1QwkSport2.5r
Score: 155 Joined: 10/15/2006 Last Login: 5/24/2013 From: Cottage Grove,
MN, USA Status: offline
quote:
ORIGINAL: Nitrovein As you say, in the U.S. I believe the standard is by weight and in Europe by volume (in general). But even if most engine brands come from Europe, most of the fuel come from the U.S. I unfortunately can not find more than one brand at the moment and that site seems down for the night... http://www.gt-racing.de/ I will get back when my memory serves me better. But if we toy with the idea of mixing fuel with 25% Nitro and 10% Oil, and use a density of 0,79g/ml for methanol, 0,95g/ml for oil and 1,138g/ml for nitro then that would look like this: 1000gram = 1147,72ml Methanol 65% =650g = 822,8ml or 71,69% by volume Nitro 25% =250g = 219,68ml or 19,14% by volume Oil 10% =100g = 105,26ml or 9,17% by volume 1000ml = 893gram Methanol 65% =650ml = 513,5g or 57,5% by weight Nitro 25% =250ml = 284,5g or 31,85% by weight Oil 10% =100ml = 95g or 10,63% by weight But as you say, they probably don´t mix oil by weight, my guess is on the heavy expensive ingredient. After doing some math, I've concluded most fuel companies in the U.S. must mix by volume predominantly. Reason being is this: If they sold a 5% nitro 20% castor 75% methanol pre-mixed product mixed by weight, there would only be 112 fluid ounces of product. Being that they sell it by the gallon mainly, which is 128 fluid ounces, Either they are further diluting the nitro and oil with more methanol or just selling 112fl oz. of mixed product. 5% nitro by weight is 5.6oz = 168ml 20% castor (using .96g/ml) by weight is 22.46oz = 674ml and 75% methanol by weight is 84oz = 2520ml Added up = 3362ml. 1 Gallon = 128fl oz = 3840ml My homebrew 5% nitro 20% castor 75% methanol mixed by volume yields 6.4oz nitro, 25.6oz oil, and 96oz methanol. Their weights as a percentage respectively would be 7.6%, 23%, and 69.9% Which ends up being just a tad over a gallon (128.64oz) I hate converting from imperial to metric measurements since theres a great deal of fractions so I did some rounding to simplify things a little. I probably overthought this, but in hindsight, it is far easier to mix by volume. If one needs to be dead-on exact, then mixing by weight is a better route. As I said before, my engines havent been all that picky up to this point with what I've ran through them so I'll keep doing what I've been doing. My homebrew 20% nitro 12% castor 68% methanol by volume = 25.8%, 13.07%, and 61.06% by weight respectively. Give or take a little.
_____________________________
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
