RE: HPI Mini Recon    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> RE: HPI Mini Recon Page: <<   < prev  2 3 4 5 6 [7] 8 9 10 11   next >   >>
Login
RE: HPI Mini Recon - 12/22/2011 6:51 PM
thehuntingterminator
Score: 224
Last Login: 5/15/2013
Status: offline
i subbed to you on youtube. my name is the same on here as is there.
quote:
ORIGINAL: Atomika
A couple pix & vid of the latest mods to my MR
http://www.youtube.com/watch?v=0dAyyO2VUBU&context=C36e51b9ADOEgsToPDskLgbosEp-iunktK7nL0pWYy
_____________________________
- HobbyTownUSA Employee
- Writer for ModelKits.com & RcTruckStop.com
Hide Signatures
(in reply to Atomika)
       Post #: 151
RE: HPI Mini Recon - 12/23/2011 5:29 AM
Atomika
Score: 100
Last Login: 4/22/2013
Status: offline
@SyCo VeNoM
Sweet! I didn't know they made anything like that. That'll make it doing headlights much easier, smaller & more solid, Thanx.
@robjr1
I jus used some spare parts I had lying around. 2 "finger lights" I got in the $ isle at a grocery store, 2 wires, a piece of lexan, and a servo. I replaced the original servo with a metal geared one and used the stock one to do the lights with.
I'll make a vid showing how I made it here in the next day or so.
Jealousy is the tribute mediocrity pays to genius
Hide Signatures
(in reply to thehuntingterminator)
       Post #: 152
RE: HPI Mini Recon - 12/23/2011 6:17 AM
SyCo_VeNoM
Score: 621
Last Login: 5/23/2013
Status: online
quote:
ORIGINAL: Atomika
@SyCo VeNoM
yea someone in another thread asked if they would work, and when I saw it I was like hmm ordered 2, and rigged em up. Only wish I remembered where I put them (one was hooked to an ESC I REALLY need right now too...)
With great speed comes greater repair bills.
Look at my garage for my model list.
Hide Signatures
       Post #: 153
RE: HPI Mini Recon - 12/26/2011 9:44 AM
stevenkelby
Score: 100
Last Login: 5/3/2012
Status: offline
quote:
ORIGINAL: Atomika
Cool
Are these your shocks?
http://www.rchobbyexplosion.com/MEGATECH_MEGAPRO_ALUMINUM_OIL_FILLED_SHOCKS_4_p/mtpt-mp112.htm
Happy with them?
I have the shocks from a Losi mini 8ight and they are good but were a pain to fit to the Recon, a bit too long too.
Hide Signatures
       Post #: 154
RE: HPI Mini Recon - 12/26/2011 10:31 PM
SyCo_VeNoM
Score: 621
Status: online
Can say now RC18b arms fit the recon perfectly
so no $20 a pair HPI arms seeing there are aftermarket RPM RC18b arms cheaper
Shock tower still will probably have to get from megatech though still $7 aint that bad for a pair of towers
wish megatech just sold the aluminum shock towers separate from the "complete aluminum upgrade kit" seeing I don't want any of the other parts...
Now have to wait for my sedan RC18 conversion hub set to arrive, and I should be able to slap the mini slash rims on no issue (the conversion has spaces that should eliminate slop that was REAL bad with the traxxas hex's, and the distance from the axle hole in the rim itself)
Hide Signatures
(in reply to stevenkelby)
       Post #: 155
RE: HPI Mini Recon - 12/26/2011 10:50 PM
alexhunter
Score: 100
Last Login: 10/27/2012
Status: offline
 Does anyone know if the rc18 rear hub Carrier will fit the recon.  My kid broke one after 10 seconds of use Christmas morning.  I can't find a Hpi part in stock and can't find the megatech ones in Canada.
Hide Signatures
(in reply to SyCo_VeNoM)
       Post #: 156
RE: HPI Mini Recon - 12/26/2011 11:07 PM
SyCo_VeNoM
Score: 621
Status: online
quote:
ORIGINAL: alexhunter
just tried it doesn't fit right
it looks like it can be made to fit though the issue I see is the RC18b's has a little nub that prevents the suspension from going down farther if it was dremeled off (or maybe an after market version doesn't have it), and you put the RC 18's rear turnbuckles on it MIGHT work. the part will fit in the arm though, but its tight and causing binding which I'm attributing to the turnbuckle on the HPI being shorter than the RC18
Also shoot HPI an e-mail and say it broke after a day or 2 of use there is a chance they will send you a new part at no cost.
Hide Signatures
(in reply to alexhunter)
       Post #: 157
RE: HPI Mini Recon - 12/27/2011 6:35 AM
Atomika
Score: 100
Status: offline
@ stevenkelby
Yep, Those are the ones. I like em so far. They've been good for cruising around in parking lots thus far. It'll be awhile b4 I know if they're racing worthy as our 18 track is out of commission till spring. The fronts are significantly shorter than the rears. Drop test wise they bottom out at a much lower height than the stock ones.
Hide Signatures
       Post #: 158
RE: HPI Mini Recon - 12/28/2011 12:19 AM
stevenkelby
Score: 100
Status: offline
Thanks.
Is it bad that they bottom out sooner than stock? I would think it's better if they can take a bigger drop? I'd like the best shocks possible
Hide Signatures
       Post #: 159
RE: HPI Mini Recon - 12/28/2011 2:18 AM
SyCo_VeNoM
Score: 621
Status: online
quote:
ORIGINAL: stevenkelby
Thanks.
yes and no
you kinda want a happy medium
if the shocks are too rigid, and have too stiff of spring the arm, and shock tower will take most the force instead of it being absorbed by the shocks. Too soft, and you will hit the chassis too hard, and cause damage that way. The chassis slapping the ground isn't that bad if its not too hard
Hide Signatures
       Post #: 160
RE: HPI Mini Recon - 12/28/2011 2:36 AM
stevenkelby
Score: 100
Status: offline
quote:
ORIGINAL: SyCo_VeNoM
yes and no
Cool thanks. With the Losi mini 8ight shocks I have now, the chassis will not touch the ground at all, the shocks bottom out first, putting all the force through the shock mounts/shock tower. Not ideal at all. I broke a couple lower shock mounts/rod ends but have better quality ones coming from Ofna and Traxxas.
Would love a perfect fitting shock, might try some from 3 racing for the RC18 next.
Hide Signatures
       Post #: 161
RE: HPI Mini Recon - 12/28/2011 2:49 AM
SyCo_VeNoM
Score: 621
Status: online
I'm actually tempted to order that aluminum upgrade kit, and just pretend the arms don't exist. seeing I wanted aluminum arms, kuckles, c-hubs anyways $60 aint that bad after thinking how much I've dropped on a set of shock towers. I think I'll wait till the RC18 RPM arms come in the mail so I can make 100% sure the C-hubs, and rear carriers don't have fitment issues.
Hide Signatures
       Post #: 162
RE: HPI Mini Recon - 12/29/2011 4:32 AM
WWWracing
Score: 100
Last Login: 12/30/2012
Status: offline
hi im new to this and i was wondering if the Associated rc18b rtr would run well against the HPI Mini Recon rtr? What are the pros and cons comaring them to eachother? Which is faster? also this is all completely STOCK
P.S. is the rc18b any faster/better than the rc18t?
Hide Signatures
       Post #: 163
RE: HPI Mini Recon - 12/29/2011 5:41 AM
SyCo_VeNoM
Score: 621
Status: online
quote:
ORIGINAL: mracing1553
hmm RC18b will have better parts support, and has a ton of aftermarket parts available.
The recon has very limited parts support, and replacements if going through HPI honestly for a hand full of parts it cost almost as much as the truck itself.
Now if you go through Megatech, and get the megapro parts for replacements cost drops significantly. Also megatech has an aluminum upgrade kit that has most the parts in aluminum
Recon has 2.4ghz vs the RC18b's 27mhz AM
Recon also has the spur gear enclosed where the RC18 leaves it open (but an aftermarket cover is available)
speed wise the should be similar
Recon has a wider battery compartment where the RC18's is a little more narrow (narrow enough to where my lipo won't fit at all...)
same RC diff tires, buggy has a wing, and body is diff
Hide Signatures
(in reply to WWWracing)
       Post #: 164
RE: HPI Mini Recon - 12/29/2011 6:34 PM
WWWracing
Score: 100
Status: offline
 so who do u think would win? becuase my friend got the mini recon and i want to be able to race him and have it be fair and fast
Hide Signatures
       Post #: 165
RE: HPI Mini Recon - 12/29/2011 8:50 PM
SyCo_VeNoM
Score: 621
Status: online
the better driver
Hide Signatures
       Post #: 166
RE: HPI Mini Recon - 12/29/2011 9:47 PM
WWWracing
Score: 100
Status: offline
good thats exactly what i wanted...*hint*hint* btw which do u think is all around better: rc18b or rc18t? we will be racing on a bumpy street, but it should be able to go off curbs and drive over sticks/grass. Speed, handling, and off roading ability all included please. It should also be able to jump, but nothing serious (jumping over cars ect.). Thanks for the tips!
< Message edited by mracing1553 -- 12/30/2011 12:01 AM >
Hide Signatures
       Post #: 167
RE: HPI Mini Recon - 12/30/2011 1:59 AM
SyCo_VeNoM
Score: 621
Status: online
literally they are basically the same RC(wing, and bodies are the difference) just different tires. Pretty sure the tires are even the same exat size just different threads
Side not to get on topic got my RPM RC18 arms they fit pretty good BUT a few minor mods had to be done.
1st I had to enlarge the C-hubs hole cause the RC18 seems to use a larger pin on the C-hub than the recon. I also had to cut a new pin found out the clothing hangers I use the metal was the perfect diameter so I made 2 pins off a hanger Oddly the other side that goes to the chassis was the same size as the RC18's so no mods had to be done
I also had to make the hinge area on the C-hub a little thinner cause it was too tight in the arm. Outside those 2 things they fit great otherwise
Also got my 12mm hex hub kit, and wow this thing is nice
has a flange that brings the 5mm hole in the 12mm rims down to 3mm's perfectly, and has a nice offset so the rims are at the right position. Now wish I could find my 4th mini slash rim, and I would be set.
Also gotta order the replacement shock tower now that I know the arm replacement idea works to get it back up and running.
Edit: cause I hate posting 2 things back to back
Put the rear arms on. Had same issue I had with the front, and had to make a bigger hole, and a pin to hold the rear carriers in. Also ordered tamiya rally tires(was same price as a mini slash rim/tire), and the aluminum megapro upgrade kit so once those 2 come it will be fixed up and able to run
< Message edited by SyCo_VeNoM -- 12/30/2011 5:44 AM >
Hide Signatures
       Post #: 168
RE: HPI Mini Recon - 1/1/2012 6:38 AM
mjohnson55336
Score: 100
Last Login: 11/2/2012
Status: offline
Will a mip diff work out of a AE rc18t work in a HPI mini recon?
Hide Signatures
(in reply to Rcforme...)
       Post #: 169
RE: HPI Mini Recon - 1/1/2012 6:48 AM
mjohnson55336
Score: 100
Status: offline
I have a hpi mini recon and i just threw in a Dynamte Fuze brushless system in it. Any ideas on how to do the differentials so they wont blow up its an 8300kv motor. Any help is greatly appresheated.
Hide Signatures
(in reply to ozzy9039)
       Post #: 170
RE: HPI Mini Recon - 1/1/2012 7:23 AM
stevenkelby
Score: 100
Status: offline
quote:
ORIGINAL: mjohnson55336
Yes, but I had to scrape 0.8mm off the bearing housing on the lower diff casing, the MIP diff was too wide. The top cover on the Recon was 0.8mm wider than the bottom one, so it was perfect.
Hide Signatures
(in reply to mjohnson55336)
       Post #: 171
RE: HPI Mini Recon - 1/1/2012 9:10 AM
ktombs1
Score: 100
Last Login: 4/7/2012
Status: offline
I put MIP`s in front and back. the bottoms were tight but did pop in, the tops fit fine. gear mesh was perfect.
Hide Signatures
       Post #: 172
RE: HPI Mini Recon - 1/1/2012 10:46 AM
stevenkelby
Score: 100
Status: offline
My mesh was perfect too, I tried 1 shim and it was too tight, wouldn't turn freely.
Hide Signatures
(in reply to ktombs1)
       Post #: 173
RE: HPI Mini Recon - 1/1/2012 6:52 PM
mercerbeef
Score: 105
Last Login: 3/10/2013
Status: offline
Nice, maybe now I can get my brama18b running. my micro sidewinder blew both diffs on the buggy. Does the buggy alum. motor mount fit the recon? and I'm guessing the bramas alum. shocks would be too short for the recon too?
ESEblitz, Efirestorm, firestorm10t, cycloneS,
Hide Signatures
       Post #: 174
RE: HPI Mini Recon - 1/1/2012 11:44 PM
SyCo_VeNoM
Score: 621
Status: online
I didn't post this but there was another issue I didn't notice with the traxxas rims on it. Putting the RPM arms on somehow pushed the hubs, and carrier a little farther out making the rims go in on the top due to the tierods now being too short. Kinda was shocked at that seeing the RPM arms are literally the same dimensions... Ohh well I ordered titanium RC18 tierod set to fix that. This is probably one of the last expenses I see for a while till the diffs melt, but I'll deal with that when it arises. So far around $100 in upgrades(which would have been less if they sold the alum shock towers separate), not counting the BL setup which I think will pretty much end it
Hide Signatures
(in reply to mercerbeef)
       Post #: 175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.984RCU1
