building an model for as level design technology. need advise fast!!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> building an model for as level design technology. need advise fast!!!!
Page: [1]
Login
building an model for as level design technology. need ... - 9/12/2011 7:09 PM
scottydog10111
Score: 100
Last Login: 9/14/2011
Status: offline
 hi guys, basically i am building an rc aircraft as part of my as design technology. i need help ASAP and if anyone has any plans which i may have so i can get ideas off that would be great. i want my model to be aesthetically pleasing so i dont want a basic model where it is small and flimsy. i want to make one with a large, good looking fuselage etc...
i also need help with the structure of my model, do i build it bit by bit or do i get large pieces of balsa wood and carve out of it. i have little knowlage but want to get into the hobby more
so guys please help me as i need every bit of help i can get and please post pictures if you have any!!!!!
thanks guys
Hide Signatures
       Post #: 1
RE: building an model for as level design technology. n... - 9/12/2011 7:18 PM
MinnFlyer
Score: 390
Last Login: 4/27/2012
Status: offline
Here is a thread that documents the building of the airplane pictured below
http://www.rcuniverse.com/forum/m_6822225/anchors_6822225/mpage_1/key_/anchor/tm.htm#6822225
Click to see fullsize image.
Click for fullsize
_____________________________
Mike B. AMA# 42400 www.gettingairborne.com
Ultra Sport Brotherhood #2 - Waco Brother #188 - Cub Brother #2
"Those are my principles. If you don’t like them, I have others." - Groucho Marx
Hide Signatures
(in reply to scottydog10111)
       Post #: 2
RE: building an model for as level design technology. n... - 9/14/2011 1:05 AM
FallDownGoBoom
Score: 100
Last Login: 6/13/2013
Status: offline
Scotty:
Since it seems you're in a design course, are you supposed to design an airplane, then build it from scratch? Or take a kit that already exists and modify it?
Building a plane from scratch, even a relatively simple trainer, could be difficult if you have no experience in building and/or no access to the tools you'll need. I've attached some older, but still accurate articles about aircraft design. But I'm not sure they'll take you through the process of building a wing or a fuselage (which, by the way, is typically not carved out of a series of balsa blocks).
The thread Mike has mentioned before illustrates the building of something called an Ultrasport. If you go to the Great Planes website, you can download the contstruction manual, which will give you some idea of how the various sections of the model are constructed, then assembled into a finished aircraft.
Click to see the file in new window.Attachment.pdf Click to see the file in new window.Attachment.pdf Click to see the file in new window.Attachment.pdf Click to see the file in new window.Attachment.pdf
Fred
UltraSport Brotherhood #50
Hide Signatures
       Post #: 3
RE: building an model for as level design technology. n... - 9/14/2011 1:37 AM
exeter_acres
Score: 116
Last Login: 9/24/2012
Status: offline
do we get the grade too?
Extreme Flight RC tech support
IMAC SE Regional Director|IMAC Sequence Committee|IMAC Judging Instructor|Team Futaba
Hide Signatures
(in reply to FallDownGoBoom)
       Post #: 4
RE: building an model for as level design technology. n... - 9/14/2011 1:45 AM
Gray Beard
Score: 314
Last Login: 6/19/2013
Status: offline
Being in the UK I'm pretty sure you can locate a plans service there but you can go onto the Model Airplanes News web site and go into there plans section and see a lot of different type of planes that you may like. These are plans for builders so all the parts you require to build one is shown in profile for you.
I build from these type of plans but I also re-design them to suit my own needs. It's up to you what type and size you would require but they do come in several sizes from 40 size to giant scale. They are coded as to how hard the build will be. I just finished there 80 inch Sukhoi 29 and I think it is labeled for intermediate builders but if you have never built a plane before you would never get this one finished due to the design itself.
Go there and look around but keep it simple. It's easy to think something will be easy but you can find yourself over your head in a hurry.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
       Post #: 5
RE: building an model for as level design technology. n... - 9/14/2011 2:07 AM
smithcreek
Score: 159
Status: offline
quote:
ORIGINAL: scottydog10111
...do i build it bit by bit or do i get large pieces of balsa wood and carve out of it.
Really? I assume the only effort you've made to learn about building so far has been to start this thread. When is it due?
For a kit you are, and to a kit you shall return.
Hide Signatures
       Post #: 6
RE: building an model for as level design technology. n... - 9/14/2011 2:25 AM
vicman
Score: 189
Status: offline
Go pick up the current issue of RCModel World or RCM&E. Both excellent brit mags and have a free pull out plan as well as a build article to get it started.
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
Hide Signatures
(in reply to smithcreek)
       Post #: 7
RE: building an model for as level design technology. n... - 9/14/2011 10:47 AM
scottydog10111
Score: 100
Status: offline
i am designing it from scratch and building it by myself. not from a kit. i am keen on bulding the ultrasport, it is exactly what im looking for. thanks. i have basically all year to do this including the planning, and building of the kit.
Hide Signatures
(in reply to vicman)
       Post #: 8
RE: building an model for as level design technology. n... - 9/14/2011 1:57 PM
MinnFlyer
Score: 390
Status: offline
I would STRONGLY suggest buying a kit and building it first before doing your own. There are a LOT of things you need to know, like how to join the two wing halves so they don't fold up on you in flight!
Hide Signatures
       Post #: 9
RE: building an model for as level design technology. n... - 9/14/2011 3:01 PM
EscapeFlyer
Score: 120
Status: offline
quote:
ORIGINAL: MinnFlyer
...or how to get the wing and stabilizers squared to the fuselage- or, how to set up your fuel delivery system.
Brian
N Central Regional Director
Classic Pattern Association
Hide Signatures
(in reply to MinnFlyer)
       Post #: 10
RE: building an model for as level design technology. n... - 9/14/2011 3:29 PM
Bax
Score: 169
Status: online
quote:
ORIGINAL : Ilikebipes
quote:
ORIGINAL: MinnFlyer
Brian
....or how to build a right and a left fuselage side!
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
Hide Signatures
(in reply to EscapeFlyer)
       Post #: 11
RE: building an model for as level design technology. n... - 9/14/2011 3:46 PM
MinnFlyer
Score: 390
Status: offline
As you can see, there are MANY things that can bite you in the butt if you have no experience - And we've only scratched the surface!
Hide Signatures
(in reply to Bax)
       Post #: 12
RE: building an model for as level design technology. n... - 9/14/2011 5:47 PM
Gray Beard
Score: 314
Status: offline
And why would a designer/scratch builder request free plans from RCU members?? Do what Mike says and go buy a kit. Building a plane from plans without any instructions is way beyond someone that has never built a kit or several. A kit from SIG or Great Planes have plans, instructions and all wood cut for you. The instructions even have photos and walk you through the build step by step.
Hide Signatures
       Post #: 13
RE: building an model for as level design technology. n... - 9/14/2011 6:01 PM
Lnewqban
Score: 163
Last Login: 5/6/2013
Status: offline
Scott,
Consider that some motorization, radio control gear and piloting skills may be needed for a complete project.
The simplest thing is a free flight glider.
You can find also local experienced help if you start from here:
http://www.bmfa.org/
Lnewqban - "The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge." - E. H.
Hide Signatures
       Post #: 14
RE: building an model for as level design technology. n... - 9/14/2011 6:04 PM
scottydog10111
Score: 100
Status: offline
ok then, now i am looking to buy a kit. can someone recommend a good kit? like a cub? i've looked around and seen a few nice ones but would just like some advise. also if possibly, a website in the uk would be a lot more handy
Hide Signatures
(in reply to Gray Beard)
       Post #: 15
RE: building an model for as level design technology. n... - 9/14/2011 6:10 PM
Lnewqban
Score: 163
Status: offline
Contact this champs in your area, who will have a lot of good suggestions:
Click for fullsize
Hide Signatures
       Post #: 16
RE: building an model for as level design technology. n... - 9/14/2011 6:42 PM
scottydog10111
Score: 100
Status: offline
thats a big hand lnewqban! thanks!
also i have looked around and found the great planes elctrifly electricub kit 58.75"
is this a good kit? i have access to pretty much most of the tools needed in the workshop
Hide Signatures
(in reply to Lnewqban)
       Post #: 17
RE: building an model for as level design technology. n... - 9/14/2011 6:44 PM
MinnFlyer
Score: 390
Status: offline
Yea, anything by Great Planes is good
Hide Signatures
       Post #: 18
RE: building an model for as level design technology. n... - 9/14/2011 7:36 PM
All Day Dan
Score: 156
Status: online
These should help. Dan.
Click for fullsize
Click for fullsize
Click for fullsize
Dan
Hide Signatures
       Post #: 19
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.535RCU1
