RE: LA7 Info / Research / Build - Scale Wings    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: LA7 Info / Research / Build - Scale Wings
Page: <<   < prev  1 2 3 4 [5] 6 7 8   next >   >>
Login
RE: LA7 Info / Research / Build - Scale Wings - 3/3/2012 8:17 PM
wxman2
Score: 100
Last Login: 5/25/2013
Status: online
Here is a status update
The real and dummy hinges are in… Have a bit of epoxy cleanup work to do on them.
Made the oil cooler exhaust flap functional which should help with getting air out of the airframe. Should create a good low pressure area behind it to pull air out. Not exactly sure how I am going to use this right now but one thought is to link (mix) the oil cooler flap (door) to the throttle position.
I sanded out the mold lines on the cowl today.
Received the retracts back from Down & Locked yesterday.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by wxman2 -- 3/3/2012 9:54 PM >
Hide Signatures
(in reply to wxman2)
       Post #: 101
RE: LA7 Info / Research / Build - Scale Wings - 3/5/2012 8:47 PM
wxman2
Score: 100
Status: online
The large access door looks good when it is pulled down tight; I guess I will start with magnets to see if that will keep it pulled down and then use a standalone servo to push the door open.
Also, here are two more shots of the oil cooler door.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 102
RE: LA7 Info / Research / Build - Scale Wings - 3/11/2012 8:46 PM
wxman2
Score: 100
Status: online
I got a few things done since the last post. Installed the tail gear doors and dummy hinges in the cowl. I have been using a 3M full face mask for the dust.
Designed the access panel and got ready to cut the CF with a 1/8 bit then realized I didn't have a 1/8 collet, so had to order that.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 103
RE: LA7 Info / Research / Build - Scale Wings - 3/14/2012 1:08 AM
wxman2
Score: 100
Status: online
I have been working on fitting a grill to the inside of the oil cooler; which still need some teaking...
I could use some recommendations on the tail gear doors. I cannot seem to find the right arm length and/or angle to make this design work.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 104
RE: LA7 Info / Research / Build - Scale Wings - 3/14/2012 9:12 AM
mick15
Score: 105
Status: offline
I can take a picture of mine, installed by the factory and seems to work ok.
m
Hide Signatures
       Post #: 105
RE: LA7 Info / Research / Build - Scale Wings - 3/14/2012 10:25 AM
wxman2
Score: 100
Status: online
quote:
ORIGINAL: mick15
m
Thanks M...
John
Hide Signatures
(in reply to mick15)
       Post #: 106
RE: LA7 Info / Research / Build - Scale Wings - 3/14/2012 1:07 PM
wxman2
Score: 100
Status: online
I am pleased with the look of the oil cooler grill now... Just need to add some dirt and grime to it and it will be perfect.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 107
RE: LA7 Info / Research / Build - Scale Wings - 3/14/2012 1:30 PM
wxman2
Score: 100
Status: online
The more I use the Down & Locked converted gear the more I like it. Once I get my CARF P-47 back from Graham (Jetjockgb), I will be sending that gear to them for a conversion.
Hide Signatures
       Post #: 108
RE: LA7 Info / Research / Build - Scale Wings - 3/15/2012 10:57 AM
mick15
Score: 105
Status: offline
Picture of the doors you require.
m
Click for fullsize
Hide Signatures
       Post #: 109
RE: LA7 Info / Research / Build - Scale Wings - 3/16/2012 4:22 AM
wxman2
Score: 100
Status: online
quote:
ORIGINAL: mick15
m
M,
I will install it the way your photo shows. Thanks again...
John
Hide Signatures
       Post #: 110
RE: LA7 Info / Research / Build - Scale Wings - 3/20/2012 2:26 AM
wxman2
Score: 100
Status: online
Cut the access control panel out tonight along with a few other items. Almost ready to mount the oil cooler and epoxy it on.
Click for fullsize
Hide Signatures
       Post #: 111
RE: LA7 Info / Research / Build - Scale Wings - 3/24/2012 11:02 PM
wxman2
Score: 100
Status: online
Was on the road working the last part of the week and just getting back to the LA-7. Almost have the control/fuel panel done...
Click for fullsize
Hide Signatures
       Post #: 112
RE: LA7 Info / Research / Build - Scale Wings - 3/27/2012 2:37 AM
wxman2
Score: 100
Status: online
Worked on the frame for the control panel this evening; almost done with it. Been test fitting it as I go...
If I ever want or need to change the panel layout, it will be easy to remove the insert and make a new one.
Click for fullsize
Click for fullsize
< Message edited by wxman2 -- 3/27/2012 3:10 AM >
Hide Signatures
       Post #: 113
RE: LA7 Info / Research / Build - Scale Wings - 3/29/2012 9:16 PM
wxman2
Score: 100
Status: online
Went to mount the Moki 250 today and realized that the engine standoffs are missing.
Could use some help from ScaleWings LA-7 owners on how long should these standoffs be?
I will email Hans at ScaleWings too...
I have attached two photos are what they look like.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 114
RE: LA7 Info / Research / Build - Scale Wings - 3/29/2012 9:40 PM
mick15
Score: 105
Status: offline
Mine does'nt have standoffs, it has a built up wooden mount. The measurements will obviously be the same though, I can measure it for you but not tonight.
m
Hide Signatures
       Post #: 115
RE: LA7 Info / Research / Build - Scale Wings - 3/31/2012 12:21 AM
wxman2
Score: 100
Status: online
Spent the afternoon making CF parts to replace the wood ones...
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 116
RE: LA7 Info / Research / Build - Scale Wings - 4/1/2012 5:34 PM
wxman2
Score: 100
Status: online
I felt like a change of pace on the LA7 assembly so I started working on redesigning the fuel tank holder and equipment tray.
My LA7 came with only one of the round fuel tanks and it has been a pain trying to get another for a smoke-tank. So I decided just to go with DU-BRO 80oz tanks for fuel/smoke. This required a redesign of the original ScaleWings parts and I also extended the length from 200mm out to 500mm. This will allow me to mount the Futaba PSS2018 and all the other items like batteries and APS fuel / smoke pumps on this one slide out assembly.
The first photo shows what the original holder looks like…
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 117
RE: LA7 Info / Research / Build - Scale Wings - 4/1/2012 7:39 PM
Prekin
Score: 101
Status: offline
Hello wxman,
I saw the picture of the book about the La-7 and it looks, that it is in the Czech language. If you want, I can translate something for you, if you don´t have it in the English.
Hide Signatures
       Post #: 118
RE: LA7 Info / Research / Build - Scale Wings - 4/1/2012 7:44 PM
wxman2
Score: 100
Status: online
Thanks Perkin,
I may take you up on this offer... I have one MBI La-7 book that is in Czech with an English translation, but have been using Google Translator for some other Russian manuals.
Hide Signatures
(in reply to Prekin)
       Post #: 119
RE: LA7 Info / Research / Build - Scale Wings - 4/1/2012 7:50 PM
Prekin
Score: 101
Status: offline
OK, If you will have some problem with Russian or Czech, write it here, or use my e-mail, and I can help you.
Hide Signatures
       Post #: 120
RE: LA7 Info / Research / Build - Scale Wings - 4/1/2012 8:35 PM
wxman2
Score: 100
Status: online
Finished up the 2D CNC drawing... Plan to cut this out of wood first to make sure of the fit before cuting the carbin fiber.
Click for fullsize
Hide Signatures
       Post #: 121
RE: LA7 Info / Research / Build - Scale Wings - 4/5/2012 3:32 PM
wxman2
Score: 100
Status: online
I posted an open question about using a shaft couper here for this project:
http://www.rcuniverse.com/forum/m_11029214/anchors_11029214/mpage_1/key_/anchor/tm.htm#11029214
Hide Signatures
       Post #: 122
RE: LA7 Info / Research / Build - Scale Wings - 4/7/2012 2:54 AM
wxman2
Score: 100
Status: online
The top and bottom trays are built... Just need a bit of time for the epoxy to cure and will finish up the assembly in the morning.
Plan to mount the motor tomorrow to figure out how long the standoffs need to be.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 123
RE: LA7 Info / Research / Build - Scale Wings - 4/7/2012 11:03 PM
wxman2
Score: 100
Status: online
Here is the finished fuel/smoke tank holder / equipment tray contraption...
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 124
RE: LA7 Info / Research / Build - Scale Wings - 4/7/2012 11:05 PM
wxman2
Score: 100
Status: online
The main wheel covers that came with the plane are plastic and I started the process digitizing one of them so that I can cut it out of aluminum.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
