RE: UMS Evolution Radial Care and Operation    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: UMS Evolution Radial Care and Operation
Page: <<   < prev  22 23 [24] 25 26 27 28 29 30 31   next >   >>
Login
RE: UMS Evolution Radial Care and Operation - 9/25/2012 1:01 AM
Maxam
Score: 100
Last Login: 5/25/2013
Status: offline
I have a local chemical company who sells methanol for racing engines, and dilute 1:1 16% oil 15% nitro glow fuel. The engine will run fine on normal fuel like this but will be messy.
Hide Signatures
(in reply to skypup50)
       Post #: 576
RE: UMS Evolution Radial Care and Operation - 9/25/2012 1:47 AM
skypup50
Score: 100
Last Login: 12/13/2012
Status: offline
quote:
ORIGINAL: Maxam
Getting methanol is my only concern and may drive me towards the os 160 twin. I've found a company that sells methanol and they make all kinds of fuels here in San Antonio. They mention that you should use it in a short period of time (2-3 weeks) and if it is not in a steel drum it will deteriorate quickly. They also talk about different grades of methanol M1,M3 and M5. All this is new to me. Guess I have a lot to learn. I don't mind mixing the fuel so long as I have a reliable source of methanol. Some info here:
http://www.vpracingfuels.com/racing-fuel
Hide Signatures
(in reply to Maxam)
       Post #: 577
RE: UMS Evolution Radial Care and Operation - 9/25/2012 2:37 AM
skypup50
Score: 100
Status: offline
I have found that r/c car fuel only runs about 9% oil. Would this work?
http://www.amainhobbies.com/product_info.php/cPath/1575_67_766/products_id/233398/n/PowerMaster-Nitro-Race-20-Car-Fuel-9-Castor-Synthetic-Blend-Six-Gallons
Hide Signatures
       Post #: 578
RE: UMS Evolution Radial Care and Operation - 9/25/2012 2:44 AM
skypup50
Score: 100
Status: offline
They also make a touring car fuel with 16% nitro and 9% synthetic/castor. Is castor a no no?
http://www.amainhobbies.com/product_info.php/cPath/1575_67_766/products_id/233410/n/PowerMaster-Nitro-Race-16-Touring-Car-Fuel-9-Castor-Synthetic-Blend-Six-Gallons
Hide Signatures
       Post #: 579
RE: UMS Evolution Radial Care and Operation - 9/25/2012 2:56 AM
Heli-NuBee
Score: 100
Status: offline
I forgot to mention that I follow maxam's suggestions about using after run oil in my UMS Evolution 777 radial engine. I have not been able to get after run oil locally so I have been using air tool oil and it seems to be working OK. I insert a medium sized siringe of air tool oil in one of the top lifter ports and drain the oil out of one of the lower lifter ports. Of course the lifters and valve push rods have to be removed first. I do this after each day's running. I turn the engine over during the oiling process to ensure that all of the bearing surfaces receive oiling. I also reoiled the valve train after 1-1/2 hours of break-in running. The valve train still seemed to be OK but I wanted to be sure that it was adequately lubricated before the maiden flight. Maxam (Tom) has been invaluable to me in the radial engine learning curve. I can't say thanks enough to him for his help. As far as the fuel thing goes, we are lucky in this area because the local motorcycle shops sell Klotz oil and the speed shop sells methanol. I mixed my own straight methanol and oil at 10% for break-in. I then took Omega 10% nitro fuel with 18% oil from the LHS and mixed it with one half methanol to end up with 5% nitro and 9% oil for flying. That seems to be the easiest way to get a good fuel mix for me.
Roger the Radial Rabbit
Hide Signatures
       Post #: 580
RE: UMS Evolution Radial Care and Operation - 9/25/2012 3:02 AM
skypup50
Score: 100
Status: offline
quote:
ORIGINAL: Heli-NuBee
How much do they charge for the methanol?
Hide Signatures
(in reply to Heli-NuBee)
       Post #: 581
RE: UMS Evolution Radial Care and Operation - 9/25/2012 9:53 AM
Pull Up Now!
Score: 140
Last Login: 5/22/2013
Status: offline
quote:
ORIGINAL: skypup50
I don't think 100% of the oil being castor is recommended. I'd be concerned about valve deposits eventually keeping them from closing.
Hide Signatures
       Post #: 582
RE: UMS Evolution Radial Care and Operation - 9/25/2012 11:09 AM
Maxam
Score: 100
Status: offline
Buy the purest methanol (99.9%) pure. It will keep for months in a plastic sealed container. Going bad in two weeks is ridiculous.
Hide Signatures
(in reply to Pull Up Now!)
       Post #: 583
RE: UMS Evolution Radial Care and Operation - 9/25/2012 12:05 PM
skypup50
Score: 100
Status: offline
quote:
ORIGINAL: Pull Up Now!
quote:
ORIGINAL: skypup50
They are actually saying castor/synthetic but don't give the ratio.
Hide Signatures
       Post #: 584
RE: UMS Evolution Radial Care and Operation - 9/25/2012 12:06 PM
skypup50
Score: 100
Status: offline
quote:
ORIGINAL: Maxam
I'll need to find a source. How much are you paying for the methanol?
Hide Signatures
(in reply to Maxam)
       Post #: 585
RE: UMS Evolution Radial Care and Operation - 9/25/2012 12:31 PM
Maxam
Score: 100
Status: offline
With a credit card! I just drive up th the methanol pump and buy like gasoline!
Hide Signatures
       Post #: 586
RE: UMS Evolution Radial Care and Operation - 9/25/2012 12:40 PM
Dad_Roman
Score: 100
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: skypup50
Most dragster guys have it i thier shop. The dragstrip will have it.
I have recently found it on the shelf prepackaged at the Oilfield Supply store. In my area there is a store called "Jett" they probably have one by you too since most of the oilfield has moved south.
Its 99.6 percnt pure I believe if not better. If I remember its about 45 bucks for a 5 gallon jug.
_____________________________
AMA# 134406
Hide Signatures
       Post #: 587
RE: UMS Evolution Radial Care and Operation - 9/25/2012 1:43 PM
Pull Up Now!
Score: 140
Status: offline
This is Minnesota. Around here, dragster guys are people who buy ladies clothes at the crossover shop.
Hide Signatures
(in reply to Dad_Roman)
       Post #: 588
RE: UMS Evolution Radial Care and Operation - 9/25/2012 4:20 PM
skypup50
Score: 100
Status: offline
quote:
ORIGINAL: Dad_Roman
quote:
ORIGINAL: skypup50
I have recently found it on the shelf prepackaged at the Oilfield Supply store. In my area there is a store called ''Jett'' they probably have one by you too since most of the oilfield has moved south.
Thanks. Tried there and no answer. Still looking. Thanks for the help. I'm not sure if depending on someone to sell this stuff is a good thing when spending $1100.00 on an engine. It kind of scares me. The OS 160 twin would run on stuff I actually have on hand and is easy to get. Any other alternatives? How about denatured alcohol? The radial would be sooo cool.
Hide Signatures
       Post #: 589
RE: UMS Evolution Radial Care and Operation - 9/25/2012 5:24 PM
pappy 883
Score: 100
Last Login: 5/24/2013
Status: offline
Try your local petrol jobbers . thats where i found some out here ,5 gal. for $36.00
____________AIRSPEED IS LIFE_____________
Hide Signatures
       Post #: 590
RE: UMS Evolution Radial Care and Operation - 9/25/2012 6:15 PM
skypup50
Score: 100
Status: offline
I found a source. VP fuels is within an hour of my home and would be willing to sell a 5 gallon container. What brand fuel are you guys mixing with it? Thanks!
Hide Signatures
(in reply to pappy 883)
       Post #: 591
RE: UMS Evolution Radial Care and Operation - 9/25/2012 6:17 PM
Maxam
Score: 100
Status: offline
My gosh folks, I get it for 4$ a gallon! Thank you Jefferson chemicals on the south side of Indianapolis! Sorry you have such a struggle to get the stuff.
Hide Signatures
       Post #: 592
RE: UMS Evolution Radial Care and Operation - 9/26/2012 8:32 PM
skypup50
Score: 100
Status: offline
I'm wondering what to do initially for bench running my 7-35 next month? In terms of electrical power requirements should I get a 7 cylinder Macdaniels system from the get go or just build a 1.2 volt pack? After break in the engine will not be used until my scale model is complete.
Hide Signatures
(in reply to Maxam)
       Post #: 593
RE: UMS Evolution Radial Care and Operation - 9/26/2012 8:35 PM
Maxam
Score: 100
Status: offline
Skypup. Please read the earlier posts. I have provided much info that will help you. -Tom
Hide Signatures
       Post #: 594
RE: UMS Evolution Radial Care and Operation - 9/26/2012 9:35 PM
skypup50
Score: 100
Status: offline
quote:
ORIGINAL: Maxam
I already have. Great memory! I'll go back and read again.
Hide Signatures
(in reply to Maxam)
       Post #: 595
RE: UMS Evolution Radial Care and Operation - 9/26/2012 10:09 PM
skypup50
Score: 100
Status: offline
quote:
ORIGINAL: BeasleyBunch
Joel, looks like we were running the same errands today!  I stopped by Hyperfuels and picked up a gallon of 99.95% methanol.  Also placed an order for the after-run Blue Block…thanks Tom and Pete for that one!  And used some scrap lumber to build, what I think, is a bullet proof engine stand.  For size reference, that’s a 12 inch ruler attached to the square.  Still have to finish the platform for the fuel tank, mounting config and misc other items...
I'm glad to find out about hyperfuels. I can order smaller quantities and not have to drive from San Antonio to Houston and back. It's worth the shipping charges in fuel and time! Wasn't quite sure what to do with the extra methanol if I was required to buy 5 gallons. Great find.
Hide Signatures
(in reply to BeasleyBunch)
       Post #: 596
RE: UMS Evolution Radial Care and Operation - 9/26/2012 10:12 PM
skypup50
Score: 100
Status: offline
Tom
If I make up a nicad pack for testing my engine, what connection do I need on the battery to mate with the engine harness? Thanks in advance.
Hide Signatures
       Post #: 597
RE: UMS Evolution Radial Care and Operation - 9/26/2012 10:17 PM
Maxam
Score: 100
Status: offline
First you need to make a battery pack that can dump 40 amps such three 3.5 amp hour nicads in parallel and use 12 or 13 gauge wire. I like the type N concentric connector and socket from radio shack. Keep wires short and thick!
Hide Signatures
       Post #: 598
RE: UMS Evolution Radial Care and Operation - 9/26/2012 11:32 PM
skypup50
Score: 100
Status: offline
quote:
ORIGINAL: Maxam
Thanks. I'm trying to understand what the end of the cylinder ignition harness looks like when you get the engine? Does it have a battery connector installed? Thanks!
Hide Signatures
(in reply to Maxam)
       Post #: 599
RE: UMS Evolution Radial Care and Operation - 9/26/2012 11:34 PM
Maxam
Score: 100
Status: offline
It has banana plugs
Hide Signatures
       Post #: 600
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: UMS Evolution Radial Care and Operation
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.609RCU1
