Wanted to run this past the pros
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Painting, Detailing & Bodies >> Wanted to run this past the pros Page: [1]
Login
Wanted to run this past the pros - 8/21/2003 6:02:49 AM
lazoj
Status: offline
I am getting ready to paint my Ford Gt40 body. I am using non metaillic blue with two white stripes. I am going to mask the stripes with tape, paint the blue in mulitple coats, remove the mask and hit the stripes. Couple of questions:
-Do I need to back both colors when I am said and done? What color?
-The proline body didn't come with window trim decals, so I was going to cut some of the window mask off for the trim and paint black. When should I do this? First, after or before the backing?
-I want to tint the windows and headlight covers, I was going to use black paint and practice, then paint. Once again, this should be done absolutely last, correct?
Thanks for any input.
_____________________________
HPI RS4 3 SS|HPI Racing Clutch|MIP CVD's (front)|HB Center bulkhead (just for looks!)|HPI sways|HPI graphite towers|HB Top d
       Post #: 1
Wanted to run this past the pros - 8/21/2003 5:37:05 PM
Holst
Status: offline
Mask the windows and stripes.
Paint the blue.
Remove the stripe mask.
Paint the wite and back the blue with white also.
you might want to back the white sith silver to stop the black from darkening it, or just put on plenty of white (several coats not one bit one)
Then cut the window masks and spray the black.
Remove the window masks and if you want to tint the shell do it now.
I wouldnt recomend usign canned black to tint the windows it will turn out too dark or very blotchy. Everybody who ive seen try this has ended up with black windows as it went wrong.
Best to use an airbrush with thinned paint or buy a can of window tint.
(in reply to lazoj)
       Post #: 2
Wanted to run this past the pros - 8/21/2003 8:01:21 PM
24_bikes
Status: offline
i used canned tinting. but i did want the windows pretty black afterall. it was my first body, so is it just me or does tinting dry darker then when you first put ur coats on?
(in reply to lazoj)
       Post #: 3
Wanted to run this past the pros - 8/22/2003 9:12:21 AM
lazoj
Status: offline
Ok, I painted the blue and stripes. I still ahve the window masking on the body. I can't decide how I want to do the windows. I really want to finish off with window trim, but am not sure if I want risk ruining my body. Is it pretty easy to cut back the masking? Or should I just buy some thin pinstriping and do it from the outside?
(in reply to lazoj)
       Post #: 4
Wanted to run this past the pros - 8/23/2003 5:05:59 AM
Holst
Status: offline
It depends on how sharp your knie is and how good you are at using it.
It might be worth pacticing before hand on some scraps if your not sure if you can do it.
I find it helps allot to draw the line with a fineliner before I cut.
(in reply to lazoj)
       Post #: 5
Wanted to run this past the pros - 9/7/2003 12:55:01 AM
fastfred
Status: offline
actually automotive window tinting works great.
the spray on tinting doesn't look nearly as nice...
m
LST, XXX4G+ Brushless, MTX-3, Gecko II Clod w/ Reductions, Gecko I Clod w/55turners, JPS SpeedyClod, Storm, RC10GT Jumper, XXXSG+ Carpet, XXXSG+ Brushless, XXXS/4 G+ Rally Conv., BK2, Mini-T
www.themirrorpool.com
www.mattfrederickdesign.com
(in reply to lazoj)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.780RCU1
