RE: Another Fliteskin ME 109 build thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Another Fliteskin ME 109 build thread
Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: Another Fliteskin ME 109 build thread - 3/3/2012 3:42 PM
glazier808
Score: 291
Last Login: 5/26/2013
Status: offline
It works quite well actually...you will destroy it be befor it ever comes apart!
Keep up the good work erans....it won't effect anything (that spot)
Casey
_____________________________
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
(in reply to jaka)
       Post #: 201
RE: Another Fliteskin ME 109 build thread - 3/3/2012 11:45 PM
JGrc
Score: 100
Last Login: 5/19/2013
Status: offline
I do not for sure about the cavosil, epoxy does not work as well as polyurethane because the latter fills the gaps, epoxy is also much heavier.
JG
Fliteskin is tougher than you think!
Hide Signatures
(in reply to jaka)
       Post #: 202
RE: Another Fliteskin ME 109 build thread - 3/11/2012 12:50 PM
erans
Score: 100
Last Login: 4/28/2013
Status: offline
jaka - apologies for the late reply. As said by Jose and Casey, using the polyurethane glue is very strong solution which will not come off. I am sold on this solution and quite a few of my club members who saw it were very impressed, to the level that they have asked me to demonstrate to them the covering so they can utilise it on their own coming projects.
Back to my wing, I covered with Fliteskin the left bottom side today. This time I took some additional photos of the glue application. The photos below show the sequence from last test fit to the lifting of the "weight" with the only omission being applying moisture with wet cloth to both wood and Fliteskin sheet.
First impression after lifting the "weight" is that it came out quite good.
With the work load I currently have with my new job, the build will be slowed down dramatically, but I hope to manage both flying and building somehow.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by erans -- 3/11/2012 1:41 PM >
Hide Signatures
(in reply to jaka)
       Post #: 203
RE: Another Fliteskin ME 109 build thread - 3/24/2012 1:27 PM
erans
Score: 100
Status: offline
It has been two weeks since I last touched the aeroplane. Finally this evening I had 1/2 hour free, so, it was time to pull out the T-Pins which were still "holding" the Fliteskin in the perimeter. Then I did a "rough" clean up of of the edges and released the flap which had some Gorilla glue holding it in place (in the gap to the wing TE).
Overall the result is quite good. I have some work to do on the joint between the wing tip and the Fliteskin at the bottom, nothing major.
The last thing for this evening was to mark the wheel cutting using the same template I used on the other half wing.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to erans)
       Post #: 204
RE: Another Fliteskin ME 109 build thread - 4/25/2012 9:10 AM
erans
Score: 100
Status: offline
It has been a while since I touched the Me-109. Starting a new job sacked all my energy and motivation.
Jose was asking what is going on with my build in his TA-152 thread and I realised it is about time to get moving (thatnk you Jose). The perfect opportunity came with the public holiday today here in Australia.
So, I continued where I left last time and cut both bottom wing Fliteskin covering from the landing gear bay.
I then took the left wing outside and sanded the Leading Edge to Fliteskin "transition line" and some Gorilla glue where it run over the LE.
This is part of my preparation to fibre-glass the LE.
Unfortunately, I didn't have time to do the other wing today.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to erans)
       Post #: 205
RE: Another Fliteskin ME 109 build thread - 4/25/2012 9:28 AM
saramos
Score: 121
Status: offline
Good to see you back at it.
Hide Signatures
(in reply to erans)
       Post #: 206
RE: Another Fliteskin ME 109 build thread - 4/25/2012 9:38 AM
Prekin
Score: 101
Status: offline
Hello Earans,
I like your Bf-109, the idea with the slots on leading edge is great, but be careful with the deviation and with the speed. The airplane is very sensitive on the method of the makeing bigger lift force.
As I see, you chose engine MVVS 30. I had one, but sometime I had problem with starting, because engines MVVS 26,30 and 40 have walbro in front of. This is the reason, why I now useing MVVS in my Bf-109.
Hide Signatures
(in reply to erans)
       Post #: 207
RE: Another Fliteskin ME 109 build thread - 4/25/2012 11:09 AM
erans
Score: 100
Status: offline
saramos - Thank you, it is a great feeling to get back to it
Prekin - I have the MVVS 40 in my Great Planes SU-31. It is very reliable and strong engine. I start it with a heavy duty starter and never had a problem.
We have assortment of petrol engines at our airfield in many sizes and capacities, from cheap Chinese engines to expensive well known brands. From all of them, the MVVS seem to be the engine which just works, no fuss.
As to the slats, I will see how it go. Jose had no issue with his, so I do not expect issues with my setup. By the time I will get my Me-109 flying I will have flying review from Casey as well, so plenty of time to take a decision.
Hide Signatures
(in reply to Prekin)
       Post #: 208
RE: Another Fliteskin ME 109 build thread - 4/25/2012 2:43 PM
Prekin
Score: 101
Status: offline
So now I understand, if you use starter, you have no problem.
What weight of your Bf-109 are you expecting?
Hide Signatures
(in reply to erans)
       Post #: 209
RE: Another Fliteskin ME 109 build thread - 4/25/2012 3:19 PM
erans
Score: 100
Status: offline
The weight is the Million dollar question. I hope not to pass the 7Kg, which in Australia require "Heavy Model Permit", but am not sure what will be the final weight.
Maybe Jose will tell us how much his Me-109 weighted when he reply. I think my Me-109 may be slightly heavier due to the use of the MVVS petrol engine (Jose used the OS 160).
Hide Signatures
       Post #: 210
RE: Another Fliteskin ME 109 build thread - 4/25/2012 3:23 PM
glazier808
Score: 291
Status: offline
Erans,
good to see you take a break from the new job...remember, we work so we can play!
I put mine on the scales a couple days ago, and as mine sits I'm at 8 pounds 6oz for the fuse and 4 pounds 4 oz on the wing. That under 13 pounds! The battery pack weighs about a pound and a half...so I think I will be right in the neighborhood of 17 pounds, if not under that. Not bad for all the detail work thats gone in to it.
I hope to have something to post shortly, I got side tracked finishing the paint on my 109E and changing out some digital servos that I didnt care for in my flaps.
Casey
< Message edited by glazier808 -- 4/25/2012 4:33 PM >
Hide Signatures
       Post #: 211
RE: Another Fliteskin ME 109 build thread - 4/25/2012 3:32 PM
erans
Score: 100
Status: offline
Hi Casey, I can't weight to see where you are at with your build. I was actually giving myself "mental note" the other day to have another look at your wing radiators. I think to do them before I join the wing.
17 pounds is 7.7Kg, and you do have much more details then I will have, so I may just be able to get it under 7Kg.
This little work I did today lifted my spirit. I think I found my building "Mojo" again
Hide Signatures
(in reply to glazier808)
       Post #: 212
RE: Another Fliteskin ME 109 build thread - 4/25/2012 5:11 PM
JGrc
Score: 100
Status: offline
HI ERan,
my 109 weight was 17lbs. and that's not a heavy model! [>:]
JG
Hide Signatures
(in reply to erans)
       Post #: 213
RE: Another Fliteskin ME 109 build thread - 4/25/2012 5:14 PM
Prekin
Score: 101
Status: offline
7kg?!! It´s great for 2m wingspan warbird. My Bf-109G is 9,5kg it is 20,9 pounds. Some CMP Zero has about 11kg! If you will have 7kg, you will be able to hang on the prop!
Hide Signatures
(in reply to erans)
       Post #: 214
RE: Another Fliteskin ME 109 build thread - 4/28/2012 4:45 AM
erans
Score: 100
Status: offline
I didn't had the opportunity to update the progress yesterday, but I had 20 minutes to sand the LE of the other wing.  Every minute counts
Next is the "fine" sanding and getting the LE surface ready for fibreglass.
I hope to get some of it done this weekend.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 215
RE: Another Fliteskin ME 109 build thread - 4/28/2012 10:26 AM
erans
Score: 100
Status: offline
After some more sanding to the LE today with a fine sandpaper, I am ready for the filler.
I saw in Casey's build that he was using the "SuperFil", so I decided to try it.
I did "chickened" (trying it first time on the LE), so I am testing it on some scrap balsa (which I "dented" with a hammer) first.
The drying time is 8-12 hours, so results will be published tomorrow.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to erans)
       Post #: 216
RE: Another Fliteskin ME 109 build thread - 4/28/2012 2:48 PM
glazier808
Score: 291
Status: offline
Erans,
I used an old credit card when putting it on. Its really nice to work with.
Casey
Hide Signatures
(in reply to erans)
       Post #: 217
RE: Another Fliteskin ME 109 build thread - 4/28/2012 3:38 PM
erans
Score: 100
Status: offline
It is very nice to work with, I am looking forward to see how easy it sands.
If it will keep raining as it is at the moment, I will have plenty of time to do both wings LE tomorrow instead of going to the airfield...
Hide Signatures
       Post #: 218
RE: Another Fliteskin ME 109 build thread - 4/29/2012 12:57 PM
erans
Score: 100
Status: offline
The weather was good enough to go to the airfield, but, I did found the time to do the "fine" sanding to the LE of the left wing.
I then applied filler to both LE and on the connection of the wing tip.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to erans)
       Post #: 219
RE: Another Fliteskin ME 109 build thread - 4/29/2012 5:34 PM
JGrc
Score: 100
Status: offline
Eran, did you glass the leading edges?
JG
Hide Signatures
(in reply to erans)
       Post #: 220
RE: Another Fliteskin ME 109 build thread - 4/30/2012 12:39 AM
erans
Score: 100
Status: offline
Not yet. This filler is preparation for it to get the surface reasonably smooth.
Unfortunately the surface, after the sanding of the Fliteskin "edges", was not that great, so I had to do something about it.
Hide Signatures
(in reply to JGrc)
       Post #: 221
RE: Another Fliteskin ME 109 build thread - 4/30/2012 12:49 AM
JGrc
Score: 100
Status: offline
I always glass cloth the leading edges after the skins are glued down. After that, I use body filler only where is needed. Saves a bit of time.
JG
Hide Signatures
(in reply to erans)
       Post #: 222
RE: Another Fliteskin ME 109 build thread - 4/30/2012 9:55 AM
erans
Score: 100
Status: offline
That was the plan. The skins are glued down and it was supposed to be the next stage.
Unfortunately, I had couple of larger "dents" that required filling, so while anyway mixing the filler, I did the lot...
Hide Signatures
(in reply to JGrc)
       Post #: 223
RE: Another Fliteskin ME 109 build thread - 5/1/2012 10:29 AM
erans
Score: 100
Status: offline
I sanded the LE today and now I am fully converted. This SuperFil is awesome, So easy to sand. Thank you Casey
Then, I did the first fibreglass section and must admit that I am not very happy with my workmanship on it.
I will have to wait and see how it went when it is dry.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to erans)
       Post #: 224
RE: Another Fliteskin ME 109 build thread - 5/5/2012 8:27 AM
erans
Score: 100
Status: offline
As expected, the LE fibreglass work I did earlier this week was nothing to write home about...
There will be fair amount of sanding to do to fix it.
So, while at it, I fibre-glassed the Slat area today, trying not to repeat my mistakes.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to erans)
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.766RCU1
