E Flight Phantom F-4-Turbine conversion    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> E Flight Phantom F-4-Turbine conversion
Page: [1] 2   next >   >>
Login
E Flight Phantom F-4-Turbine conversion - 10/13/2011 7:47 AM
Dave Wilshere
Score: 108
Last Login: 5/25/2013
Status: online
Just before I left the office yesterday morning a nice plain box turned up in the shape of a pre-production Eflight F-4. I had looked over the model at JetPower and made notes on how I might convert it to Turbine power. Looks like I have a tank that will work and I can use our Habu 32 pipe. When I've finished catching up after yesterdays lost time I'll post more info.
DW
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
       Post #: 1
RE: E Flight Phantom F-4-Turbine conversion - 10/13/2011 10:08 AM
EDFCrazy
Score: 100
Status: offline
Dave are you going to use a single outlet pipe?
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 2
RE: E Flight Phantom F-4-Turbine conversion - 10/13/2011 1:36 PM
J.F
Score: 100
Last Login: 5/23/2013
Status: offline
so jealous..........!
Hide Signatures
       Post #: 3
RE: E Flight Phantom F-4-Turbine conversion - 10/13/2011 2:38 PM
Dave Wilshere
Score: 108
Status: online
Way busier than I expected
Yes, there is zero point in making a special pipe, noisy, less thrust, impossible to fit. So between the outlets Eurosport style.
Wings are interesting, nice thick section
Dave
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to J.F)
       Post #: 4
RE: E Flight Phantom F-4-Turbine conversion - 10/13/2011 3:37 PM
Dr Honda
Score: 100
Status: offline
Very cool.
Is this getting a p20?
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
       Post #: 5
RE: E Flight Phantom F-4-Turbine conversion - 10/13/2011 3:53 PM
Dave Wilshere
Score: 108
Status: online
Yes sir.
D
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Dr Honda)
       Post #: 6
RE: E Flight Phantom F-4-Turbine conversion - 10/13/2011 10:44 PM
Dave Wilshere
Score: 108
Status: online
Still no time to start the F-4, but in the work shop and looking at it I noticed the Flap hinge set-up limits movement. The Aileron is double bevelled.The slots are all pre cut for horns and servo arm.
Dw
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 7
RE: E Flight Phantom F-4-Turbine conversion - 10/17/2011 10:34 PM
Dave Wilshere
Score: 108
Status: online
After a break from any workshop time with family matters, I'm now back looking at this model. The conversion is much more involved than the Habu 32. A single pipe set-up is possible, but it means lots of cutting. I'm looking at options, so working on the wings. Fit is brilliant, out of the box the pegs plug in, there are stops, so they don't push through, pix of outer panel on is dry, no glue, no tape!
DW
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
RE: E Flight Phantom F-4-Turbine conversion - 10/18/2011 3:01 AM
Doug Cronkhite
Score: 105
Last Login: 5/22/2013
Status: offline
This one reminds me so much of Eric Bauer's Performance Phantom.. I love it! Can't wait to get one.
Doug Cronkhite
Hide Signatures
       Post #: 9
RE: E Flight Phantom F-4-Turbine conversion - 10/18/2011 3:58 AM
Wayne22
Score: 105
Status: offline
Dave, can you use a single straight pipe out of one of the existing nozzles? I read about somebody doing this to a larger jet (of course I can't remember which one ) But I do rememeber them stating that the slight assymetric thrust had little effect on the flying habits...........
All I ask is for a chance to prove that money can't make me happy......
Hide Signatures
(in reply to Doug Cronkhite)
       Post #: 10
RE: E Flight Phantom F-4-Turbine conversion - 10/18/2011 7:37 AM
Dave Wilshere
Score: 108
Status: online
Wayne
It is one of the things I considered-but no. On the larger models the length allows less angle than this would give. Yes I could get a pipe with a kinked end to straighten or even come back in, but then I may as well go for a Bi fo pipe. Waiting on cost, but my guess is I'll go straight pipe. I've removed the EDF Y outlet, so I have a good choice.
Dw
Hide Signatures
(in reply to Wayne22)
       Post #: 11
RE: E Flight Phantom F-4-Turbine conversion - 10/18/2011 9:34 AM
ash 26
Score: 100
Last Login: 5/21/2013
Status: offline
Dave
nice job the Phantom is one of my all time favorites would be nice to see that one at Offaly jets next year
I would go for a straight pipe no loss of power plus not as noisy
have a nice day
Andy
Hide Signatures
       Post #: 12
RE: E Flight Phantom F-4-Turbine conversion - 10/18/2011 10:26 AM
Dave Wilshere
Score: 108
Status: online
Andy
Yes, my first thought, but you have to cut a lot of the fuselage away under the fin. Will decide soon as the wings are complete!
Will bring it to the "crack"
Dave
Hide Signatures
(in reply to ash 26)
       Post #: 13
RE: E Flight Phantom F-4-Turbine conversion - 10/18/2011 10:43 AM
fege
Score: 100
Status: offline
Cool project! As for the single outlet, check out the Jepe website (http://jepe.org/indek.htm). Look under Fastfoam and select the F4. It's an EDF but it might give you some ideas on how to mask a single outlet.
/Fredrik.
Hide Signatures
       Post #: 14
RE: E Flight Phantom F-4-Turbine conversion - 10/19/2011 10:54 PM
Dave Wilshere
Score: 108
Status: online
Cracking on with the wings, started to put the servos in and control horns. Hinges in the surface side-typical E-Flight quality, everything fits, quality is good. Panel is not heavy.
Larger servos might be an issue as they side angled on the covers, but the surfaces are small, so 2.5kg plus should be fine.
Dw
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to fege)
       Post #: 15
RE: E Flight Phantom F-4-Turbine conversion - 10/19/2011 11:07 PM
YellowAircraft
Score: 186
Status: offline
Dave,
Are the servo-horn slots precut like that?
Yellow Aircraft, JetCat Engines and Turn Key Jets
Hide Signatures
       Post #: 16
RE: E Flight Phantom F-4-Turbine conversion - 10/19/2011 11:38 PM
Dave Wilshere
Score: 108
Status: online
Yes, everything is pre cut. Works OK
Click for fullsize
Hide Signatures
(in reply to YellowAircraft)
       Post #: 17
RE: E Flight Phantom F-4-Turbine conversion - 10/21/2011 7:52 PM
Dave Wilshere
Score: 108
Status: online
Test fit on the linkages and showing flap angle (which is not quite as much as I would have liked)
Dw
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 18
RE: E Flight Phantom F-4-Turbine conversion - 10/22/2011 9:24 PM
Dave Wilshere
Score: 108
Status: online
Bit more today, the pre formed legs are different to the std wire supplied with the EFLG 230's, note the bigger coil, pre bent position leaves the wheel just forward of the centre (perfect)
When you set the control surfaces, make sure you leave a large enough gap as the hinge line angles mean the gaps close with movement.
Dw
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 19
RE: E Flight Phantom F-4-Turbine conversion - 10/24/2011 8:56 PM
Dave Wilshere
Score: 108
Status: online
OK, looked more at the turbine install and have decided to get a Bi-fo pipe made to give people the choice. I still have not decided whether to wait or go single on this one.
Dw
Click for fullsize
Hide Signatures
       Post #: 20
RE: E Flight Phantom F-4-Turbine conversion - 10/24/2011 9:00 PM
J.F
Score: 100
Status: offline
would be interesting to see what the reduction in thrust might be using a bi pipe.
Will you be doing a kit the same as what you have done with the habu, i.e all the bits, servo's tank, pipe etc??
Hide Signatures
       Post #: 21
RE: E Flight Phantom F-4-Turbine conversion - 10/24/2011 9:42 PM
Dave Wilshere
Score: 108
Status: online
I'm guessing there is a loss (as usual) that's why I'm struggling with using it. Yes we will offer a conversion kit of parts, everything else in place for a single pipe set-up. Really need to build 2, one with each then we can have a race!
Dw
Hide Signatures
(in reply to J.F)
       Post #: 22
RE: E Flight Phantom F-4-Turbine conversion - 10/24/2011 10:23 PM
J.F
Score: 100
Status: offline
Sign me up! Loser buys the cakes!
Hide Signatures
       Post #: 23
RE: E Flight Phantom F-4-Turbine conversion - 10/24/2011 10:32 PM
Dave Wilshere
Score: 108
Status: online
OK...
Hide Signatures
(in reply to J.F)
       Post #: 24
RE: E Flight Phantom F-4-Turbine conversion - 10/29/2011 10:28 PM
Dave Wilshere
Score: 108
Status: online
OK, back on this again. Making up the nose unit with T axle. First wing panel fitted too.
Dw
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Dave Wilshere -- 10/29/2011 11:16 PM >
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
