KMS Quantom 2826/05 question    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> E-Flight Power Sources >> KMS Quantom 2826/05 question
Page: [1]
Login
KMS Quantom 2826/05 question - 10/14/2011 3:49 AM
navihawk
Score: 100
Last Login: 6/18/2013
Status: offline
hello all. I had this motor on an ultrafly sr-22, flying with 11.1 2200 lipo, it had excellent performance, way overpowered, but it crashed recently and its not repairable. The question i have is what is the Quantom 2826/05 motor most equivalent to? An eflite power 10,15,25? Im thinking its more like a power 10? it just seems kind of big motor. Thanks.
Hide Signatures
       Post #: 1
RE: KMS Quantom 2826/05 question - 10/16/2011 4:26 AM
Dr Kiwi
Score: 120
Last Login: 6/1/2013
Status: offline
The Quantum is 170g... 900Kv....and rated for 45A max (400-500W)... that is a big motor.... the E-flite Power 15 is lighter (152g), same diameter but a little shorter (50mm v. 54mm)... but close to the same power rating.... that would be the nearest of that E-flite series to your Quantum
Power 15 Brushless Outrunner Motor, 950Kv
Key Features
Equivalent to a 15-size glow engine for sport and scale airplanes weighing 36–56 oz (1020–1590 g)
Ideal for 3D airplanes weighing 32–40 oz (910–1135 g)
Ideal for models requiring up to 575 watts of power
High-torque, direct-drive alternative to inrunner brushless motors
Includes mount, prop adapters and mounting hardware
External rotor design—5mm shaft can easily be reversed for alternative motor installations
Slotted 14-pole outrunner design
High-quality construction with ball bearings and hardened steel shaft
Quiet, lightweight operation
Overview
The Power 15 is designed to deliver clean and quiet power for 15-size sport and scale airplanes weighing 36 to 56 ounces (1020 to 1590 grams), 3D airplanes weighing 32 to 40 ounces (910 to 1135 grams), or models requiring up to 575 watts of power.
Product Specifications
Type: Brushless outrunner motor
Bearings or Bushings: One 5 x 14 x 5mm Bearing, and One 5 x 11 x 5mm Bearings
Wire Gauge: 16
Recommended Prop Range: 10x6–13x6.5
Voltage: 7.4–14.4V
RPM/Volt (Kv): 950
Resistance (Ri): .03 ohms
Idle Current (Io): 2.00A @10V
Continuous Current: 34A
Maximum Burst Current: 42A (15 sec)
Cells: 8–12 Ni-MH/Ni-Cd or 3-4S Li-Po
Speed Control: 40–45A brushless
Weight: 152 g (5.4 oz)
Overall Diameter: 35mm (1.40 in)
Shaft Diameter: 5mm (.20 in)
Overall Length: 50mm (1.90 in).
_____________________________
Dr Phil Millener, Chattanooga, TN
Hide Signatures
(in reply to navihawk)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.172RCU1
