Crashed Fei Bao Hawk
FL
Hi all,
In july my FB hawk 120 size crashed, after only 7 flight. Powerbox royal with 2 receivers and batteries, ev5u pro valve going to trash. Turbine i sent to serivce and repaired it cost for $1110.
Why? Because FB Sale trash for $2k.
FB put in the stabilizer soft aluminium rod, the right side rod was bent back during flight and a back side of stab sit a fuselage in Up position. Plane is going down with rolling, radio and turbine work fine.
So i write to FB and i sent stab pics. Problem discussion lasted rather long, because Catherine translated my messages for his boss one week it is not dependent on the size message 10 words or 100, all the same.
I understand FB can't compensate all my loss, but though to send new plane after resolve problem with materials. It's Ok.
FB have found a heap of not clear arguments what not to recognize the fault, and have suggested me to buy the same plane from 50% a discount.
But after i found from my friend picture of my plane in air, where clearly visible right stab have other angle than left, FB stop answer me, i write 3 email after this, but not have any response from FB.
So in this moment I can tell Fei Bao is a worst company from all Chines manufacturers. When you look for buy any plane from Fb, please
think once again, probably you will save some hundred of dollars, but can lose some thousand like me or other many people in this forum who have crash fb plane from for bad quality. And not reseive any compensation from this worst company.
RE: Crashed Fei Bao Hawk
I am prepared to elaborate on the reasons I make the following statement, but I would prefer not to unless I am pressed.
I have found dealings with FeiBao through Catherine to have been at the very least exemplary. Can I at this point urge you to re-establish relations with the company and perhaps re evaluate your approach to this unfortunate incident for which you have my sympathy.
m
m
gab,
Sorry to hear of your problems. I've built five FB jets and other than the weak gear mounts in the P60 sized F-5, have had a lot of luck with them and have gotten good support from Catherine and the factory.
I hear that the FB Hawk has issues as Bevar will testify. Check out posts #1 and #2 in this thread.
[link=http://www.rcuniverse.com/forum/m_9758010/anchors_9758910/mpage_1/key_/anchor/tm.htm#9758910]http://www.rcuniverse.com/forum/m_9758010/anchors_9758910/mpage_1/key_/anchor/tm.htm#9758910[/link]
I wish you well and hope you get back in the air soon.
Jim
Jim
My Feedback: (86)
ORIGINAL: AndyAndrews
Jiffy Pop anyone?
Jiffy Pop anyone?
Rex
My Feedback: (41)
[]Sorry for your loss. Nobody uses aluminum stab pivots on that size plane!! I have a" GLOBAL JET CLUB T-45 PRO ARF" {SKYMASTER} for sale or trade. Has new wing design,votex generaters,squar tips,washout,fences. Never flown. just taxi. Red -white. Just add power...$1700.00 Also have new KINGTECK K-80 for it..
My Feedback: (24)
TX
Jet Legend argued for 5/6 months that their F-20 had no design problems. Well, guess what, it did. Continued pressure in this forum finally made them step up and address the problem but all that crashed still lost hundreds or thousands of dollars on turbine repair or replacement as well as all the radio/servo damage. No more for me!
Rob Puetz
F15driver
Rob Puetz
F15driver
ORIGINAL: rbxbear44
Oh boy...sequels and reruns!!! Hey, all you guys that were into jets when Kingcat booms were breaking, CARF $10k Kit Mig gears were not working and SM was having major issues...I don't remember the Forum being like this then? I do remember when SM Hawks were falling out of the sky with Stab issues, FB L-39's were fluttering bad and their MB339 Nose was falling off...there was some of this. Or, are we in a new era?
Rex
Jiffy Pop anyone?
Jiffy Pop anyone?
Rex
But this is just my observation over the past few months. I am positive there are factory issues that cause some but with the mass amounts of knowledge on the web about models you should know what to expect, unless your getting the very first. Only a few companies that build these things and you have to deal with it or fly something different. I would love to find some American made stuff myself but nobody in the states makes the stuff I like in the size I like. Im sure if my jet falls apart in the air I will be mad as well, but I did the research and picked my jet for my own reasons so its ultimately my own fault. This is just thoughts and opinion so they don't matter.
My Feedback: (27)
The FB Hawk is a piece of garbage. It's poorly designed, constructed and guess what...all of them crash. Either a wing blows off, the stabs fail or it just snaps...it's a real POS.
FB has known about it's problems since Tam sold them over 5 years ago and they have done nothing to correct the issues, other than slap fancy paint jobs on them and sell more of them.
Beave
Beave
ORIGINAL: FenderBean
I'm starting to wonder if its the airframes or pilot error? From all the reading and hate fest I have seen these past few months there are people flying the same models with no issues at all. Then someone who is looking to vent after losing mass amounts of money needs something to blame.
ORIGINAL: rbxbear44
Rex
Jiffy Pop anyone?
Jiffy Pop anyone?
Rex
I saw a new Fei Bao F5 collapse in the air at KY Jets. I believe it was David Jackson's. Cause determined was no crossover support on the former between the fuse, above the wing tube. Jed noticed that his didn't have this support either and immediately fabricated one in the field for his F5 which has had tons of flights on it. I guess he has been lucky.
My Feedback: (44)
As it so happen...I have photos...
Unfortunately David's F5 "Folded like a cheep Suite"
I do believe that Mike from Global Jet Club steped up and helped David out even though David purchased the Jet elsewhere. Mike is a first class act!
After that I gave Jed some 1/4" plywood and he went to town making a cross over brace!
Yep, that was really great of Mike from GJC to help David. It was a really nice looking plane and I was sorry to hear the boom it made (I was flying at the time) when it came apart in mid-air.
Rich, please stop posting that close-up picture of Jed. I'm barely over the nightmares from the last time you posted it
Jim
Jim
