10S Cell Pro charger    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pattern Aircraft >> 10S Cell Pro charger
Page: [1]
Login
10S Cell Pro charger - 8/25/2011 4:51 AM
rgreen24
Score: 100
Last Login: 5/26/2013
Status: offline
Hello all, i recently bought a 10S charger and it has been perfroming flawlessly until tonight. I just bought it a month ago a noticed that it still had the older software. My issue is i have it connected to an IOTA power supply as well as my 1010C charger, both are four 4 years old. today it keep reading <10 volts, and then it would say as well supply unstable. what i dont understand is that my TP1010C charger works without issue where my 10S will beep and end the charge ubruptly. Is there something that i am doing wrong here? I am hooking it up how i always hook it up. I have a pattern contest the weekend and i really need to get this chager working properly. ANy help would be appreciated.
thanks
Hide Signatures
       Post #: 1
RE: 10S Cell Pro charger - 8/25/2011 5:33 AM
OhD
Score: 100
Last Login: 5/22/2013
Status: offline
Disconnect the TP 1010C and see how it works. Make sure you have good connections to the Iota power supply.
Jim
Hide Signatures
(in reply to rgreen24)
       Post #: 2
RE: 10S Cell Pro charger - 8/25/2011 11:31 AM
rgreen24
Score: 100
Status: offline
Hi Jim, I tried that as well. I have been reading that their Frmware update to help with this problem v 2.29 and I am on 2.24. The firmware came out last August, and I bought the charger in July of this year. It's odd that new chatter would not have the newest firmware update since it was bought almost a year after the new firlmware release.
Hide Signatures
(in reply to OhD)
       Post #: 3
RE: 10S Cell Pro charger - 8/25/2011 11:42 AM
jlkonn
Score: 100
Last Login: 1/26/2013
Status: offline
Hey Robert!
How's it going?
Did you get the interface cable?
http://www.store.revolectrix.com/Products/Cellpro-10s_2/FUIM3
If you didn't perhaps someone in your club has one.
With it you can download the firmware updates from FMA's website.
I have two 10s chargers and running them both to charge my 10s packs
off my Iota 55 I will sometimes get the same low voltage messages you're getting.
My solution was to set the chargers at 4.5amp max instead of 5.0.
Good luck!
JLK
_____________________________
A goal without a plan is just a dream.
AMA 97605
Hide Signatures
       Post #: 4
RE: 10S Cell Pro charger - 8/25/2011 1:17 PM
ArchNemesis
Score: 100
Last Login: 5/24/2013
Status: offline
Hey Robert,
Check to see if any of your banana plugs are getting warm or hot.  I've had this error on a few occasions and every time it was the result of poor connections via the banana plugs.  If they're not making solid contact, then they just become big resistors and will get very warm.
Mark Atwood
Team Airtronics | Castle Creation | F3A Unlimited | YS Parts and Service
Hide Signatures
(in reply to jlkonn)
       Post #: 5
RE: 10S Cell Pro charger - 8/25/2011 1:57 PM
rgreen24
Score: 100
Status: offline
Charger decided to work this morning. Go figure
Hide Signatures
(in reply to ArchNemesis)
       Post #: 6
RE: 10S Cell Pro charger - 8/25/2011 2:16 PM
nonstoprc
Score: 110
Status: offline
It is easy to measure whether the DC input voltage is really under 10v or not, and go from there.
Where facts are few, experts are many.
Perfection is God''''s business.
Hide Signatures
       Post #: 7
RE: 10S Cell Pro charger - 8/25/2011 2:28 PM
F3A Unlimited
Score: 123
Status: offline
There is a screen where you can monitor input voltage for fluctuations. I have had this error and watched the input voltage jump around just prior to the error. I have traced it back to a loose connector or undersized wire etc. every time and after I tightened up all the connectors again, it would be fine.
F3A Unlimited
Hide Signatures
(in reply to nonstoprc)
       Post #: 8
RE: 10S Cell Pro charger - 8/25/2011 3:58 PM
woodie
Score: 100
Status: offline
You might want to check the clips that hold the fuses are also tight. They sometimes get a little loose and that can lead to increased resistance. If the fuse is hotter than the charger, that is an early indicator the fuse holder is getting loose where the fuse pins plug in the clip.
Woodie
"In theory there is no difference between theory and practice. In practice there is." Yogi Berra
Hide Signatures
(in reply to F3A Unlimited)
       Post #: 9
RE: 10S Cell Pro charger - 8/25/2011 4:03 PM
smcharg
Score: 110
Status: offline
Also, the current version of firmware available is 2.30.  The firmware is obviously not the issue but 2.30 has been rock-solid for me.  Looking forward to the 10XP coming out next month!
Scott McHarg
Hide Signatures
(in reply to woodie)
       Post #: 10
RE: 10S Cell Pro charger - 8/25/2011 5:09 PM
nonstoprc
Score: 110
Status: offline
If the connetion at the DC input side is loosing, the connectors and/or wires can become very hot and the power converter can be at risk of fire.
I always set the output voltage at 12.6v to cap the DC current at 20a. Periodic checking of the temperature of the power unit and the charger during charging is a good practice.
Hide Signatures
(in reply to smcharg)
       Post #: 11
RE: 10S Cell Pro charger - 8/26/2011 12:23 AM
rgreen24
Score: 100
Status: offline
And the winner that to my dilemma is all the above. The fuse holders were a little loose, so I tightened them up. Alsombought new banana plug connectors, the gold plated kind and it seems to be working with out an use at this point.
Nonstoprc - with you limiting the voltage to 12.6, how long are you waiting for your packs to charge.
Thanks to all of you for your input, this thread will certainly help the person this happens to.
Jlkonn - are we going to see you at any more contest? How is life in Ohio?
Hide Signatures
       Post #: 12
RE: 10S Cell Pro charger - 8/26/2011 3:56 AM
nonstoprc
Score: 110
Status: offline
Rgreen24,
Since my 5000mah packs are rated at 1c, the charging time is about 30-40 minutes per pack per charger, at no more than 5a of the charging current.
Hide Signatures
       Post #: 13
RE: 10S Cell Pro charger - 8/26/2011 6:12 AM
patternflyer1
Score: 100
Last Login: 5/20/2013
Status: offline
I had this same problem exactly. Mine was caused by a bad solder joint (actually looked like no solder) where the pins for the fuse are. Pull out your fuse and see if it's melted and burned. Mine was and it was still working but then I started getting the same error.
Chris
Edit.
BTW, mine did the same thing where it started working again, but soon failed again. Did that for a while before I found the problem.
Team BJ Craft Team F3A Unlimited
Team Airtronics
Hide Signatures
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.390RCU1
