RE: RCEXL Opto Kill Switch Ignition vs. receiver Voltage Question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
RCexl ignition for most any engine
Seller:  BadAzzMaxx
Details:   $54.95   |  4/26/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: RCEXL Opto Kill Switch Ignition vs. receiver Voltage Question
Page: <<   < prev  1 [2]
Login
RE: RCEXL Opto Kill Switch Ignition vs. receiver Voltag... - 11/20/2011 8:14 PM
exteng
Score: 100
Last Login: 12/17/2012
Status: offline
Hi,
i have the same issue with Frsky D8R II RX , the engine runs fine with the killswitch on but the tachometer keeps rebooting...........i ll try to put a signal booster on the throttle kill channel and see what happens......
Hide Signatures
(in reply to sthill)
       Post #: 26
RE: RCEXL Opto Kill Switch Ignition vs. receiver Voltag... - 1/8/2012 11:44 PM
WildeOne
Score: 100
Last Login: 5/1/2012
Status: offline
I have read this thread, use 6 vdc Rx pack and 4.8 vdc ignition pack and do not use opto kill switches, but use a small servo operated switch that is very compact, cheap and totally isolated since it has no connection to either power source, other than the servo is driven by the Rx's 6 vdc. My switches are made using a reed relay, actuated by a very small (1/8" dia x 1/4") rare earth magnet glued in a servo wheel. The reed relay is epoxied in a short piece of soda straw after leads are attached. The whole affair is then glued to the top of a small servo. These tiny reed relays will typically switch 2 A or more and are very small ( 1 or 2 mm in dia) and are good for 100,000's of cycles, are very vibration tolerant AND they are cheap. Picture of a completed assembly below My radio allows setting a failsafe, so I set it to open the reed relay and disconnect ignition power if RX loses signal.
I was considering using opto switches, but after reading this thread, I don't think so. My deal is very inexpensive and bulletproof. It also has the advantage of drawing no power when the RX is powered down, so it could be used as a shutdown switch for the ignition, but I have chosen to use a separate physical switch for that function.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by WildeOne -- 1/9/2012 3:32 AM >
_____________________________
Jim
Hide Signatures
(in reply to exteng)
       Post #: 27
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: RCEXL Opto Kill Switch Ignition vs. receiver Voltage Question
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.223RCU1
