RE: LST Rebuild    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Losi Monster Trucks >> RE: LST Rebuild
Page: <<   < prev  1 2 [3]
Login
RE: LST Rebuild - 2/19/2012 2:21 PM
1QwkSport2.5r
Score: 155
Last Login: 5/21/2013
Status: online
quote:
ORIGINAL: Muskokarc
I installed a Pushglow starter
http://switchglo.com/shop/product_info.php?products_id=29&osCsid=jtsgugp08h2uhsbi6mpiuqgs23
You shouldn't drive the truck with a glow driver running on it all the time. Depending on the fuel and glow plug, this will advance the ignition timing too far which can cause all sorts of not-so-nice habits. Using that driver to get the truck running is fine, but running it all the time is not good. The engine isnt going to run properly if the glow plug is externally heated all the time.
If the engine quits when you remove the glow driver, the low speed mixture is too rich.
_____________________________
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
(in reply to Muskokarc)
       Post #: 51
RE: LST Rebuild - 2/19/2012 6:24 PM
Muskokarc
Score: 105
Last Login: 4/25/2013
Status: offline
The on board igniter only applies power to the plug for 12 seconds then increases by 5 seconds each time you push the button.  You can stop the powering by holding onto the button for 2 seconds.  While powering it gives a constant beeeep.  If you do not get a beep you know connection is bad or the plug has gone.  The Traxxas Revo has a similar igniter installed as stock.
I would recommend it to any nitro user.  It pulls power from your rx power when activated.
Youtube ID Muskokamike100
Hide Signatures
(in reply to 1QwkSport2.5r)
       Post #: 52
RE: LST Rebuild - 2/19/2012 6:26 PM
Muskokarc
Score: 105
Status: offline
Hide Signatures
       Post #: 53
RE: LST Rebuild - 2/25/2012 10:28 PM
Airbus 9e
Score: 115
Last Login: 5/9/2013
Status: offline
Something I noticed in your pics...Your new F-150 Raptor body is going to need some ventilation or you'll be melting down your engine. I just use a body reamer to neatly open up the windshield and I also remove the side windows. More air is better.
Custom Works x3.....ADX, Custom E-Maxx,Losi modified LST2, LST2, NTC3, RC10T4 Oval, RC18T and a lot of other junk.....
Hide Signatures
       Post #: 54
RE: LST Rebuild - 2/26/2012 3:04 AM
Muskokarc
Score: 105
Status: offline
Will open it up come warmer weather.   There is a fair bit of air flow with the hight in the cold.  I used my Dremel to cut a hole over the gas tank for access.  A temp gun is on my list of things to get soon as hrs at work increase and have a higher cash flow.   I think I will cut out one of the side windows above the spin start so I can see it when trying to start with the body on.  Right now the glare makes it hard to see.
Hide Signatures
(in reply to Airbus 9e)
       Post #: 55
RE: LST Rebuild - 3/19/2012 1:34 AM
Muskokarc
Score: 105
Status: offline
Well with the nice weather this past week have got some time to go out and run.  Was running my LST and it kept stalling out when I accelerated  Lucky me my friend has lots of experience with nitro and helped figure out why.  The high speed needle kept winding it self back down and leaning it right out, so he said will need new O ring for the needle.
Well with some experience with seals I decided to try an experiment with it before replacing it.  What I did was pour some nitro fuel 20% in a small rubermade container and then soaked the needle with the O ring on it over night.  Well it worked quite well almost to much.  Is a nice snug fit now and does not turn with the vibration.
Took it out today and worked like a charm.  Now just need to work on tune it properly.  It likes to stall out when i do a 180 spin turn, and sure enough it usually the farthest point I am running it to.  Then it likes to give me trouble starting again.  Well thats the fun part figuring whats wrong and how to fix it.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 56
RE: LST Rebuild - 3/19/2012 6:45 PM
HerrSavage
Score: 318
Last Login: 5/4/2013
Status: offline
What size shims are INSIDE of the diff, unde the gear? And are they standard - i.e. the same as in for ex. and Associated SC8, Ofna DM-1, etc? I need those shims, and also the ones for shimming outside the diff between the diff casing and the bearing..
Nitro > stamp collecting, watching grass grow, cleaning room, etc.. > electric.
Hide Signatures
       Post #: 57
RE: LST Rebuild - 3/19/2012 9:50 PM
Muskokarc
Score: 105
Status: offline
 Not sure what the sizes are.
Most of the parts are still available online Amain has a good selection. Go to Losi website and download the exploded parts list will give you all the numbers that you will need.
Hide Signatures
(in reply to HerrSavage)
       Post #: 58
RE: LST Rebuild - 4/20/2012 3:30 AM
Muskokarc
Score: 105
Status: offline
I am looking for a new RX pack for the truck itself.  Has any one use LiFe pack in there trucks??  What has been your experance?
New pics.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 59
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.359RCU1
