RE: STIHL oil ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: STIHL oil ?
Page: <<   < prev  1 2 [3] 4 5 6   next >   >>
Login
RE: STIHL oil ? - 9/30/2011 2:28 PM
MTK
Score: 203
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: TimBle
quote:
ORIGINAL: jedijody
Ummmm, a gallon has 128 ounces.
Your formula is correct for finding the right amount for a given ratio but for a 50:1 mix you would use 2.56 ounces of oil to 1 gallon of gas.
128/50 = 2.56
hmmmm US Gallon or Imperial Gallon....
128ounces to a US gallon but 155 ounces to an imperial gallon...
Answer.....(drum roll pls).... YES!!
_____________________________
Regards,
MattK
Hide Signatures
(in reply to TimBle)
       Post #: 51
RE: STIHL oil ? - 9/30/2011 2:42 PM
a1pcfixer
Score: 168
Last Login: 8/16/2012
Status: offline
quote:
ORIGINAL: MTK
This help?
Drum roll......
Jim L.
Learn from the mistakes of others.You won,t live long enough to make all of them yourself.
Hide Signatures
(in reply to MTK)
       Post #: 52
RE: STIHL oil ? - 9/30/2011 2:44 PM
jedijody
Score: 309
Last Login: 1/15/2013
Status: offline
Last time I checked, California was still in the USA.
Now go outside and play
Hide Signatures
       Post #: 53
RE: STIHL oil ? - 9/30/2011 3:10 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: a1pcfixer
quote:
ORIGINAL: MTK
This help?
Drum roll......
APC,
I put the munching deer as my background. Wish the pixelation wasn't so bad....Anyway, got several chuckles out of it from my coworkers, especially during this time of brass renderings at my office. Truly laffable stuff
The recipe Jody gave works fine with any amount of petrol. I know that you know this but for the other readers, stated another way:
Petrol volume you have on hand divided by the ratio you want to run, gives the volume of oil needed to be added to achieve the ratio.
Ex- Petrol / ratio = oil.......lets say you have 2.5 gallons and want to run 32:1 oil mix.....2.5(128) / 32 = 10.0 ozs;
Some oil is packaged in 12.8 oz bottles intended to be used in 5 gallons, to produce a 50:1 ratio
Regards,
MattK
Hide Signatures
(in reply to a1pcfixer)
       Post #: 54
RE: STIHL oil ? - 9/30/2011 3:16 PM
a1pcfixer
Score: 168
Status: offline
This makes it all so very simple;
Gas Oil Mixture Ratio Calculator.....
Jim L.
Hide Signatures
(in reply to MTK)
       Post #: 55
RE: STIHL oil ? - 9/30/2011 6:52 PM
TimBle
Score: 162
Last Login: 5/23/2013
Status: offline
you guys are way toooo serious...
Hide Signatures
       Post #: 56
RE: STIHL oil ? - 9/30/2011 7:24 PM
a1pcfixer
Score: 168
Status: offline
Jim L.
Hide Signatures
       Post #: 57
RE: STIHL oil ? - 10/4/2011 6:53 AM
Ernie Misner
Score: 130
Last Login: 5/22/2013
Status: online
No one remembers Steen-C, the first? synthetic to hit the 2-stroke racing circuit in the 60's? And man did the Castro R smell good but was a real plug fouler! And what about the good ol' Cheveron white pump premium gas.....
Ernie
Hide Signatures
       Post #: 58
RE: STIHL oil ? - 10/4/2011 10:58 AM
JNorton
Score: 149
Status: offline
Damn I'm old. I remember all of those.
John
Have desk ... Will Fly.... Saito Member #467
Ultimate Brotherhood #11, Ultra Sport Brotherhood #90
Hide Signatures
(in reply to Ernie Misner)
       Post #: 59
RE: STIHL oil ? - 10/4/2011 1:08 PM
Brian Smith
Score: 120
Last Login: 4/14/2013
Status: offline
I remember Steen-C. Used to run it in my go cart with twin Power Products engines. Also used "Sunoco" white gas. I didn't know Cheveron had it. . Brian
quote:
ORIGINAL: Ernie Misner
Ernie
Brian P. Smith Bismith2@hotmail.com
AMA 1044 IMAA 21141 W4BPS <><
Hide Signatures
       Post #: 60
RE: STIHL oil ? - 10/4/2011 2:02 PM
TimBle
Score: 162
Status: offline
what's Cheveron?
Hide Signatures
(in reply to Brian Smith)
       Post #: 61
RE: STIHL oil ? - 10/4/2011 2:23 PM
w8ye
Score: 318
Status: offline
Chevron was a prominent Standard Oil Company of California brand back in the 70's
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
       Post #: 62
RE: STIHL oil ? - 10/5/2011 6:19 AM
Ernie Misner
Score: 130
Status: online
And their white pump was super high (leaded!) octane gas, not white gas. Racers had to have it. It's understandable that they did not have Chevron stations in Africa though....
Oh yeah, and the Blendzall castor smell had them all beat. You would definitely get high if you got stuck behind someone running that. I think it had an additive that would allow some methanol to be mixed with the gas and remain homogenous. You guys that mix methanol with the gas, how are you keeping them from separating?
Ernie Misner (a past mechanic of Evel Kneivels!)
Hide Signatures
(in reply to w8ye)
       Post #: 63
RE: STIHL oil ? - 10/5/2011 7:27 AM
TimBle
Score: 162
Status: offline
I know what Chevron is, just not ChevEron...
Anyway to keep methanol in phase with Gasoline mix in a dash of ethanol.
Alternatively, keep the Methanol % below 1.6% or very high around 85%
For anything in the middle a 1:4 parts mix EthOH to MeOH works.
No need to remind you characters of the toxicity of methanol and the age old don't try this at home disclaimer.
Not sure why you want methanol in there anyway. It reduces BTU so you need to richen up the mixture to compensate for power. Fuel economy goes out the window as well. Only advatage is octane but our model airplane engine don't rev no have a high enough compression ratio to exploit the octane so tell me why, oh tell me why
Hide Signatures
       Post #: 64
RE: STIHL oil ? - 10/5/2011 12:33 PM
Brian Smith
Score: 120
Status: offline
Oh NO. !! The dreaded grammar cops are back. God help us characters. .. ..
B
quote:
ORIGINAL: TimBle
what's Cheveron?
Hide Signatures
       Post #: 65
RE: STIHL oil ? - 10/5/2011 1:07 PM
TimBle
Score: 162
Status: offline
Hide Signatures
       Post #: 66
RE: STIHL oil ? - 10/5/2011 4:16 PM
panhndl
Score: 105
Last Login: 5/21/2013
Status: offline
Ok, everyone needs one of these.  Stop doing math and just fill to the line indicated...
http://www.motorcycle-superstore.com/2/9/205/7411/ITEM/Ratio-Rite-Measuring-Cup.aspx
Edit:  Forgot to mention you can probably find one at any motorcycle shop.  Been using them for years on my dirt bikes.
Hide Signatures
       Post #: 67
RE: STIHL oil ? - 10/5/2011 4:26 PM
Whistling Death
Score: 150
Status: offline
quote:
ORIGINAL: panhndl
You are so right. I have and use one of these, great tool!
Blake
CORSAIR Brotherhood Lucky #13
Hide Signatures
(in reply to panhndl)
       Post #: 68
RE: STIHL oil ? - 10/5/2011 4:57 PM
Tired Old Man
Score: 662
Last Login: 1/16/2012
Status: offline
Just divide the gas quantity on hand by the ratio. Imperial or U.S. measure doesn't matter as long as you maintain consistent volume types. Imperial may use cc's instead of oz. A simple kitchen measuring cup is usually accurate enough to handle the oil quantity measurement after that. I'll suggest not using your wife's favorite cooking tools though.
Never lie, and never minimize or gloss. Tell it like it is and let the pieces fall where they may. The truth always wins.
Hide Signatures
(in reply to Whistling Death)
       Post #: 69
RE: STIHL oil ? - 10/5/2011 8:16 PM
Eganwp
Score: 113
Last Login: 7/21/2012
Status: offline
I just use my own calculator program I wrote when I was bored at work. :P Allows me way more flexibility in calculation options over all the gas/oil calcs I've found online. Maybe I'll have to share it with people... O.o
35% H9 Extra 300 - DLE-111 | 33% Lanier Yak 54 - DL-100 | 30% Peak Edge 540T - DLE-55 | SkyWalker Long Range FPV
Hide Signatures
(in reply to Tired Old Man)
       Post #: 70
RE: STIHL oil ? - 10/5/2011 8:26 PM
Tired Old Man
Score: 662
Status: offline
A simple calculator is all it takes. However, those tech savvy always have the option of making things more complicated
Hide Signatures
(in reply to Eganwp)
       Post #: 71
RE: STIHL oil ? - 10/5/2011 9:30 PM
karolh
Score: 310
Status: offline
Karol
When inverted always remember that down is up and visa versa
Hide Signatures
       Post #: 72
RE: STIHL oil ? - 10/5/2011 9:43 PM
MTK
Score: 203
Status: offline
quote:
ORIGINAL: Tired Old Man
AKA, posts 38 and 54. It don't get any simpler than that as TOM sez.....
Lessee....a cubit of gas is how much?
Too much, I know
Regards,
MattK
Hide Signatures
       Post #: 73
RE: STIHL oil ? - 10/5/2011 11:00 PM
Tired Old Man
Score: 662
Status: offline
One cubit...of course
Hide Signatures
(in reply to MTK)
       Post #: 74
RE: STIHL oil ? - 10/5/2011 11:23 PM
TimBle
Score: 162
Status: offline
quote:
ORIGINAL: Eganwp
jeez wizz, program to calculate volume ratio's....
40:1
How much you want /41 give you the other part.
want 5L at 40:1
5L/41= 0.121
or 121ml of oil
now don't forget to take 121ml from 5L or you will end up wit 5.121L....
darn it even works in US measures, what do you know....
Hide Signatures
       Post #: 75
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: STIHL oil ?
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.172RCU1
