Scoubidou
QC, CANADA Status: offline
Ok, For those who wants to give a diet to their 24% extra and don't care about the cash, here is what i did: 1)CF wing tube: PBG103T, PBG CARBON FIBER TUBE 7/8"x30" .035" WALL 55g for 30''. I keep the supplied black socket cause its lighter than http://www.precisionaerocomposite.com/ . It fits perfectly together. weigh saving=89g. l 2) Graptech landing gear:It is 6-1/2" wide at the fuse, 6-3/4" Axle height, 16-5/8" spread, cut 1-1/2" to 1". weight:165g, weight saving=40g. The main advantage here is the CF gear if higher than CA. My MVVS1.6 will get more space to turn a 18x6 prop. I will put Duralite lithium pack (1400 ignition and 2000mamh for servos) to save another 60g As proposed by Tipover, i will use the Kavan wheels Tipover, your first position as lighter 24% CA Extra300L with a small gasser at 11lbs is in danger now!! I am trying to find a way to attach the hatch to the fuse. PLease let me know if one of you have a suggestion?? That instruction manuel is a real crap! Daniel
