RE: Losi Ten SCTE 4x4 or AE SC10?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SCT Combo - RTR
Seller:  Callifas38
Details:   $100.00   |  5/19/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: Losi Ten SCTE 4x4 or AE SC10?
Page: <<   < prev  1 [2]
Login
RE: Losi Ten SCTE 4x4 or AE SC10? - 10/8/2011 3:51 PM
kaycerc
Score: 126
Last Login: 1/16/2013
Status: offline
quote:
ORIGINAL: ilanstylz
quote:
ORIGINAL: kaycerc
quote:
ORIGINAL: ilanstylz
And I can contest to the losi being hard on electronics, your more likely to overheat a motor etc on the scte because of its weight if you don't run the proper motor and gearing, and they can drain batteries quicker then the lighter 4x4's
Realistically, the Losi is not going to be any more of a drain or stain on the motor/battery/electronics - because of its ''slightly'' heavier weight - than the AE is with is high-drag belt drive system. www.rcuniverse.com="" forum="" js="" fckeditor="" editor="" images="" smiley="" msn="" src="" />
Tell that to my lipo's, with my scte on a 5000mah 40c lipo I was barely getting 6 to 7 min run times, while my sc10 4x4 which weighs almost a pound less is getting closer to to 8+ mins???????
Just because you are lapping sc10's at your track does not mean the losi is better, at my track its the exact opposite..... Now does that mean the sc10 is better? No just means that when everything is said and done it comes down to the driver, not the vehicle..............
If that's all the runtime you're getting, you're overgeared or have some other issue.
_____________________________
- Just because your redneck buddy said so does not make it right.
Hide Signatures
(in reply to ilanstylz)
       Post #: 26
RE: Losi Ten SCTE 4x4 or AE SC10? - 10/8/2011 6:39 PM
ilanstylz
Score: 100
Last Login: 3/31/2013
Status: offline
quote:
ORIGINAL: kaycerc
quote:
ORIGINAL: ilanstylz
quote:
ORIGINAL: kaycerc
quote:
ORIGINAL: ilanstylz
Realistically, the Losi is not going to be any more of a drain or stain on the motor/battery/electronics - because of its ''slightly'' heavier weight - than the AE is with is high-drag belt drive system. www.rcuniverse.com='''' forum='''' js='''' fckeditor='''' editor='''' images='''' smiley='''' msn='''' src='''' />
Regardless if I'm overgeared or not, your missing the point...... The heavier SCTE is and will not get the same runtime when compared to a lighter 4x4......... Enough said.........
RC10GT-OS.18CVR/RC10gt-LRP.18/MMGT/MMGT-BB-HPI/MGT4.6-LRP.30/RC8/NTC3-OS.18CVR/TraxxasSport/HimotoEldorada/DuratraxRaze
Hide Signatures
(in reply to kaycerc)
       Post #: 27
RE: Losi Ten SCTE 4x4 or AE SC10? - 10/8/2011 6:43 PM
kaycerc
Score: 126
Status: offline
quote:
ORIGINAL: ilanstylz
quote:
ORIGINAL: kaycerc
quote:
ORIGINAL: ilanstylz
quote:
ORIGINAL: kaycerc
quote:
ORIGINAL: ilanstylz
Since both are designed and intended to race, and races are typically 6 minutes long, and baziliion-mAh packs are commonplace, a 9% weight differential is inconsequential. And if it is, then you don't know what you're doing Nuff Said!
Hide Signatures
       Post #: 28
RE: Losi Ten SCTE 4x4 or AE SC10? - 10/8/2011 6:56 PM
ilanstylz
Score: 100
Status: offline
quote:
ORIGINAL: kaycerc
quote:
ORIGINAL: ilanstylz
quote:
ORIGINAL: kaycerc
quote:
ORIGINAL: ilanstylz
quote:
ORIGINAL: kaycerc
quote:
ORIGINAL: ilanstylz
**** does anything have to do with them being designed to race?????????????? If you know it all then prove me wrong, explain to me why my B4 on the same pack can run 3X longer then either of the 4x4's??????????????
Hide Signatures
       Post #: 29
RE: Losi Ten SCTE 4x4 or AE SC10? - 10/10/2011 1:00 AM
ThunderbirdJunkie
Score: 1040
Last Login: 6/25/2012
Status: offline
quote:
ORIGINAL: ilanstylz
quote:
ORIGINAL: kaycerc
quote:
ORIGINAL: ilanstylz
quote:
ORIGINAL: kaycerc
quote:
ORIGINAL: ilanstylz
x2, ThunderbirdJunkie's buddy's SCTE struggled to make an eight minute heat (Tekin 4.5, TP 5300/65c battery, RX8). ThunderbirdJunkie's SC10 4x4, on the other hand, with an RX8, 1410, and 5000mah packs, could get 20 minutes of straight runtime on the track...
"Some people can mess up an anvil with a rubber hammer" -46u
If you don''t allow yourself to fail, you''ll never allow yourself to succeed-ThunderbirdJunkie
Hide Signatures
       Post #: 30
RE: Losi Ten SCTE 4x4 or AE SC10? - 10/10/2011 1:50 PM
kaycerc
Score: 126
Status: offline
quote:
ORIGINAL: ilanstylz
quote:
ORIGINAL: kaycerc
quote:
ORIGINAL: ilanstylz
quote:
ORIGINAL: kaycerc
quote:
ORIGINAL: ilanstylz
quote:
ORIGINAL: kaycerc
quote:
ORIGINAL: ilanstylz
Since both are designed and intended to race, and races are typically 6 minutes long, and baziliion-mAh packs are commonplace, a 9% weight differential is inconsequential. And if it is, then you don't know what you're doingwww.rcuniverse.com="" forum="" js="" fckeditor="" editor="" images="" smiley="" msn="" src="" /> Nuff Said!
Since runtime is only a viable consideration if you're racing, you're quibbling over bits.
Hide Signatures
       Post #: 31
RE: Losi Ten SCTE 4x4 or AE SC10? - 10/10/2011 1:52 PM
kaycerc
Score: 126
Status: offline
quote:
ORIGINAL: Thunderbird
JunkieThunderbirdJunkie's buddy's SCTE struggled to make an eight minute heat (Tekin 4.5, TP 5300/65c battery, RX8). ThunderbirdJunkie's SC10 4x4, on the other hand, with an RX8, 1410, and 5000mah packs, could get 20 minutes of straight runtime on the track...
KC's buddy's SC10 4x4 struggles to make it through a 6 minute heat. What's your point?
Hide Signatures
(in reply to ThunderbirdJunkie)
       Post #: 32
RE: Losi Ten SCTE 4x4 or AE SC10? - 10/10/2011 3:05 PM
ilanstylz
Score: 100
Status: offline
quote:
ORIGINAL: kaycerc
Your the one that is acting like you know it all, and once again you still haven't posted anything to backup your comments that weight plays no factor....... So once again I ask you prove me wrong.......
Hide Signatures
       Post #: 33
RE: Losi Ten SCTE 4x4 or AE SC10? - 11/7/2011 1:20 AM
SquarePusher
Score: 100
Last Login: 12/31/2011
Status: offline
Hey thunderbird ? will a 5600 60c 2s make it through 2 heats without a charge ? and if so what gearing in the scte ..with a 3300kv pro 3 tekin?
Hide Signatures
       Post #: 34
RE: Losi Ten SCTE 4x4 or AE SC10? - 12/31/2012 9:00 AM
DCX
Score: 100
Last Login: 1/5/2013
Status: offline
Ah yes, the dynamics of racing. Heaver is wrong on paper, however, faster and not in the air longer (getting that green power?) is on the throttle longer. W/ my truck, I want to use the WHOLE LiPo in one race, and have not much to spare, if I have left over LiPo capacity, then thats extra weight unused. Or is it? Weight helps in certin conditions, you only to employ it and realize that you can't get traction w/o it or have the run time, or airbourne forever, so many different set ups. So lets brag about what works, not cry about some number on a piece of paper, 'Come On Man!
AUTHORIZED PULSO DEALER www.aurigaavionics.com
Hide Signatures
(in reply to SquarePusher)
       Post #: 35
RE: Losi Ten SCTE 4x4 or AE SC10? - 1/3/2013 1:35 PM
Foxy
Score: 2012
Last Login: 5/19/2013
Status: offline
This thread was last posted in 18 months ago, please check dates before hitting the submit button.
PS. Referring back to a post on page 1...Touring cars have belts because they act as a drag brake?? There are many reasons why belt is better than shaft (it is better in case anyone is under any misconception), but that ain't one of them.
On the subject of weight being beneficial, it is. Those who are taking weight off their cars in every way possible are usually not doing themselves any favors. Lighter=more difficult to drive, less traction under power, less predictability in the corners and in traffic.
IT`S A FAAAAAAAAKKKKKKKEEEEEEEEE!
Hide Signatures
(in reply to DCX)
       Post #: 36
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.079RCU1
