Finding the right prop    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Finding the right prop
Page: [1]
Login
Finding the right prop - 8/31/2011 5:33 PM
paulflys4fun
Score: 100
Last Login: 3/7/2013
Status: offline
Hi, has anyone any advice or help?
I have a 3w 120cc on cans. Its an old motor, but runs like a watch. I believe the best power range on this motor is between 5,800 and 6,100 rpm. I am running at 6,000 on a 30 x 10 prop. The plane the engine is pulling around is a big old 42% iad Cap 232. Its weight is 19.5kg. The engine will just pull the model vertical, but only just. I cannot afford to lose any power at all. My problem then:-
I was flying the plane at my local field, and one member of the committee was unhappy with the noise from the prop. The plane unloads on straight and level flight and the prop rips! I like the noise very pleasing and scale like but the committee does not agree. If i now over prop the model ie putting a bigger prop or more pitch on the model i believe i will drop out of the power band of the motor. As i said earlier i cannot afford to lose power. As big props are so expensive to buy just to try and find the right match what advice would you give to solve this problem.
Paul
Hide Signatures
       Post #: 1
RE: Finding the right prop - 8/31/2011 6:51 PM
av8tor1977
Score: 665
Last Login: 5/18/2013
Status: offline
A three blade prop will usually run a little quieter, but they are not as efficient as a two blade so you will probably lose some thrust. Some brands of props run quieter than others, but 30" props are pretty expensive to experiment with.....
I am so fortunate to live here in Mexico. I LIKE noise and here I can make all the noise I want. I even test run engines frequently right at my home with no complaints.
AV8TOR
_____________________________
If it is not SCARY, it is NO WHERE NEAR powerful enough!!
Hide Signatures
(in reply to paulflys4fun)
       Post #: 2
RE: Finding the right prop - 8/31/2011 6:56 PM
Tired Old Man
Score: 662
Last Login: 1/16/2012
Status: offline
It's still a 42.99 pound plane being flown with a 120. It's not a problem of finding a porp that won't cost any power. It doesn't have the power it needs now so the true solution is a larger engine that does not have to be wound up tight all the time to fly it.
Never lie, and never minimize or gloss. Tell it like it is and let the pieces fall where they may. The truth always wins.
Hide Signatures
(in reply to av8tor1977)
       Post #: 3
RE: Finding the right prop - 8/31/2011 7:44 PM
paulflys4fun
Score: 100
Status: offline
Hi, i agree the engine is working hard, but it will pull the cap up vertical just about. It flys very scale like to be fair. An old bigger engine will be heavier and will take the hole package over the 20 kg limit here in the UK, and a new lite weight engine is well out my price range, even a da copy!!!
I had thought of three blade prop, but you are very right i will lose power with one, so not practical either. I would like to try a few, but the cheapest 27 x 10 three blade is £89 so a big gamble.
Starting to think i either fly when noones at the field, or strip the engine and gear out and scrap the airframe.
Hide Signatures
(in reply to Tired Old Man)
       Post #: 4
RE: Finding the right prop - 8/31/2011 8:58 PM
DadsToysBG
Score: 125
Last Login: 5/17/2013
Status: offline
If I remember right the 3-w 120 weighted the same as a 150 at 8.5lbs. So moving up will not increase the weight of the plane. the 150 will fly the plane at a lot less throttle with a bigger prop 32x10 therefore less noise. Dennis
DadstoysRC. I fly what I sell
CD Vette City Big Bird
Hide Signatures
       Post #: 5
RE: Finding the right prop - 8/31/2011 9:04 PM
paulflys4fun
Score: 100
Status: offline
As i have posted before getting a da 150 is not an option money wise at the moment. I posted here as i hoped i had mist something. It would seem not.
I will strip the gear out tomorrow and wait for a second hand airframe to come along.
It was worth a quick post all the same.
Thanks Guys
Hide Signatures
(in reply to DadsToysBG)
       Post #: 6
RE: Finding the right prop - 8/31/2011 9:32 PM
Tired Old Man
Score: 662
Status: offline
Making the plane lighter will provide the greatest benefit.
Hide Signatures
       Post #: 7
RE: Finding the right prop - 8/31/2011 9:58 PM
DadsToysBG
Score: 125
Status: offline
What I was thinking was getting a used engine and offsetting the price by selling the 120. Dennis
Hide Signatures
       Post #: 8
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> Finding the right prop
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.406RCU1
