Wagner Solution EF-1 Kits!! 09-12-2011    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Pylon Racing >> Wagner Solution EF-1 Kits!! 09-12-2011
Page: [1]
Login
Wagner Solution EF-1 Kits!! 09-12-2011 - 9/3/2011 6:01 PM
Iceman67
Last Login: 3/20/2013
Status: offline
Hello All!!
I wanted to announce the release of the new Wagner Solution EF-1 short Kit.
It is a replica of the Judy Wagner Solution that was the 4th plans built shoestring ever. Judy was the first woman to win a 1F1 race and did so with this airplane.
I am asking $125 plus shipping, The kits include the following:
Laser Cut 1/8" lite ply fuselage parts
Laser cut 3/16" balsa Stab & Rudder
Blue Core Foam Wings
Fiberglass Cowl
Fiberglass Canopy
Fiberglass Wheel Pants
Aluminum Landing Gear
Instructions
Please contact me if you are interested. Email is archiea67@ymail.com Paypal is the preferred method of payment to that address.
I have attached some photos of the Wagner. Just recently won the CAPS Classic EF-1 race with fast time. The airframe will accept the Eflight Power 25 1250Kv, Turnigy SK 35-42-1250Kv, or the Arrowind 2820-07 1300Kv motors. These are the approved NMPRA motors for EF-1. It will accept others as well, but it was designed for racing EF-1 so it was designed to accept these motors specifically. The battery tray holds a 4S 2650 pack quite nicely. Finished weight is 3.25lbs.
Archie Adamisin
Muncie, IN
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Archie Adamisin
Muncie, Indiana
Hide Signatures
       Post #: 1
RE: Wagner Solution EF-1 Kits!! 09-12-2011 - 9/5/2011 5:22 PM
Iceman67
Status: offline
Here are some pictures of the laser cut fuse parts going together. The tab and slot construction lock everything in straight making for a quick build. Once glued together, the fuse is quite strong.
Airplane specs are:
Wing Span 51 7/8"
Wing Area 378 sq in
Fuse Length 35.25"
RTF Weight 3.25lbs (52ozs) (with EF-1 legal power plant & batteries)
I fly mine with an Arrowind 2820-07 1300Kv motor (http://www.brodak.com/shop_productdetail.php?ProductID=9066), Castle ICE 100 lite esc, Turnigy 4S 40C 2650 Li Poly batteries, APC "E" 8 x 8 prop, Hitec HS-225BB mighty mini servos, and Turnigy 9X 2.4 Radio. The cowl is made for a 1.5" (38mm)spinner. I use the Brodak 1 1/2" aluminum spinner.
Archie Adamisin
Muncie, IN
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Archie Adamisin
Muncie, Indiana
Hide Signatures
(in reply to Iceman67)
       Post #: 2
RE: Wagner Solution EF-1 Kits!! 09-12-2011 - 10/22/2011 4:18 AM
Iceman67
Status: offline
Here is a picture of the first Wagner Solution EF-1 kit to be completed. This model was built by George Parks of Austin, Texas. He did a fantastic job with his and loves the way it flies.
There are now several Wagner EF-1's out there and hope to see more of them completed soon. With the weather slipping fast in the midwest and the northern states, might be limited on flight reports for the year, but you never know.
Kits are moving off the shelf and hope to have to order more parts soon for another production run. Get them while their hot!!!
Archie Adamisin
Muncie, IN
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Archie Adamisin
Muncie, Indiana
Hide Signatures
       Post #: 3
RE: Wagner Solution EF-1 Kits!! 09-12-2011 - 11/24/2011 9:25 PM
Iceman67
Status: offline
Hello and happy Turkey Day to all.
I wanted to announce that I am now offering a sheeted wing version of the Wagner Solution EF-1 kit for $175. The wing is vacuum bagged in (1) piece with epoxy and fiberlgass underneath the skins. Average wing weights have been 8ozs out of the bag. Wings will be trimmed and ready for LE. Trailing edge will be trimmed and ready for sanding. EF-1 rules mandate a minimum 1/16" TE so little sanding is required.
Look forward to seeing more finished Wagner Solutions out there.
Take Care!!
Archie Adamisin
Muncie, IN
Archie Adamisin
Muncie, Indiana
Hide Signatures
       Post #: 4
RE: Wagner Solution EF-1 Kits!! 09-12-2011 - 3/24/2012 4:21 PM
Iceman67
Status: offline
Hello all EF-1 racers. The flying season is upon us and building season is nearing an end. We will be racing soon.
I have attached some pictures of some Finished Wagner Solution EF-1 racers completed over the winter. I am finishing out my second run on Wagner Solutions and will be starting a 3rd very soon.
I will also be offering a RTC version of the Wagner Solution that is built here in the states using the kit parts. RTC version will be sold like this:
1.) Wing sheeted with ailerons finished & hinged, torque rods installed, wing hard points installed, battery notch cut out and capped, and servo slot cut out and capped. Wing tips will not be installed due to shipping costs.
2.) Fuselage will be completely assembled with all blind nuts installed & top and bottom decks sheeted.
3.) Tail feathers will be assembled, sanded, & pre-hinged.
4.) Glass parts will be filled, and primed. Hatch hold down will be installed as well as the magnets. Hatch will be potted to wing.
To finish this model, you will need (2) rolls of covering, Spray paint, EF-1 Motor, 60 amp ESC, 4S battery, 1 1/2" Spinner, & prop.
Still working out the details on price, but I will post as soon as this is decided.
Look forward to seeing EF-1 a lot more this Summer.
Archie Adamisin
Muncie, IN
Click for fullsize
Click for fullsize
Click for fullsize
Archie Adamisin
Muncie, Indiana
Hide Signatures
       Post #: 5
RE: Wagner Solution EF-1 Kits!! 09-12-2011 - 10/23/2012 11:36 AM
E Strader
Last Login: 5/23/2013
Status: offline
Very nice plane, nice looking kit. My son was asking for an E-Flite Shoestring for X-mas but we are builders not ARF'ers and I think I found his plane!! Question, Is there a reason that none of the EF1 kits I've seen have Fiberglass fuselages.
Hide Signatures
       Post #: 6
RE: Wagner Solution EF-1 Kits!! 09-12-2011 - 10/23/2012 9:39 PM
Iceman67
Status: offline
EF1 models by rule have to be built up. Glass parts can be used for non structural covers like cowls and canopies.
Thanks for the comments. The Wagner is a very easy to build kit and flies very well.
Archie Adamisin
Muncie, IN
Archie Adamisin
Muncie, Indiana
Hide Signatures
(in reply to E Strader)
       Post #: 7
RE: Wagner Solution EF-1 Kits!! 09-12-2011 - 10/24/2012 2:59 PM
E Strader
Status: offline
Archie, how long before we can see the Rivets? i can't wait because it's been one of my favorites since I was a kid. and my bad on the Matney models thunder chicken, on the website I couldn't see the wing but should have caught the landing gear!
           Eric L. Strader
           Schenectady, N.Y.
Hide Signatures
       Post #: 8
RE: Wagner Solution EF-1 Kits!! 09-12-2011 - 12/12/2012 5:21 PM
Iceman67
Status: offline
Rivets is after the Mariah and Mother Holiday Cassut I am working on. Maybe February or March, but not sure right now.
Archie Adamisin
Muncie, IN
Archie Adamisin
Muncie, Indiana
Hide Signatures
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
