minimadster -> The mini everyone has always wanted, losi 1/14th 8ight (9/15/2011 6:06 PM)
This the mini we have all been waiting for, Big suspension, speed, fourwheel drive, and 250 bucks, maybe even better than anything else outthere, you decide Based upon the ROAR-Championship-winning 8IGHT™ buggy, this brushless-powered prodigy is the ultimate mini buggy. Its 1/14-scale size allows it to handle tougher terrain while mastering the outrageous power and speed from the brushless system. Better still, the Mini 8IGHT comes with everything you need to get started, including transmitter, rechargeable NiMH battery pack and charger. Experience the thrill of driving a Mini 8IGHT today. Features: Water-resistant brushless ESC 4500Kv brushless motor Spektrum SR300 receiver with 2.4GHz DSM technology 7.2V 1100mAh NiMH battery pack with EC2™ connectors 4WD shaft-driven drivetrain Front and rear metal gear differentials Mini servo with saver Aluminum, threaded oil-filled, coil-over shocks Heavy duty, 2.5mm anodized aluminum chassis Mini Kingpin™ treaded tires 2.5mm aluminum shock towers 12mm wheel hexes Aluminum motor mount Heavy-duty adjustable turnbuckles Chassis dirt guards Product Specifications Type: 4WD Buggy Scale: 1/14 Length: 11.49 in (292mm) Width: 8.03 in (204mm) Height: 4.33 in (110mm) Wheelbase: 7.32 in (186mm) Weight: 2.15 lb (0.98 kg) Chassis: 2.5mm anodized aluminum Tire Type: Kingpin™ Buggy Motor or Engine: 4500Kv brushless motor Speed Control: Brushless Radio: 2.4GHz DSM® Technology Batteries: 7.2V NiMH with EC2™ connector Kit/RTR: RTR Shock Type: Aluminum, threaded, oil-filled Ball Bearings: Complete Minimum Age Recommendation: 14 years LOSB0224 – $249.99 Pictures and info from Rc Car Action, article done by Trevor "Chilly" duncan
