Will this cause interference?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Will this cause interference?
Page: [1]
Login
Will this cause interference? - 8/21/2003 4:18:43 AM
canesugarrules
Status: offline
I am building a Wattage Crazy Max (electric). It is a fairly tight fit in the fuselage, and the elevator and rudder servos are touching (HS-55). Will this cause any interference?
       Post #: 1
Will this cause interference? - 8/21/2003 9:52:17 AM
Lynx
Status: offline
Not very likley, as long as the control arms can't hit each other.
_____________________________
-Curiosity may have killed the cat
-But that's why they have nine lives
(in reply to canesugarrules)
       Post #: 2
Will this cause interference? - 8/21/2003 7:45:22 PM
FLYBOY
Status: offline
I have done that quite a bit. You shouldn't have a problem.
Fly it till the wings come off.
       Post #: 3
Will this cause interference? - 8/22/2003 2:11:39 AM
canesugarrules
Status: offline
Thanks. Only the cases are touching. I'm going to range test anyway.
       Post #: 4
Will this cause interference? - 8/22/2003 7:24:43 AM
jchuston
Status: offline
I own a Crazy Max (bought it in February of this year) and I think that this is standard for the servos to touch (at least for the Rudder/Elevator combination of servos...)
I am not using 55's, I am using 81's, but they will be fine...just be careful with how you locate the wing in the wing saddle, and make sure that you do a little sanding around the sharp edges of the saddle after you cut it down to size...I didn't have this problem, but I have heard of a couple of people losing their fuse from the wing because that sharp-edges plastic cut through the rubberbands that they were holding their wings on with...also, even though the plans call for 2 rubberbands on the wing...just use 4...better safe than sorry...
-John
AMA 739303
       Post #: 5
Will this cause interference? - 8/24/2003 11:09:52 PM
canesugarrules
Status: offline
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.480RCU2
