RE: Four Stroke Engine in Tower Trainer .60    Gallery
Logged in as Guest
    Search This Thread
Printable Version
SAB Goblin 770 Helicopter - RTF
Seller:  mariogonzales
Details:   $2,500.00   |  5/14/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Beginners >> RE: Four Stroke Engine in Tower Trainer .60
Page: <<   < prev  1 [2]
Login
RE: Four Stroke Engine in Tower Trainer .60 - 10/21/2011 6:17 PM
OliverJacob
Score: 110
Last Login: 5/19/2013
Status: offline
I had 4 stroke engine right from the beginning. No problems operating any of them. I have a couple Magnums and OS, they all start and run great. And they are easy on fuel and the ears.
I had a few crashes, never broke an engine...
So if your plane can handle the extra weight, I'd use the 4 cycle. I don't see why they would be harder to operate. Make sure you use the right prop nut with a jam nut, and the worst you will see is that if the engine backfires, the prop comes loose, but does not spin off.
Also - use an electric starter, do not hand start it, unless you know you engine well. As a beginner - keep you hands away from the prop.
Same thing for 2 stroke engines.
When it come the engine repairs - yes, the strokes are a lot easier to work on. Less parts, less costs and less efficiency.
Hide Signatures
(in reply to rowdog_14)
       Post #: 26
RE: Four Stroke Engine in Tower Trainer .60 - 10/21/2011 7:56 PM
rowdog_14
Score: 107
Last Login: 4/29/2013
Status: offline
quote:
ORIGINAL: OliverJacob
x2
_____________________________
THE T.R.U.T.H
Hide Signatures
(in reply to OliverJacob)
       Post #: 27
RE: Four Stroke Engine in Tower Trainer .60 - 10/21/2011 9:25 PM
hsukaria
Score: 185
Last Login: 5/18/2013
Status: offline
If you decide to go with the 4-stroke, I recommend that you use an aluminum spinner for safety in case of a backfire.
Access to a tachometer for tuning is also recommended for a 4-stroke, can't go by ear to get peak rpm.
Content, but not Complacent.
Saito Club Member #765
Hide Signatures
       Post #: 28
RE: Four Stroke Engine in Tower Trainer .60 - 10/21/2011 11:19 PM
budchugger
Score: 105
Last Login: 3/21/2013
Status: online
i used a Saito 100 in mine when i stated
The only thing that''''s supposed to drop out of the sky is bird ****
Hide Signatures
       Post #: 29
RE: Four Stroke Engine in Tower Trainer .60 - 10/21/2011 11:33 PM
jmcowart
Score: 100
Status: offline
Thanks for the suggestion.  I have a Tru-Turn aluminium spinner and back plate.  I haven't been able to get it to fit yet.  I p;urchased the adapter recommended by the Tru-Turn Company and it didnt fit.  Wouldn't tighten enough to snug down the spinner.
The company sold me another, shorter, adapter and I tried that as well.  It wouldn't fit either.
After the next call the Tru-Turn they sent me a no charge adapter and I haven't had a chance to try it out yet.
I don't have much confidence in them as of now.  Their web site sounds good and the self-proclaimed quality they push sounds good, but my results have been both expensive and frustrating.  Nothing has worked as yet.
For others, if you are using an O.S. FS-95V, find another aluminium spinner as Tru-Turn hasn't got their act together on this engine yet.
Mike.
John M. Cowart
Hide Signatures
(in reply to hsukaria)
       Post #: 30
RE: Four Stroke Engine in Tower Trainer .60 - 10/21/2011 11:37 PM
CafeenMan
Score: 105
Status: offline
Are you using the propeller washer?
Work is what I do for the love of it. A job is how I pay for it. :)
Please visit AirfieldModels.com
Hide Signatures
(in reply to jmcowart)
       Post #: 31
RE: Four Stroke Engine in Tower Trainer .60 - 10/22/2011 1:46 AM
jmcowart
Score: 100
Status: offline
Yes, prop washer that comes with the engine, then every prop nut and jam nut combination possible provided by either O.S. and/or Tru-turn. I will probably end up using the little solid aluminium spinner by Du-bro.
I will try the new adapter sent by Tru-Turn tomorrow and I have my fingers crossed that will secure the 2.5 aluminium spinner by Tru-Turn.
Mike.
John M. Cowart
Hide Signatures
(in reply to CafeenMan)
       Post #: 32
RE: Four Stroke Engine in Tower Trainer .60 - 10/22/2011 2:52 AM
carrellh
Score: 179
Status: offline
Truturn spinners are as good as any other but getting the right combination of spinner/nut/adapter can be frustrating. Trial and error does get expensive. The 'ultimate' shape is longer than some of their other designs.
http://www.truturn.com/Spinners/By_Shape/by_shape_ultimate.htm
Unless you need the nose weight, just use the plastic spinner that came with the arf
- Carrell
Hide Signatures
       Post #: 33
RE: Four Stroke Engine in Tower Trainer .60 - 10/22/2011 4:14 AM
JollyPopper
Score: 158
Status: offline
I have a Tower Hobbies .60 trainer, and it is a superb airplane. Mine has a strong .61 in it. Would I trade that strong .61 for a 90 to 115 size four stroke of just about any brand and install in that airplane? You bet your bippy.
"In theory, there is no difference between theory and practice; In practice, there is"
Hide Signatures
(in reply to carrellh)
       Post #: 34
RE: Four Stroke Engine in Tower Trainer .60 - 10/22/2011 4:44 AM
Campgems
Score: 138
Last Login: 5/17/2013
Status: offline
The great plane aluminum back, plastic cone spinners are a good choice.  I'm not a fan of the plastic back spinners as they cursh under a very tight prop, and I really tighten mine up.  they also provide a crush zone in the event you land nose first.  They have saved a couple of my engines.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBMY9&P=7
This is an example, they come a a number of sizes and colors.  No spinner nut to worry about, just the nuts that came with the enigne.  They are easy to carve out to fit a prop, a #11 Xacto knife is all you need.
Don
Hide Signatures
       Post #: 35
RE: Four Stroke Engine in Tower Trainer .60 - 10/22/2011 5:54 AM
scooterinvegas
Score: 141
Last Login: 7/7/2012
Status: offline
I had a Thunder Tiger 91 four stroke on a 60 size trainer and it flew fine. Not under nor overpowered. Wait, what was the question?
Maybe I should just take rubbing alcohol with me to the field and rub the props down before starting any of my planes!
Hide Signatures
(in reply to Campgems)
       Post #: 36
RE: Four Stroke Engine in Tower Trainer .60 - 10/27/2011 5:33 AM
dakoris73
Score: 100
Last Login: 5/16/2013
Status: offline
Probably totally unrelated, but I have the Tower 40 trainer and I put a 52 4 stroke on it, and it is definitely a fun airplane. very short take offs, lots of flight time as I can fly at less than half throttle for at least 20 min flights, great for students to fly with as it will slow down quite nicely when needed, but has the added punch to get out of trouble easier, and definitely love the looks and comments at the field about having a 4 stroke on a trainer.
If your patient getting it all set up and dialed in, you will love that 60 trainer with a 95 4 stroke in it.
Good luck and happy flying......
Remember: What goes up MUST come down. How it comes down is purely up to you.....
Hide Signatures
(in reply to scooterinvegas)
       Post #: 37
RE: Four Stroke Engine in Tower Trainer .60 - 10/27/2011 11:41 AM
mike109
Score: 148
Status: offline
G'day
Way back in 1992 I put an OS 48 Surpass in a Thunder Tiger 40 size trainer. All the experts told me it would not work but when they flew the plane, they were immediately converted.
Four strokes will happily run at part throttle all day, are economical and best of all, quiet. They are not hard to handle and rarely deadstick. As a result, I have been using them in trainers ever since. They are particularly good for older learners who seem to appreciate their good pulling power at lower speeds.
They can be damaged more in crashes than two strokes but I have always been able to repair them and with buddy boxes, crashes are rare these days.
At the present time I have a range of trainers and only one has a two stroke.
Mike in Oz
"I just had no control. Must be the radio." Club Saito #597 Kadet Brotherhood #66
Hide Signatures
(in reply to dakoris73)
       Post #: 38
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.406RCU1
