RE: Thunder Tiger engines
Tower Hobbies
Logged in as Guest
  Printable Version
90 Degree Muffler Adapter
Seller:  RC Specialties
Details:   $17.95   |  7/13/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Thunder Tiger engines
Page: <<   < prev  1 2 [3] 4 5   next >   >>
Login
RE: Thunder Tiger engines - 6/20/2004 8:01:12 PM
Fun Flyer
Status: offline
In ace hobby I checked the information of both, the TT PRO 61 And the GP 61, It says that the GP is stronger I dont know why
(in reply to dlucas48)
       Post #: 51
RE: Thunder Tiger engines - 6/21/2004 2:47:34 AM
Fun Flyer
Status: offline
I hope it gives unlimited vertical to my sukhoi, it weights 6 pounds
(in reply to Fun Flyer)
       Post #: 52
RE: Thunder Tiger engines - 6/21/2004 3:25:52 AM
MyWay
Status: offline
quote:
ORIGINAL: R/C BOY!!
The GP. 61 is a bigger engine. It is a .65. Very strong engine.
       Post #: 53
RE: Thunder Tiger engines - 6/21/2004 2:58:42 PM
TNRabbit
Status: offline
I've had both the TT .46 Pro and .91 FS; they were both good engines and very durable. The .46 has been thru 3 severe crashes and still runs great.
_____________________________
Gary
AMA # 706964
(in reply to Strykaas)
       Post #: 54
RE: Thunder Tiger engines - 6/21/2004 3:29:08 PM
Fun Flyer
Status: offline
None of you guys have both?, The PRO61 and the GP61
(in reply to TNRabbit)
       Post #: 55
RE: Thunder Tiger engines - 6/23/2004 4:23:09 AM
.70 savageman
Status: offline
any of you guys put the pro-70bxr (.70) thunder tiger rc truck motor in a savage or a tmax if so is it fast??
       Post #: 56
RE: Thunder Tiger engines - 6/25/2004 12:14:54 AM
misterpanda
Status: offline
R/C Boy:
quote:
ORIGINAL: R/C BOY!!
If you read the specs carefully (as per Tower Hobbies Tech notes), you will see that the GP61 is actually a .64!!!!!!!!!!!!!!!!!!!!! Perhaps herein lies the greater power output claim.
Cordially,
Misterpanda
       Post #: 57
RE: Thunder Tiger engines - 6/25/2004 2:38:15 PM
Fun Flyer
Status: offline
Thanks for the info misterpanda
(in reply to misterpanda)
       Post #: 58
RE: Thunder Tiger engines - 9/22/2004 4:07:47 AM
sam1390
Status: offline
hi every one can some one help me i`m very intersting to start rc dealer out side the usa but i need help to know where can i start
       Post #: 59
RE: Break-in, etc. - 12/19/2005 2:55:36 AM
krazycdn
Status: offline
how the hell do you know when they are tuned properly I had my cub do a stall and die today due to my tg 40 petering out
cubs for life
(in reply to Gene Chernosky)
       Post #: 60
RE: Break-in, etc. - 12/19/2005 3:04:21 AM
w8ye
Status: offline
Hold the plane vertical and lean out the high speed needle to find the point where the engine runs the fastest. Then screw the needle back out about 4 clicks.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to krazycdn)
       Post #: 61
RE: Thunder Tiger engines - 12/19/2005 5:01:00 AM
seanychen
Status: offline
quote:
ORIGINAL: TNRabbit
My TT 46 Pro was run over by a car after crashing. Now it still runs great, turning APC 12x4 @ 14000 rpm w/ a BCM strap-on muffler.
E_Total = M*G*H + 1/2 M*V^2
When H=0, all of airplane's velocity becomes crash energy!
       Post #: 62
RE: Thunder Tiger engines - 12/19/2005 6:17:18 AM
Jackster00
Status: offline
Yes, the TT Pro is one tough engine. A person who was learning on a trainer of mine with a TT Pro 46, nose-dived the plane into the bone-dry ground of my flying field last summer, breaking off the muffler at the mount (damage was done to the engine casting). After some alterations, including making a spacer to replace the lost material on the damaged exhaust port and a thorough cleaning, the engine still runs strong on an identical trainer, with no diminished performance!
(in reply to seanychen)
       Post #: 63
RE: Thunder Tiger engines - 12/19/2005 2:06:54 PM
Ed Cregger
Status: offline
quote:
ORIGINAL: misterpanda
R/C Boy:
quote:
ORIGINAL: R/C BOY!!
Cordially,
Misterpanda
Mostly likely it is a typo. The GP is a plain bearing engine that is grossly detuned from the ball bearing version.
Artisan
"Flying models since the Fifties - I'll get the hang of this yet!!!"
       Post #: 64
RE: Thunder Tiger engines - 12/19/2005 2:24:40 PM
seanychen
Status: offline
http://www.acehobby.com/ace/TTR9060.htm
It is indeed 0.646 cu in. Look at the bore and stroke and do the math yourself. It has the same stroke as the Pro 61, but larger bore.
I don't think it is detuned. It just doesn't have ball bearing, and has air bleed carb. Mainly cost saving measure. However, its power is pretty good if propped for lower rpm range, especially when compared with the Pro 61, which is not a particularly powerful 61 anyway.
(in reply to Ed Cregger)
       Post #: 65
RE: Thunder Tiger engines - 12/19/2005 3:26:18 PM
britbrat
Status: offline
With a healthy sized prop, the TT "61" GP will easily out-pull both the TT 61 Pro & the OS 61 FX (both of which are pretty average in performance). If you want to wind them until they squeak, the 61 Pro has a small advantage in performance. IMO, all things considered, the GP is a better choice.
