Scoubidou
QC, CANADA Status: offline
Ralf, first of all, i would recommend you to read carefully this thread from the beginning. There are huge technical informations from many experience pilots and builders. If your goal is doing 3D stuff, go with a OS160FX or Saito180 and MK bellcrank. If you go with a 30CC gasser, the wing loading will be too heavy. Adding 500g gives you a plane around 13lbs, 208oz/6.18sqft=33oz oz/sqft. (25 to 28oz/sqft is good). The wing area is small on that plane compare to 72'' span Katana or Funtana. Yes you will have plenty vertical, but you will have to land at mid throttle and the wing will stall if you try to land too slow!! I would try to fit a tune pipe on the MVVS1.6 before going with a bigger motor and in the worst case, i thing the ZDZ40 is lighter than MVVS30CC. Tipover tried a modified 26CC Zenoah also... tune pipe fitting: http://www.krumscheid-metallwaren.de/html/fittings.html Keep it light and you'll enjoy, that rule does apply to any kind of plane! Wing tube weight from my previous post: 1)CF wing tube: PBG103T, PBG CARBON FIBER TUBE 7/8"x30" .035" WALL 55g for 30''. I keep the supplied black socket cause its lighter than http://www.precisionaerocomposite.com/ . It fits perfectly together. weigh saving=89g. l Daniel
