Tipover
WI, USA Status: offline
I wouldn't go so far as saying this plane has a bad stall. It is a tripple taper wing, so pretty much what one should expect considering the weights were coming in at. The real issue is how to build the plane light, when you need every oz of weight on board crammed to the nose for balance. I have a 3 lb gasser up there, my reciever packs on the firewall. I'm now very close to balanced on the wing tube. Maybe 1/8-1/4" behind. I don't think 9-10 lbs is possible with the current wing location. With a light glow motor on the nose, you could cut the tail off, move it to the front, and still be tail heavy Very simply, the manufacture needs to posistion the wings center of lift location, in relation to the planes natural balance point. Moving the wing back 1/2 to 1" would shift all the weight forward. The plane would then balance around the required cg. Not exactly rocket science(well, sort of ). There should be no need to move all your gear to the nose. A good design should have its center of mass more centrally located around the cg. Also, its much easyer to balance a nose heavy plane with a few oz's of tail weight, rather than adding pounds to the nose of a tail heavy design. On adding wing area, that would be the easyest way to get this plane floating without adding much weight. Unfortunatly, doing it right would require cutting new foam cores. For best proportions, you would want to add to the root of the wing. That would also have the advantage of adding depth to the wing, for even more wing area. Because the root is a more critical stress point, the sheeting should not be spliced at that point IMO. One could add to the tips, but that would take a lot more length to get the same added area. Just my thoughts..... Kevin
< Message edited by Tipover -- 9/9/2003 1:01:03 PM >
