RE: Irvine engines    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Irvine engines
Page: <<   < prev  1 2 3 [4]
Login
RE: Irvine engines - 5/4/2012 4:08 PM
pancake
Score: 100
Last Login: 5/18/2013
Status: offline
can someone tell me the size of the black slotted screws which hold the black plastic style carburetor on the older Irvine 40 is? i lost one and need a replacement.
Hide Signatures
(in reply to Texas Don)
       Post #: 76
RE: Irvine engines - 5/9/2012 12:44 PM
Kostas1
Score: 330
Last Login: 5/24/2013
Status: offline
Presentation of my Irvine 53!
_____________________________
<==**Check my gallery for more pictures**
Club Saito member #706
Hide Signatures
(in reply to pancake)
       Post #: 77
RE: Irvine engines - 12/19/2012 2:03 AM
downunder
Score: 123
Last Login: 5/20/2013
Status: offline
I've just picked up a NIB Irvine 61RLS from the bay which arrived yesterday. It looked so much like my 40RLS I just had to have it . However I also have a new Dykes ringed 61R and they're completely different animals (apart from the obviously different coloured heads). From the parts list that came in the box, the 61RLS is quite a mixture of bits. The crankcase is the 61R but the head, piston/liner, wrist pin and gaskets are peculiar to the RLS while the crankshaft, con rod and wrist pin circlips come from the Irvine 72. This is somewhat similar to my 40RLS which is a mix of early RE crankcase with some Q40 parts and Mk3 .46 crankshaft.
Fairly soon (probably after Christmas) I'll be stripping it down to get some measurements to compare things like bore/stroke and timings to the 61R.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to fiery)
       Post #: 78
RE: Irvine engines - 12/22/2012 3:54 PM
Dan Vincent
Score: 100
Last Login: 5/23/2013
Status: offline
I only have one Irvine engine. It's a .25 RC. Must be an early version because the carb guts are aluminum instead of brass.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Hobbsy)
       Post #: 79
RE: Irvine engines - 12/23/2012 12:30 AM
jeffie8696
Score: 120
Last Login: 5/15/2013
Status: offline
Yea, its an older one but as long as the quality is there it should be a good runner regardless. All mine run amazing except the 1.50 that is unrun.
Club Saito # 677 , Team Boca Bearings and Star Collectibles Muscatine
Hide Signatures
(in reply to Dan Vincent)
       Post #: 80
RE: Irvine engines - 4/25/2013 5:37 AM
fiery
Score: 100
Status: offline
A while back I received as part of trade a couple of "bumpy" Irvine .40 Mk II's.
The ABC one was OK. I gave it to Dave.
The other was set up with a Dykes ring and steel cylinder. I kept it. It was a wreck. It had been badly maltreated and run 'hot'. Really hot. The ring was so worn it wiggled in its land. The piston crown and skirt were pitch black with baked on carbon.
I found I could still get parts for it.
With back plate and carb off I boiled the engine for fifteen minutes in water and a little dishwashing liquid. I then stripped and dried it.
I cleaned the piston with paint stripper, and then used the green side of a green and yellow plastic plastic pot scourer with some elbow grease to get the hardened carbon off. It was a long job. I installed a new ring, cylinder liner, and gaskets scourced from RC Modelcentre in the UK. It was treated to a new set of screws. Du-bro 4-40 x 3/8 for the head and case, and, 6-32 x 9/16 for the muffler. New ball bearings installed care of Boca (my usual scource, R/C Bearings, did not list Irvine). Amazingly, the big and little ends of the rod, the piston pin and piston bosses were fine. The carb received a new main needle.
All other working parts were fine.
Irvine built these .40's tough.
I ran it in today. Six five minute runs with complete cool down between each, really rich for the first few runs, gradually leaning it out on the successive runs. On nil nitro home made fuel with a hot ENYA #3 plug it peaks perfectly and throttles like a rheostat. Back to readiness for many hours service.
Issues? It leaks fuel/air mix between the back of the case and the back plate. The uppermost flange of the composite back plate slightly flex's out. The exhaust is loud. Really loud. That chamberless muffler results in minimal noise reduction. I will probably install a double chamber muffler on it. To sort the back plate leak I will try a thicker (home made 1/32") automotive gasket paper gasket coated in blue hylomar. Hopefully that will sort it.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by fiery -- 4/26/2013 2:00 AM >
Hide Signatures
(in reply to jeffie8696)
       Post #: 81
RE: Irvine engines - 4/25/2013 1:46 PM
Hobbsy
Score: 650
Status: offline
Good job Derek, here is a shot of the bumpy you passed on to me.
Click for fullsize
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to fiery)
       Post #: 82
RE: Irvine engines - 4/26/2013 3:32 AM
jeffie8696
Score: 120
Status: offline
I call mine "Lumpy" LOL
Hide Signatures
       Post #: 83
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: Irvine engines
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.500RCU1
