RE: 31% Fokker Dr-1 Scratch Build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
DAB-A-GLUE Glue Applicators
Seller:  donnboyd
Details:   $3.95   |  6/3/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> RE: 31% Fokker Dr-1 Scratch Build
Page: <<   < prev  1 2 3 [4] 5   next >   >>
Login
RE: 31% Fokker Dr-1 Scratch Build - 10/26/2012 5:37 PM
lazyace
Score: 100
Last Login: 6/18/2013
Status: offline
nice and neet , I opted for the solid gear , have it on my 1/3 pup seems to be OK , turning cold and rainy here tonight
_____________________________
charlie AMA 8916
WACO brotherhood #67
Hide Signatures
(in reply to rcwarbirdbuilder)
       Post #: 76
RE: 31% Fokker Dr-1 Scratch Build - 10/27/2012 3:43 AM
rcwarbirdbuilder
Score: 110
Last Login: 6/13/2013
Status: offline
Will I got the undercarriage complete, still need to make the wood strut covers over the gear strut wire,  and now start painting some of the crosses on.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Help! Call the doctor I can''''''t stop building these things.
Hide Signatures
(in reply to lazyace)
       Post #: 77
RE: 31% Fokker Dr-1 Scratch Build - 10/27/2012 6:31 PM
rcwarbirdbuilder
Score: 110
Status: offline
My hands are to shaky without masking tape to paint this...
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 78
RE: 31% Fokker Dr-1 Scratch Build - 11/1/2012 5:21 PM
rcwarbirdbuilder
Score: 110
Status: offline
Painting the details continues...
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 79
RE: 31% Fokker Dr-1 Scratch Build - 11/2/2012 12:03 PM
lazyace
Score: 100
Status: offline
looking real good , when's the first flight ?
charlie AMA 8916
Hide Signatures
       Post #: 80
RE: 31% Fokker Dr-1 Scratch Build - 11/2/2012 9:40 PM
rcwarbirdbuilder
Score: 110
Status: offline
Just to dang cold for me to go outside and set this airplane up for flight, unless we get a warm snap in the weather... otherwise looks like I well be doing more detail work on it.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 81
RE: 31% Fokker Dr-1 Scratch Build - 11/3/2012 9:34 PM
rcwarbirdbuilder
Score: 110
Status: offline
I have the fiberglass cowl detailed and painted and the dummy air intake tube stubs installed behind the cowl on the fuselage. I like using the rubber backed washer under the screws spaced 3" appart to hold the cowl. Balsa USA sells the neat prop washers.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 82
RE: 31% Fokker Dr-1 Scratch Build - 11/4/2012 4:47 PM
rcwarbirdbuilder
Score: 110
Status: offline
Here is what it is looking like, the next step for me to get it closer to fly is to balance the airplane.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 83
RE: 31% Fokker Dr-1 Scratch Build - 11/4/2012 7:34 PM
lazyace
Score: 100
Status: offline
what no guns ?
charlie AMA 8916
Hide Signatures
       Post #: 84
RE: 31% Fokker Dr-1 Scratch Build - 11/5/2012 10:14 PM
rcwarbirdbuilder
Score: 110
Status: offline
I got to get some guns yet, along with Ace of Iron pilot and some leather trim around the cockpit opening. Still have more work to do on covering the wire wing and geare struts with wood struts, also need to make the wheel gear wing.
Hide Signatures
       Post #: 85
RE: 31% Fokker Dr-1 Scratch Build - 11/6/2012 4:22 PM
rcwarbirdbuilder
Score: 110
Status: offline
I took pine about 1" wide and grooved it 1/4" on the back, so it can be slipped over the wire struts for a better appearance.
Click for fullsize
Hide Signatures
       Post #: 86
RE: 31% Fokker Dr-1 Scratch Build - 11/15/2012 4:38 PM
rcwarbirdbuilder
Score: 110
Status: offline
I am using some goop to secure the trim around the cockpit opening..
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 87
RE: 31% Fokker Dr-1 Scratch Build - 11/17/2012 4:14 AM
rcwarbirdbuilder
Score: 110
Status: offline
The weather was not bad today so I got the first flight in before the sun went down, seems to fly good, airlon trim was dead on, elevator needed some down trim which is typical on most of these old timers. Now I can finish the detail on the dash, got a 1/3  Ace of Iron pilot on order, and need to get couple machine guns.  http://www.youtube.com/watch?v=tCBrBlxSHOs
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 88
RE: 31% Fokker Dr-1 Scratch Build - 11/17/2012 11:37 AM
lazyace
Score: 100
Status: offline
hi george looks real good in the air. Do you think my g-62 has the power for it to fly good ? started to cover it yasterday lots of mat'l
charlie AMA 8916
Hide Signatures
       Post #: 89
RE: 31% Fokker Dr-1 Scratch Build - 11/17/2012 12:42 PM
rcwarbirdbuilder
Score: 110
Status: offline
Charlie, you know I had planed on using a G-62 when I started this project, but ended up installing a Q-75 becuase I got a good  deal on couple larger used engines..   My impression after I made the first flight was that I did not need the Q-75 in it after all.. That is my friend making the second flight while I worked the camera, he likes it with the Quadra 75,, the big thing is that with a G-62 it would be hard to put it through all the areobatic manuvers he likes to fly, like the rolls without loosing altitude..  I think it well be ok either way, keep us all posted on which way you go, George.
Hide Signatures
       Post #: 90
RE: 31% Fokker Dr-1 Scratch Build - 11/23/2012 5:42 PM
rcwarbirdbuilder
Score: 110
Status: offline
Getting Manfred the pilot from ACE of Iron prepped to fit into the cockpit of the DR-1...
Click for fullsize
Hide Signatures
       Post #: 91
RE: 31% Fokker Dr-1 Scratch Build - 11/23/2012 11:04 PM
rcwarbirdbuilder
Score: 110
Status: offline
Got a new 24x10 prop I picked up and the pilot painted and installed today..
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 92
RE: 31% Fokker Dr-1 Scratch Build - 11/26/2012 5:13 PM
rcwarbirdbuilder
Score: 110
Status: offline
I got two spandau 1/3 size machine gun kits from BalsaUSA, pre painted the barrel inside black, than rolled it and glued the seam to make a tube has to be the most difficult part of the assembly.
Click for fullsize
Hide Signatures
       Post #: 93
RE: 31% Fokker Dr-1 Scratch Build - 11/26/2012 7:22 PM
lazyace
Score: 100
Status: offline
a little flimsy for 32.00 I think
charlie AMA 8916
Hide Signatures
       Post #: 94
RE: 31% Fokker Dr-1 Scratch Build - 11/26/2012 8:52 PM
rcwarbirdbuilder
Score: 110
Status: offline
That is what I am thinking Charlie, not $32, I got billed $39 each, not shure what it was with postage, well over  $70, threw the bill away in the trash quick so I would not be reminded, sure looks like inflation is taking hold of prices and the wages keep going down for new hires..
Hide Signatures
       Post #: 95
RE: 31% Fokker Dr-1 Scratch Build - 11/28/2012 6:18 PM
rcwarbirdbuilder
Score: 110
Status: offline
Ok, this is it, the guns are ready to mount..
Click for fullsize
Hide Signatures
       Post #: 96
RE: 31% Fokker Dr-1 Scratch Build - 12/2/2012 7:31 PM
rcwarbirdbuilder
Score: 110
Status: offline
Put a little more lead in the front to make up for the added weight of the pilot and guns...
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 97
RE: 31% Fokker Dr-1 Scratch Build - 12/2/2012 11:45 PM
lazyace
Score: 100
Status: offline
looks real nice with guns & pilot , still covering wings
charlie AMA 8916
Hide Signatures
       Post #: 98
RE: 31% Fokker Dr-1 Scratch Build - 1/14/2013 12:06 PM
lazyace
Score: 100
Status: offline
george
sneeeek peeeek almost done if pics upload
Click for fullsize
Click for fullsize
charlie AMA 8916
Hide Signatures
       Post #: 99
RE: 31% Fokker Dr-1 Scratch Build - 1/14/2013 1:44 PM
rcwarbirdbuilder
Score: 110
Status: offline
lazyace, nothing lazy about that strut detailed on the upper part of the wing strut, L@@king good, what engine did you go with and when is the maiden flight scheduled for? George.
Hide Signatures
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.594RCU1
