RE: Thorpe F-20 build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Thorpe F-20 build
Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: Thorpe F-20 build - 1/25/2012 11:31 PM
picard1
Score: 100
Last Login: 5/19/2013
Status: offline
Great to here Pete is doing well...
Any chance of Sending me Pete's phone number via PM. I sure could use a canopy.
Hide Signatures
(in reply to fire.42)
       Post #: 176
RE: Thorpe F-20 build - 1/25/2012 11:38 PM
Love To build
Score: 110
Status: online
Thanks Dave. Keep us advised on the parts. I could use some canopys for a F104 and the F20. Maybe he would like to set up a distribution entity in the US for plans and plastics.
< Message edited by Love To build -- 1/30/2012 4:28 AM >
Hide Signatures
(in reply to picard1)
       Post #: 177
RE: Thorpe F-20 build - 6/20/2012 3:21 AM
tlj125
Score: 104
Last Login: 5/18/2013
Status: offline
OK. So now back to the F-20. Had a pipe left over from a Yellow Starfire that never got used. Cut it down with a dremel tool with cutoff wheel. Then made L shaped brackets from the cutoff piece.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Love To build)
       Post #: 178
RE: Thorpe F-20 build - 6/21/2012 11:07 AM
tlj125
Score: 104
Status: offline
Wheels and brakes came in. Made a combination engine/ pipe mount and worked to get it lined up and true to the plane.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to tlj125)
       Post #: 179
RE: Thorpe F-20 build - 6/22/2012 10:47 PM
tlj125
Score: 104
Status: offline
A few more pics of the engine and pipe mounting...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 180
RE: Thorpe F-20 build - 6/23/2012 2:37 PM
tlj125
Score: 104
Status: offline
Didn't like mounting the pipe under the motor mount so I added a doubler to put the screws in from the top. Will also give more for the engine mounting screws to go into.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 181
RE: Thorpe F-20 build - 6/23/2012 2:43 PM
tlj125
Score: 104
Status: offline
Started digging out the mounts for the retracts. Used dimension from the plans and made a starter hole with a dremel tool and sanding drum. Then made the hole bigger until I could determine where I was at. Saves making the wheel opening for last. Retracts are Spring Air 5/32 wire struts. I ordered 3/16 but received 5/32. Oh well. I am sure they will work.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 182
RE: Thorpe F-20 build - 6/23/2012 2:47 PM
tlj125
Score: 104
Status: offline
Then dremel out for the wheel wells...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 183
RE: Thorpe F-20 build - 6/23/2012 2:51 PM
tlj125
Score: 104
Status: offline
A few final touches, sanding here and there for clearance and free retact motion and done...
Click for fullsize
Hide Signatures
       Post #: 184
RE: Thorpe F-20 build - 6/23/2012 3:46 PM
tlj125
Score: 104
Status: offline
The front retract was more difficult. Since I wanted to use the sigle side steering version, the rails are higher. This created an interference with the servos and the wheel when retracted. Had to relocate the retract twice before finding a position that didn't interefere. It is close but it will work.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 185
RE: Thorpe F-20 build - 6/23/2012 3:50 PM
tlj125
Score: 104
Status: offline
The F-20 standing on its new legs. Notice the slight positive angle of attack for the wings.
Click for fullsize
Hide Signatures
       Post #: 186
RE: Thorpe F-20 build - 6/23/2012 6:03 PM
thunderchief
Score: 100
Last Login: 2/28/2013
Status: offline
Terry, Looks great............keep on it.
Glenn
Hide Signatures
       Post #: 187
RE: Thorpe F-20 build - 6/24/2012 3:44 AM
tlj125
Score: 104
Status: offline
Thanks Glenn. Opened up the bulkhead to fit a 24 oz Kavan fuel tank. Used a dremel tool with a sanding drum.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to thunderchief)
       Post #: 188
RE: Thorpe F-20 build - 6/24/2012 3:49 AM
tlj125
Score: 104
Status: offline
Used a piece of balsa to act as a support for the tank to keep it from tilting down in the back. The air tank will go above the tank and keep it from tilting up in flight.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 189
RE: Thorpe F-20 build - 6/24/2012 3:56 AM
tlj125
Score: 104
Status: offline
Added a plywood support for the back of the pipe to attach to. Glued in with 20 min epoxy. The screw is a #4 wood screw and washer. Redrilled the screw holes for the front tabs of the pipe so the #4 screws tighten from the top. The three screws hold the pipe very well. No additional support should be needed.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 190
RE: Thorpe F-20 build - 6/25/2012 2:34 AM
tlj125
Score: 104
Status: offline
Cut and glued in servo rails for the retract and steering servos. Then mounted the servos.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 191
RE: Thorpe F-20 build - 6/25/2012 2:38 AM
tlj125
Score: 104
Status: offline
Made a support for the air valve from a plastic control horn. Mounted it to the servo rails and connected it with 1/16 wire to the servo control horn. Started plumbing the air lines to the retracts.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 192
RE: Thorpe F-20 build - 6/26/2012 11:06 AM
tlj125
Score: 104
Status: offline
Ran the airlines to the retracts. Kept them tucked in and out of the way by drilling small holes to run the lines through. Had to add one restictor in the line to slow the retracts.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 193
RE: Thorpe F-20 build - 6/26/2012 11:13 AM
tlj125
Score: 104
Status: offline
Drilled the clearance hole for the steering wire through the bulkhead by hand. Couldn't get in there with a drill. Pretty tight. Started with a 1/16 then opened up to a 3/16. Soldered a threaded coupler onto a 1/16 wire. This will be the end that attaches to the retract steering arm.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 194
RE: Thorpe F-20 build - 7/1/2012 6:23 AM
tlj125
Score: 104
Status: offline
Added a brass piece to act as a guide for the steering rod. Put a few bends in the rod to make it move smoothly from the servo.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 195
RE: Thorpe F-20 build - 7/1/2012 6:29 AM
tlj125
Score: 104
Status: offline
Sanded the pod on the back of the vertical stab before sheeting the exhaust nozzle.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 196
RE: Thorpe F-20 build - 7/1/2012 6:36 AM
tlj125
Score: 104
Status: offline
Used some filler balsa around the exhaust nozzle to give more surface to glue the sheeting to. Sanded smooth with the last bulkhead and exhaust tube.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 197
RE: Thorpe F-20 build - 7/1/2012 6:42 AM
tlj125
Score: 104
Status: offline
Glued on some scrap balsa to act as a ledge for the 3/32 strips cut from sheet. A wider sheet just didn't want to wrap around the nozzle very well. Started gluing on the 3/32 strips.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 198
RE: Thorpe F-20 build - 7/2/2012 2:40 AM
tlj125
Score: 104
Status: offline
Finished gluing on the sheeting and started sanding the exhaust nozzle into shape.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 199
RE: Thorpe F-20 build - 7/2/2012 2:43 AM
tlj125
Score: 104
Status: offline
More sanding...
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.549RCU1
