Jetcat Turboprop Info    Gallery
Logged in as Guest
    Search This Thread
Printable Version
GJC 1/6 Scale F-16 ARF PRO
Seller:  Flynstuff
Details:   $4,400.00   |  5/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> Jetcat Turboprop Info
Page: [1]
Login
Jetcat Turboprop Info - 10/21/2011 2:32 PM
siclick33
Score: 125
Last Login: 5/19/2013
Status: offline
Could someone please give me some info on the Jetcat Turboprop. I am particularly interested in the exhaust installation.
The pictures on the Jetcat website show the exhaust as being 2 short stubs to which, I assume, extensions need to be attached. Would these extensions be welded on?
I believe the CARF Marchetti uses a version of the turbine with a single exhaust outlet at the bottom. If the engine is installed in this configuration is it a big, expensive, job to have it re-configured to the twin side exhausts?
In essence I am trying to find out how difficult it would be to move this engine into a different airframe. It is pretty expensive and, if I bought one, I wouldn't want to have it restricted to the same airframe for its whole life.
_____________________________
It was all going really well, then I suddenly ran out of talent!
Hide Signatures
       Post #: 1
RE: Jetcat Turboprop Info - 10/21/2011 2:39 PM
Gonzalo38
Score: 100
Last Login: 5/20/2013
Status: online
From the pictures posted in the CARF web page, the model includes double exhaust.
What I haven't seen in their website is a kit for the exhaust extensions, but I guess you can always ask for them to your local CARF dealer.
By the way..... the bottom exhaust solutions looks ugly to me. It should have been through the sides like the Tucano.
My Gallery http://www.rcuniverse.com/community/profile.cfm?section=gallery&memid=314761
Hide Signatures
(in reply to siclick33)
       Post #: 2
RE: Jetcat Turboprop Info - 10/21/2011 3:16 PM
Dave Wilshere
Score: 108
Status: offline
It uses a manifold like the boat set-up, with two round stubs.
You would have to send the turbo prop back to JC for change if you went for a conventional set up
Dw
Motors & Rotors. JetCat, Powerbox, Intairco, Behotec, Graupner. CARF-models Rep. JR Propo for ever!, Jet 1A, MAP, Evojet, BV
Hide Signatures
(in reply to Gonzalo38)
       Post #: 3
RE: Jetcat Turboprop Info - 10/21/2011 3:40 PM
bevar
Score: 142
Status: offline
Sic,
As you can see, the model SF-260 uses two exhaust stacks. They are pre bent and simply slip over the engine exhaust housing and then a few bolts hold the stacks in place.
If you want to put the engine in a different plane, it is no big deal. Just buy a new set of exhaust pipes for the new plane and bolt them on to the engine.
The full scale Petrol and Turboprop versions uses two exhaust stacks in the same place the TP model uses FWIW...
Beave
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by bevar -- 10/21/2011 4:10 PM >
Jetcat and EVO Jet Rule!
Allied Scale Squadron
Hide Signatures
(in reply to Dave Wilshere)
       Post #: 4
RE: Jetcat Turboprop Info - 10/21/2011 5:43 PM
siclick33
Score: 125
Status: offline
Beave,
Have you seen the Marchetti installation? As Dave suggests, I'm not sure it is a simple as that as I believe that the exhaust outlet on the engine itself is different for the Marchetti than say, for instance, the C-ARF Tucano.
I've emailed Jetcat for some more info (including the price to swap the manifold part if required) to see if it is a sensible option.
The pictures below show the marine and the turboprop version to show the difference. I'm led to believe that the Marchetti Turboprop has something similar to the marine setup.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to bevar)
       Post #: 5
RE: Jetcat Turboprop Info - 10/21/2011 6:00 PM
bevar
Score: 142
Status: offline
Sic,
Let me know what you find out. A simple "S" bend with the top being turned 90 degrees would work well I suppose to have scale pipes.
Interesting...
Beave
Hide Signatures
       Post #: 6
RE: Jetcat Turboprop Info - 10/21/2011 10:12 PM
Dr Honda
Score: 100
Status: offline
I think we need a p-20 sized trubo-prop so we can fly .60 sized sport models.
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
(in reply to bevar)
       Post #: 7
RE: Jetcat Turboprop Info - 10/25/2011 4:01 PM
siclick33
Score: 125
Status: offline
Just an update to say, as of yet, there is no update
Apparently the exhaust doesn't appear to be available from CARF yet, which is a bit odd considering you can already buy the kit.
Jetcat haven't got back to me yet which is a bit odd for them as they're usually very quick at responding to emails.
Hide Signatures
(in reply to Dr Honda)
       Post #: 8
RE: Jetcat Turboprop Info - 10/25/2011 11:38 PM
Dave Wilshere
Score: 108
Status: offline
Hi Dave,
at the moment we have no pictures from the final version, it is a very new projekt....
Best
Regards,
Roman
Mit freundlichen Grüßen
JetCat Germany
Hide Signatures
       Post #: 9
RE: Jetcat Turboprop Info - 10/26/2011 12:19 AM
Tim Redelman
Score: 105
Last Login: 5/7/2013
Status: offline
Hey Boli, You need one of those! I'm getting tired of looking at that Tucano....
Timmah!
BVM/Skymaster , Jetcat USA , WREN USA and Horizon Hobby/SPEKTRUM Team Representative!
Hide Signatures
       Post #: 10
RE: Jetcat Turboprop Info - 10/26/2011 6:37 AM
Henke Torphammar
Score: 100
Status: offline
quote:
ORIGINAL: Dr Honda
They are comeing too :-)
/Henke
www.youtube.com/henke2
Swist F5D, Lambert Kolibri T25 - 310mph 2012
Hide Signatures
       Post #: 11
RE: Jetcat Turboprop Info - 10/26/2011 1:51 PM
Dr Honda
Score: 100
Status: offline
Do you have more pics of the top engine? What engine is that?
Tony
Hide Signatures
(in reply to Henke Torphammar)
       Post #: 12
RE: Jetcat Turboprop Info - 10/26/2011 2:00 PM
Henke Torphammar
Score: 100
Status: offline
quote:
ORIGINAL: Dr Honda
It's a development from Martin Lambert meant to power a Trex 500 helicopter. Look at it as an experiment rather then a prototype. I know Martin was talking about a version with a power turbine like most other turboprop solutions on the market too. I guess time will tell
/Henke
Hide Signatures
       Post #: 13
RE: Jetcat Turboprop Info - 10/26/2011 2:41 PM
bevar
Score: 142
Status: offline
Yes yes! One of my friends used to fly with the Redhawks back in the day in the 260 ...I'd love to get one to add to the fleet!
B
quote:
ORIGINAL: Tim Redelman
Timmah!
Hide Signatures
(in reply to Tim Redelman)
       Post #: 14
RE: Jetcat Turboprop Info - 11/27/2012 11:04 AM
frema
Score: 103
Status: offline
hahah
so Martin Lambert still have no freepower turbine
then i am still the only one in the world
the engine with that plastic gear , i dont like it at all
i did that too , but if you realy have power , you need steel
like i have hahaha
Click for fullsize
Hide Signatures
(in reply to bevar)
       Post #: 15
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
