Gene Chernosky
TX, USA Status: offline
TT ABN engines need a HOT break-in. DON'T do the rich run routine or you could possibly ruin the engine! Don't run them full lean at first, but definitely past the rich/lean break. Typical break-in for a TT PRO .46 is to run it up with a 10x6 to get the needle set to run lean...this is a short as possible run...let it cool afterwards. Then put a 9x6 on it and take it to 16.5K RPM and hold it there for two minutes...let it cool a LONG time. Then put an 11x5 on it (this engine's favorite prop IMO) and run it through 3-4 eight ounce tanks at full throttle just leaner than the rich/lean break...let it cool well between tanks. After that put it on a plane and go fly it...it will just keep getting better. BTW, all props are APC. The ONLY thing that upsets me with Thunder Tiger presently is that their part support is VERY little to be desired. Typically, a lot of items are on back order and there is no idea when they will be available. I hope this situation changes soon! Further, I've owned just about every engine they make except the .07, .61 & 1.20 two-cycle ones. They are inexpensive and do the job quite nicely IMO...particularily if you are a 'sport' flier. Currently I own 2-GP.15's, 2-GP.25's, 2-PRO .36's, 1-GP.42, 10-PRO.46's and 2-FS.91's. No, they aren't all in use...but I'm a packrat.
_____________________________
Eugene S. Chernosky "I'm the person your parents warned you about"
