Tipover
WI, USA Status: offline
[QUOTE]Originally posted by Scoubidou I love that huge RUDDER!! You can save 3oz by replacing the main landing gear and 1 oz, if you put a micro servo for throttle and if you search more, you will remove 2 or 3 oz to get 8oz (1/2lbs) weight saving, where that plane begins to glide!! I haven't monted yet, but what advantage is to install that tube rearward?? It will be more tail heavy?? Scou [/QUOTE] I think I could shave off 8oz if I really try. Its the weight distribution thats the issue. The wings center of lift is a fixed point for any given airfoil. By moving the wing tube aft on the fuselage, you'll end up with a balanced plane around the wings center of lift. A planes Center of gravity is the movable range around the wings center of lift where the plane will still fly with a certain amount of inherent stability. Remember the little balsa gliders with the sliding wings?? slide the wing forward, or aft, to get the flattest longest glide, no weight added or removed Kevin
