Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
Reload this Page >
UMS Evolution Radial Care and Operation
Old 09-18-2011, 04:21 PM
Maxam
My Feedback: (62)
Default UMS Evolution Radial Care and Operation
Last April at the Toledo Show I was walking near the Horizon hobby area and spotted a bunch of radial engines that looked like my UMS Seidel engines. I said "hey I have all the glow versions of these engines". I met Pete Bergstrom who is overseeing the import and development of these engines! Great, now there will be a place where we can get parts and support in the US. These engines are said to be available in November and will be branded under the Evolution label. The displacements will be increased from 70 cc and 90 cc to 77 and 99 cc respectively.
My name is Tom Maxam and I have been modeling since around 12 years old. I am currently 52 so, wow around 40 years. I ran gas and electric boats including competition electric with Ed Hughey as a mentor. Within a year of starting RC airplanes I went totally for the 4 cycle engines. I am up to 43 of them including six radials! I have a Hangar 9 corsair with 400 flights on it powered with a Saito 90 R3. I also have a 50cc Yak 55SP powered with a Saito 325 R5. When the UMS Seidels came out I had to have one. The first one was the 7-70 which I bench ran extensively to learn how to tune it and understand the quirks. Later I acquired a 9-90 and finally the 7-35. I soon discovered these are not paperweights but reliable solid engines that can be flown heavily. I am also quite experienced with the Moki 150 and 215 cc radials and have learned how to make them run well.
The goal of this thread is to discuss all aspects of the care and operation of these engines to help others realize success. Topics will include fuel, Ignition, tuning, valve adjusting, cooling, prop selection, preventing hydraulic lock, fuel pressure tapping and after run oil and corrosion protection. Pete Bergstrom from Horizon has agreed to occasionally contribute to this thread.
I currently have the 7-70 in a 91 inch corsair. It weighs 20 pounds and flies magnificently. The 9-90 is in a restored Robin Hood 99. Both planes have over 50 flights. The engines are showing no wear.
OldBill (08-02-2020)
Old 09-19-2011, 02:08 AM
nilsreinert123
Default RE: UMS Evolution Radial Care and Operation
This is an interesting topic! I have one question regarding those engines, i have read that the 7-70 run fine without glow support, what is it with this engine that makes it so reliable without glow? I am wondering since i have a ASP 400 which runs terrible without glow support !
jfassino (05-08-2020)
Old 09-19-2011, 02:48 AM
Maxam
My Feedback: (62)
Nils, Good topic! The main reason I suspect is the much lower oil content. You are going from 16 to 18% oil way down to 6 to 8% oil. Also these engines are supplied with OS type F glow plugs which are the best. I do not run on-board glow in any of my engines. The other day I flew my 9-90 on my Robin Hood 99 7 times and never lost a cylinder!
Old 09-19-2011, 09:34 AM
Linkan2
Hi
I have a UMS Seidel 7-35 who have worked very well, no problems in the air at all.
I have 23 flights passes and it has not been any problems yet.
But I'll probably buy a set of ring for the exhaust.
I am very pleased with the engine so far
Lars
Old 09-19-2011, 03:14 PM
Maxam
My Feedback: (62)
Thanks for your post Lars. You might show pictures. I need to figure out how to post pictures myself!
I would like to discuss correct propellors for these Engines. When the 7-35 was released last year the top recommended rpm was a ridiculously slow 5200. The engine would be loaded down severely at that rpm and less than 1 hp would be developed! An APC 17x8 was turned at about 7000 and a Xoar 17x8 wood was about 6500. The Xoar has a larger hub size which matches the prop driver perfectly. The engine ran well at these speeds. The early carbs had to have a rich idle setting or else the mid to full range would be too lean regardless of high speed needle settings. The new carbs will address this. Notice these engines have an under square stroke to bore ratio along with minimal valve overlap. This translates into ideal loads at lower rpms. The 7-70 on my 91 inch corsair turns a 22x10 3 blade warbird Xoar prop at 4500 rpm. There is no detonation and the engine runs quite cool! As mentioned it flies this plane with authority. I take off at half throttle. A two blade prop should be around a 22x12. Some of you might say why the high pitch? This is not high pitch for this diameter. A diameter to pitch ratio should be around 2:1 or more for improved aerodynamic efficiency. Many people say I have a slow WW1 plane, well throttle back and it will fly well and the engine will sound more realistic. 3D is where low pitch props with great diameter work well due to the high thrust at near zero speed. Increase speed with these props and the aerodynamic efficiency drops dramatically. My 9-90 swings a 24x12 at around 5800 rpm and hauls the 24 pound Robin Hood strongly. The plane will fly at 1/4 throttle with added up trim very slowly and sound outrageously realistic! Cannot do that with low pitch. I do experiment with many props. My Saito 90 r3 and 325r5 have a very over square stroke to bore ratio. This translates into developing power at much higher rpms. The 90r3 can only turn a 13x7 with out overloading and loosing performance. The 325r5 is suffering with anything above a 20x10. That is the advantage of these engines from UMS. They can turn the larger props and be in their ideal operating range, look more scale and enjoy the efficiency gained from larger props spinning more slowly. Think about the P51 and corsair etc. (full size) They have gearboxes in front of the engine that drops rpm, increasing torque so they could turn those huge props with high pitch for increased performance.
Recall the newer engines have greater displacements so the props might have to be bigger and/or have even courser pitch than before.
-Tom
Old 09-20-2011, 05:35 AM
Maxam
My Feedback: (62)
I noticed a number of people have viewed this thread. Do you guys and gals have a UMS Seidel already? What are your plans for these engines. Let us know about your projects! Dont have a radial yet? Let us know what you want to put one in. Do you have worries about owning one and being able to run it and take care of it. Speak up! Lets keep this fun.....Tom
Hey Pete lets get these guys fired up. How about putting that picture from the recent ad in Model aviation in here. Very sharp!
Old 09-20-2011, 07:22 AM
Pete Bergstrom
Tom,
Thanks for taking this on. I am attaching the photo you spoke of. Your mail must be faster than mine because I haven't seen the ad yet. I'll also add to this thread later with some build pictures from the Seagull 1.20 size AT-6 I mounted the EVO 735 radial in, complete with our new collector ring. Sounds great and certainly keeps a bunch of the mess of the airplane!
Pete
Old 09-20-2011, 08:19 AM
Linkan2
Hello all engines fans
I have flown my best 7-35 with 18x8 prop from menzs wood.
now from Graupner 18x8 "G-Sonic" looks like APC, but cheaper, rpm 6800th
My PT 17 Stearman weighs 6.5 kg and there is no problem at all, is power over.
I've tried the 18x10 but there was nothing good flying weather, so I'll be back with the test
Lars
Old 09-20-2011, 08:38 AM
Pete Bergstrom
Here's a picture of the AT-6 with EVO7-35 and collector ring. BTW - I've test flow APC 16 x8, 16 x 10, 17 x 8, 17 x 10, 17 x 12, 18 x18, and 18 x 10 on this airplane. The best combination of load, pitch speed and aircraft speed for this plane is the 17 x 10 prop. turns about 6,800 rpm and provides a nicely manageable realistic airplane speed with the climb power as what you would expect of an AT-6. Very realistic in flight and because of this I did very well at the Bob Evan's Fun Scale event in August with this combination.
Pete
Old 09-20-2011, 09:41 AM
Maxam
My Feedback: (62)
All, Very embarrassing but how do you post pictures from another file on your computer? Thanks -Tom .................OK figured it out!
Old 09-20-2011, 03:02 PM
Maxam
My Feedback: (62)
I think I figured it out! Here are photos of my corsair and Robin Hood 99. -Tom
ID:	1664808   Click image for larger version
ID:	1664809   Click image for larger version
Old 09-21-2011, 09:29 AM
Linkan2
ok can any of you help me to post pictures please
Lars
ps I have many pictures
Old 09-21-2011, 11:39 AM
Kmot
My Feedback: (24)
Kmot's Avatar
Your planes look awesome Tom, full of radial engine up front!
Old 09-21-2011, 12:10 PM
Maxam
My Feedback: (62)
Lars, Below the message box you will see upload files. Do that before typing. Click on the one that says image. You will then get a prompt to choose file and your photo's should come up and then select the ones you want. Hope it works! -Tom
Old 09-21-2011, 12:24 PM
Maxam
My Feedback: (62)
Thanks Tom. They are fun to fly. I want to put the 7-35 in a Sig Waco SRE. -Tom
Old 09-22-2011, 10:08 AM
Linkan2
Enter the URL of the link?????
Lars
Old 09-22-2011, 10:32 AM
Pete Bergstrom
You have to hit "reply" first. Then the easiest way is to go to the "Click here to upload images and files!" link and a box will appear with 12 lines with a browse tab next to them. Click on the browse tab and your computer files will come up. Choose the correct image file you want and either double clik the file or select it and click open. That file location will be loaded to the images list. When you have added all the images you want hit OK at the bottom of the box. RCU will then upload those images from your computer. Sometimes this can take a while so be patient until you see a response screen. Occasionally it will tell you the total file to upload is too large so you'll have to start over again with either smaller picture files or fewer images per upload.
I am far from a computer expert but I have been making this work for me just fine. Good luck and we look forward to seeing your pictures!
Pete
Old 09-22-2011, 11:33 AM
Linkan2
Old 09-22-2011, 11:34 AM
Linkan2
Ha Ha yes fixit
Lars
Old 09-22-2011, 11:37 AM
Pete Bergstrom
Beautiful airplane!
Old 09-22-2011, 11:40 AM
Linkan2
ID:	1665407   Click image for larger version
Old 09-22-2011, 03:33 PM
Maxam
My Feedback: (62)
Lars, Thank you for the great pictures. That engine looks to be just the right size for that plane. I bet that Stearman loves the near zero vibration. Pete thanks for your better directions helping Lars.
My topic for today has to do with corrosion prevention. I do like running my radials on 8% oil and 7% nitro. That is part of the reason I do not use one-board glow power. When I am finished for the day I will start the engine after the tank is drained and let it quit on its own. I will then start it again and it will run a bit and quit. I will do this until it will not fire. Now I know there is no residual fuel in the engine. Now I remove one of the top pushrods and the follower so I have a hole directly over the cam ring and the rear main bearing. Into that hole I squirt about 10 ml of air tool oil chased with 2 ml of Evolutions Blue-block. I put the follower and the pushrod back and turn the prop over 3 to 5 times. The engine several days later is still creamy smooth indicating no corrosion. A major discovery I found. DO NOT use exhaust back pressure. The exhaust has highly corrosive effects on the engine. The carbs on these engines have plenty of draw if the tank is at the correct height and close to the engine. -Tom
Old 09-24-2011, 12:41 AM
sprakash60
Dear Mr.Pete
This is Prakash from UMS. Thankyou very much for coming down here and spending some time with us.
Another thanks for testing the Evolution 7-35 on Piper J3.Hope you enjoyed the flight like us.
Its unfortunate that we didnt fly the YAK54, due to glitch. When I analysed the cause later, it turned out to be the interference from Iphones ,you and Mr.Gopal was having. When I first range tested the Cub , you were away in discussion with Mr.Gopal. But for the YAK you were near. So its a lesson for us who are using 35 Mhz sets- to switch off mobile phones when flying.After that I tested all receivers without the glitch.
Mostly this weekend I may fly the YAK. I will send photos later.
Kindly reply[email protected]
Old 09-25-2011, 05:26 AM
Linkan2
Hey Tom
There way to rust protection your engine is in prinsip same as I do.
I have 6% oil 0 nitro got on board glow.
Now it is autumn here and near the end of flygsesongen.
Lars
ID:	1666014   Click image for larger version
Old 09-25-2011, 07:48 AM
nilsreinert123
Can these UMS radials be run well on regular 15/15 fuel? here in Norway it is impossible to buy pure methanol.. I have been considering a 7-70 but need to run it on regular 15/15 fuel.
