RE: Sig Somethin' Extra Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: Sig Somethin' Extra Build Page: <<   < prev  1 2 3 4 5 [6]
Login
RE: Sig Somethin' Extra Build - 3/15/2012 4:09 PM
yel914
Score: 120
Last Login: 5/18/2013
Status: offline
The advice for preassembly is a good one. That Seamus has been around the block I don't make any rash decisions when I crash a plane. I pick up all the pieces and sock it away for a while. I find myself thinking about what may have caused the crash for some time afterward. Eventually, I look at the crashed plane and decide what to do with it. By then I've calmed down and can apply some rational thoughts about my next step. Sometimes rational...but not always!
_____________________________
Kits show building skills, ARFs show shopping skills. WACO Brotherhood #24
Hide Signatures
(in reply to mikeh251)
       Post #: 126
RE: Sig Somethin' Extra Build - 3/15/2012 8:28 PM
SeamusG
Score: 199
Last Login: 4/10/2013
Status: offline
quote:
ORIGINAL: jetblast96
So when doing the pre-covering check, if I were to find a messed up hinge slot, how would it be fixed? Fill it and re cut it?
I've opened up the "messed up" hinge slot so that a piece of 3/16, 1/8 stock can be slid in wet with wood glue with grains aligned. Using a drill bit at the ends (3/16) and cut straight lines on the hole's outside edges. Cut a piece of stock and sand over the ends to match the holes and the depth of the trailing edge. You can either recut the hinge hole at the same location - might be problematic  - or move the hinge slot to a new virgin location. I would not use a mircro balloons putty or any other type of filler.
I've rehinged CA, Dubro pinned hinges and Robart hinge pins using the technique.
Hide Signatures
(in reply to jetblast96)
       Post #: 127
RE: Sig Somethin' Extra Build - 3/16/2012 4:35 PM
blw
Score: 655
Last Login: 5/20/2013
Status: offline
Mine has been crash repaired 8 or 9 times. It survived a hard mid air with another SSE. It was given to me when the builder got tired of repairing it. I just repaired a Smoothie that broke in two in the same place down the fuselage.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
(in reply to SeamusG)
       Post #: 128
RE: Sig Somethin' Extra Build - 12/13/2012 10:16 PM
jazzboy
Score: 100
Last Login: 5/15/2013
Status: offline
Fun thread. Will be building an SSE with a Saito FA80 GK ABC. Already saw a few great tips on throttle linkage.
Cheers,
Andy
Hide Signatures
(in reply to blw)
       Post #: 129
RE: Sig Somethin' Extra Build - 12/14/2012 12:10 AM
UltimateFlyer120
Score: 100
Status: offline
It will be interesting to see how the balance comes out with an FA 80. Good luck!
Victor
Saito Club #33
Hide Signatures
(in reply to jazzboy)
       Post #: 130
RE: Sig Somethin' Extra Build - 12/14/2012 6:41 AM
jazzboy
Score: 100
Status: offline
I'm sure the elevtor and rudder servos will be at the rear of the fuselage.
quote:
ORIGINAL: UltimateFlyer120
Hide Signatures
(in reply to UltimateFlyer120)
       Post #: 131
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.391RCU1
