RE: Servo screws    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Mikado Logo XXTREME Combo - RTF
Seller:  Hegemonoius
Details:   $2,975.00   |  4/29/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> RE: Servo screws
Page: <<   < prev  1 [2]
Login
RE: Servo screws - 9/30/2011 10:02 PM
bhorton
Score: 100
Last Login: 5/25/2013
Status: offline
I use Dubro Socket Head Servo Mounting Screws like these:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&W=000448338&I=LXFRM2&P=K
If the servo tray is light ply I add strips of aircraft ply under the tray and use CA to harden the threads in the wood like others have already described.
_____________________________
Of all the things I''ve lost, I miss my mind the most.
Hide Signatures
(in reply to Gray Beard)
       Post #: 26
RE: Servo screws - 9/30/2011 10:10 PM
The Ghost
Score: 110
Status: offline
quote:
ORIGINAL: MinnFlyer
Ooops. Edwin beat me to it
Yea, but you use pictures
Cheers
Remember, Always look after the ORGANIC part of the model
Hide Signatures
(in reply to MinnFlyer)
       Post #: 27
RE: Servo screws - 9/30/2011 10:27 PM
on_your_six
Score: 264
Status: online
So I am wrong??? The piston is counter balanced... sure there is some vibration, but the engine designer did the best they could. Until you try what I am telling you, you will never believe... sorry, your loss.
If you see this much vibration, there is usually something causing it. Does not cost a thing to check and balance these things.
quote:
ORIGINAL: MinnFlyer
No matter what you do, you still have a piston moving up and down.
Hide Signatures
       Post #: 28
RE: Servo screws - 9/30/2011 10:52 PM
Edwin
Score: 156
Status: offline
Yeah, somethin to be said for pictures. Minnflyer could a just posted the pics and said nothing. And it would have been understood. I'm a shoot from the hip guy, Minnflyer aims.
Edwin
Hide Signatures
(in reply to on_your_six)
       Post #: 29
RE: Servo screws - 9/30/2011 11:00 PM
VF84sluggo
Score: 345
Status: online
Man, I've been making 'vibration-proofing' my cowl and canopy screws waaay too hard. I've been using wood like MN Flyer, but then using a blind nut, a socket-head screw, and then cutting thin 'washers' out of fuel tubing to use under the screw and metal washer. Problem is these fuel-tubing washers tend to squish out around the metal washer as the screw is tightened.
Tons of good tips here in this thread on easier ways to do this...sheesh, now you guys tell me
JetCat P100-RX
Kingtech K60G
Hide Signatures
(in reply to Edwin)
       Post #: 30
RE: Servo screws - 9/30/2011 11:05 PM
Edwin
Score: 156
Status: offline
Good judgement comes from experience. Unfortunately, experience comes from poor judgement.
Edwin
Hide Signatures
(in reply to VF84sluggo)
       Post #: 31
RE: Servo screws - 9/30/2011 11:58 PM
Gray Beard
Score: 314
Status: offline
Prices of screws for hobby use tends to be a bit out of line. I placed an order, { I do this about every 5 years} and buy my screws and hardware from Micro Fastener. I just bought 4 bags of 100 2 X 9/16 servo screws, $4.90 per 100. I picked up several bags of 4-40 hex head screws and 2-56 hex heads then washers for them. I also ordered several bags of hardware for some friends at the same time. There are other places with the same items and about the same prices but I have used Micro for years so I haven't changed to another company. Once you have been in the hobby long enough you will find way better places then Tower to buy from but Tower is a great place for people just starting out, they have most everything for new modelers. They used to be a lot better but they are still where I send my new students.
Vibration: OK, fact, you can never balance a single cylinder engine so it doesn't vibrate. However, a well balanced prop can really cut down on vibration. I have tried using unbalanced spinners then a balanced one and there is little effect due to the center mass on the crank but even that can help dampen vibration. I have had some very smooth running twins though. Vibration is just the nature of the beast but there are a few things we can do to help remove it. Prop balance is the big thing. Different brands of props are also smoother running then others. You can never fully remove it but you can tame it.
Drinking and driving are illegal, why do bars have parking lots
Daisy Air Guns, keeping kids off your lawn for 100 year
Hide Signatures
(in reply to Edwin)
       Post #: 32
RE: Servo screws - 10/1/2011 12:26 AM
mike31
Score: 114
Last Login: 5/22/2013
Status: offline
Not sure. I have been flying for 35 years and have never had a servo screw come loose. maybe the hole you are inserting the screw into is to big? Maybe you need to get the engine balanced properly? Who knows?
Hide Signatures
(in reply to Goran619)
       Post #: 33
RE: Servo screws - 10/1/2011 12:28 AM
mike31
Score: 114
Status: offline
I beg to differ with you on the balance issue for a single cylinder engine. I raced go karts for years and every Mac I ran was a single and was balanced. Just bigger but still a single cylinder!
Hide Signatures
       Post #: 34
RE: Servo screws - 10/1/2011 1:04 AM
All Day Dan
Score: 151
Status: offline
Jordan, use 3-48 screws into maple mounts. The screws fit the eyelets much better and the maple provides plenty of friction. Dan
Click to see fullsize image.
Click for fullsize
Dan
Hide Signatures
       Post #: 35
RE: Servo screws - 10/1/2011 1:40 AM
on_your_six
Score: 264
Status: online
Single cylinder engines cannot ever be perfectly balanced. The crank shaft can be counter balanced, but there is always going to be a certain amount of vibration that cannot be eliminated as you convert a pumping piston motion into rotary energy.
What I am saying is that a pretty darn good job is being done, but when you throw on an unbalanced propeller and/or spinner vibration is very noticeable. Cure the effect of the vibration using the methods described here, but curing the cause goes a long way towards not needing the cure. It should also be pointed out that static and dynamic balancing are two different things... you are looking for a dynamic balance, but often the static balance is close enough. A sever imbalanced condition will soon wreck the firewall and other glued joints and plane, motor, batteries and electronics will not last very long at all... so when I first heard the OP's question... I was thinking vibration caused all the damage.
Engine designers have done a lot to reduce engine vibration... look at the huge rotary engines of WWII, look at the V8s and their crankshafts and how elaborately they are counter balanced.
quote:
ORIGINAL: mike31
Hide Signatures
(in reply to mike31)
       Post #: 36
RE: Servo screws - 10/1/2011 2:50 AM
Goran619
Score: 100
Last Login: 5/11/2013
Status: offline
On our six is right I did initially balance my prop after the tips were painted but I inspected the prop and found a couple chips out of the painted tips. So I rechecked the prop it was a little out of balance so I added a small amount of CA to the tip and it balanced out perfectly. I also added more CA to the servo tray where the screws go in, let it dry and then added another drop to each hole then screwed in the servos so hopefully they will never come apart again. On the cowl I did drill out the cowl mounts a little bit and then stuck a piece of nyrod tube into each one then used some CA to secure them in. They cowl screws sure did tighten down nicely, I also added a washer to each screw to apply pressure to more than just the little screw head. Thank you all for the advice it was all wonderful as usual.
Jordan
Trex 550E 3G
Raptor 30V2
Hide Signatures
       Post #: 37
RE: Servo screws - 10/1/2011 3:46 AM
mlj3
Score: 100
Status: offline
While on the subject of servo screws,,Who makes the best ?? I have used some that where Great,I have also used some that either the Hex Head rounded out or the complete head rung off, I don,t remember where I brought the Bad ones. I think the best ones I brought where from Central Hobby Thanks In advance !!!
Hide Signatures
       Post #: 38
RE: Servo screws - 10/1/2011 6:22 AM
Gray Beard
Score: 314
Status: offline
Best????????? The word best is often a relative term. All of the screws I have gotten over the years look the same but have all been repackaged with the sellers label on them. I'm sure Micro Fastener is like NAPA, don't make anything but distribute under there name. A distributor is not a manufacture. I don't have any trouble with the items I have bought from Micro but I know I can twist the head off of any #2 screw. When I strip or round off the center of the head first place I look is the tip of my wrench. I quick lick on the grinder makes them good as new unless it's one of my round tips that hasn't broken off yet.
Mike, having something balanced doesn't mean it's a true balance. My bike engines were balanced as well as anyone could do but it wasn't a true 100% job. No reason to get into what I did to a VW engine but you can get darn close when you have 4 cylinders to work with.
Hide Signatures
(in reply to mlj3)
       Post #: 39
RE: Servo screws - 10/1/2011 12:35 PM
VA-RC-POP
Score: 100
Last Login: 11/23/2011
Status: offline
ALL OF THE METHODS DESCRIBED WILL WORK. MOST OF THE PROBLEMS WITH MOUNTING SERVOS IS THE INSTALLATION OF THE "BRASS" EYELET THAT GOES INTO THE RUBBER GROMET. IF YOU WILL LOOK AT THE PICTURES OF MOST OF THE SERVOS THAT ARE FOR "SALE" THE EYELET, IS INSTALLED UPSIDE DOWN. THE LARGE OR FLARED END OF THE EYELET GOES AGAINST THE WOOD, MOST OF THE SERVOS ARE MOUNTED IN WOOD. THIS LARGER END KEEPS THE EYELET FROM EATING INTO THE WOOD, CAUSING THE RUBBER GROMET TO BE MASHED TOO TIGHT. THIS KEEPS THE SERVO FROM BEING ABLE TO ABSORB EXCESS STRESS, AND ALSO HELPS KEEP THE SCREW TIGHT. BE SURE TO USE A SCRAP PIECE OF HARDWOOD, 1/4" sq. UNDER THE SERVO TRAY, USE THE HARDWOOD TO MAKE THE RAILS. NEVER MOUNT SERVO SCREWS INTO BALSA WOOD WITHOUT ADDITIONAL SUPPORT
Hide Signatures
       Post #: 40
RE: Servo screws - 10/1/2011 1:19 PM
Edwin
Score: 156
Status: offline
I forgot to mention that I sometimes us the white plastic washers on the cowl screws. RTL and Micro Fasteners sell the washers with a rubber surface on one side.
Edwin
Hide Signatures
(in reply to VA-RC-POP)
       Post #: 41
RE: Servo screws - 10/1/2011 2:33 PM
MinnFlyer
Score: 390
Last Login: 4/27/2012
Status: offline
quote:
ORIGINAL: on_your_six
You're insinuating that I don't balance my props. I do (at least the larger ones). Screws still vibrate loose. Rather than drive myself crazy for hours researching where the mysterious vibration is coming from, I find it much easier to secure my screws.
Mike B. AMA# 42400 www.gettingairborne.com
Ultra Sport Brotherhood #2 - Waco Brother #188 - Cub Brother #2
"Those are my principles. If you don’t like them, I have others." - Groucho Marx
Hide Signatures
       Post #: 42
RE: Servo screws - 10/1/2011 4:50 PM
DIYER
Score: 100
Last Login: 5/8/2013
Status: offline
For mounting cowls and canopies I use plywood or hardwood blocks into which I tap and thread 4-40 holes. After dripping some CA into each hole for hardening the wood, I screw on the canopy/cowl with 4-40 nylon bolts. The nylon bolts absorb vibration and, if there is severe stress, the bolts will break before the blocks, so replacement is easy.
Hide Signatures
       Post #: 43
RE: Servo screws - 10/1/2011 7:55 PM
BarracudaHockey
Score: 280
Status: offline
Six is correct, no way to cost effectively balance a single cylinder model engine unless they start using tungsten counterweights, but then that wouldn't be cost effective
Andy - Helicopter Forum Moderator
AMA 77227 Leader Member- Contest Director
www.JaxRC.com
Hide Signatures
(in reply to DIYER)
       Post #: 44
RE: Servo screws - 10/1/2011 8:40 PM
jester_s1
Score: 233
Last Login: 5/24/2013
Status: online
Even if the engine and prop is balanced perfectly, we still get pressure pulses from only having one cylinder which causes a twisting vibration. It's very noticeable when the plane is sitting at idle, and aside for adding a harmonic dampener there's nothing we can do about it.
For me, an ARF is an airplane that someone else just crashed.
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 45
RE: Servo screws - 10/1/2011 8:45 PM
huck1199
Score: 115
Status: offline
Anyone ever produced a dampening spinner?
Hide Signatures
       Post #: 46
RE: Servo screws - 10/1/2011 11:44 PM
Old Fart
Score: 158
Status: offline
Good tip on the nyrod,i've been using tiny wallplugs they work great
Watch out for the ground eh?
Hide Signatures
(in reply to huck1199)
       Post #: 47
RE: Servo screws - 10/3/2011 6:51 PM
Radical Departure
Score: 104
Status: offline
quote:
ORIGINAL: Gray Beard
I get my screws from Micro Fastener, hex head screws. I pre-drill the holes under size, thread the screws in then back out. Add a drop or two of thin CA then let it set up. Now install the servos and tighten them down good.
Same screws and method I use. Never had a problem with them when installed that way.
Radical Departure..
..from controlled flight
Hide Signatures
       Post #: 48
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.922RCU1
