Jim_McIntyre
ON, CANADA Status: offline
[QUOTE]Originally posted by DBCherry Jim, We have a four in the air limit at one field, five at a time at the other, and in eight years, I've never seen anything like this happen.[/QUOTE] Then you are either very lucky or you all fly aircraft of similar performance. Having a big floaty Tigermoth in the same pattern with a Nelson powered Diamond Dust is a recipe for disaster. Mix in a heli and Funfly plane and you're sure to see some carnage if you strictly enforce the pattern. The pattern is a great way to control airspace over the field but, just like at the real airport, there's a heck of a lot more airspace out there. Q: if everyone flies the pattern all the time, how do you practice spins, Cuban-8s or any aerobatic pattern for that matter? Yes, we have the prority calls for deadstick etc. but we also call low-pass or low pass from the {compass direction} (if anti-pattern). Mild non direction-changing aerobatics (eg. slow roll) are permitted in the circuit, all others must be performed out of the circuit or, by special pre-arrangement eg. "Hey guys, gimme a couple minutes to do some low-n-slow stuff over the runway ok?" It's just the same rules you learned in the sandbox. Share the resources and everyone gets equal time centre-stage while emergencies have priority.
_____________________________
http://scalebuilder.org
