lawn darted brand new 50cc    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Fly Eagle Jet F-16 Project, 1/5.5 Scale, includes turbine - ARF
Seller:  Screamin Eagle
Details:   $6,300.00   |  6/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Crash & Rebuild >> lawn darted brand new 50cc
Page: [1] 2   next >   >>
Login
lawn darted brand new 50cc - 10/24/2011 8:42 PM  1 votes
andizzle
Score: 101
Last Login: 5/19/2013
Status: offline
worthless aurora 9 radio has cost me 2000 bucks, 2 airplanes, and about 300 bucks in excedrin migraine
first crash i took hitecs advice and thought MAYBE it was the receiver, so before putting this radio in my brand new 50cc mx2 i purchased a new receiver, plane flew great from about 10 flights. then just like before it locked me out with no control whats so every. plane looped a few times then lawn darted into a field about a 1/2 mile away...lesson learned from this, im going back to futaba
what was left after the mile round trip to find it and parts, followed by it being sacrificed to the rc field gods lol
_____________________________
Carl Goldberg Ultimate Brotherhood # 66
Hide Signatures
       Post #: 1
RE: lawn darted brand new 50cc - 10/24/2011 10:46 PM
foodstick
Score: 182
Last Login: 6/19/2013
Status: offline
Man, that is tough ...
Its pretty much the worst case scenario when you can't trust a radio..
Hide Signatures
(in reply to andizzle)
       Post #: 2
RE: lawn darted brand new 50cc - 10/24/2011 10:54 PM
Oberst
Score: 621
Last Login: 5/22/2012
Status: offline
quote:
ORIGINAL: foodstick
Its pretty much he worst case scenario when you can't trust a radio..
Must be a 2.4.
Sorry for the loss, it's a bumber I know. I smacked my second Extra 260 last year. It wasn't a radio failure, but it was more like pilot failure. I tried to do a roll right after take off and I didn't have enough airspeed. "Smack!"
Pete
AMA #856404 Fokker Planes Forever! VFW POST 8534 Mens Aux Member
Hide Signatures
(in reply to foodstick)
       Post #: 3
RE: lawn darted brand new 50cc - 10/24/2011 11:20 PM
aussiesteve
Score: 216
Last Login: 5/29/2012
Status: offline
Sorry to hear of your loss(es) andizzle. Even if you could pinpoint the actual issue you will always have that doubt in the back of your mind as to the radios reliability. IMHO You are making the right choice to replace it if for no other reason than peace of mind.
A couple of questions
Did the plane have an optical kill switch of any type? If so, Which one?
What batteries were you using?
What servos were you using?
Was this the first flight of the day or how many flights had it done before that on the day?
The reason I am asking is that a buddy of mine has had a similar experience as yours and is doing some research. It seems all may not be perfect in the A9 world.
I had a similar problem as you experienced (not with a Hitec - another of the "top 3" brands) and to this day, I can not consider using that particular radio. I also changed to the mighty Futaba and have not had the slightest issue since.
3W, BME and DA all the way. Proven power, Proven reliability and Proven support equals much cheaper in the long term.
Hide Signatures
       Post #: 4
RE: lawn darted brand new 50cc - 10/24/2011 11:55 PM
Rfabbre
Score: 100
Last Login: 6/18/2013
Status: offline
Andizzle,
Sorry for youe loss.  Looks like it was a beautiful plane.  Where did you get it???
Thanx     Rich
Hide Signatures
       Post #: 5
RE: lawn darted brand new 50cc - 10/25/2011 12:07 AM
Kwesdog
Score: 100
Status: offline
Man that really stinks. Sorry for your loss.
I lost a 50cc a few years ago due to what I thought was a radio failure but it ended up being a power issue. I took the plane off and it was about perfect just to find that once I got 20 feet off the ground I had no control. The plane just kept going in a very lazy climb with an ever so slight left turn at 1/4 throttle until it exceeded about 30 degrees bank and started coming down right into the field parking lot behind the pits of all places. Smashed the wings into toothpicks when it hit.
I got lucky that the wing and the back of the fuse took all the shock from the crash. My engine wasnt even scratched and none of the servos broke/stripped (Which was a major indicator of the power failure). Sounds like you didnt come out as good as I did.
Again sorry to hear about the loss.
Harry
I fly army UAVs and no its not like flying R/C!
Hide Signatures
(in reply to Rfabbre)
       Post #: 6
RE: lawn darted brand new 50cc - 10/25/2011 12:18 AM
aussiesteve
Score: 216
Status: offline
I just took another look at the pictures.
I think there may have been a contributory factor there that isn't radio related
Everyone knows Ethanol is bad for our engines - look at what it did to yours
Hide Signatures
(in reply to Kwesdog)
       Post #: 7
RE: lawn darted brand new 50cc - 10/25/2011 12:30 AM
andizzle
Score: 101
Status: offline
quote:
ORIGINAL: aussiesteve
no there was no optical kill switch of any kind, i pretty much got it ready to fly from a friend
i cant remember the brand name batteries off the top of my head but everything was 6 volt. i do know my ignition was a 2500 mah, my rudder was a 2500mah, and everything else was on a 4200mah battery. everything was charged up overnight and i did a extensive preflight (being a real pilot its just a habit and added insurance) checked every batteries voltage with and without a load. i made sure the reciever and antenna was well away from batteries and switches. all my servos are also hitec servos
my outlook is maybe hitec has outsourced work to save money and the quality control just isnt there anymore. all i know is im done with there radios
Hide Signatures
(in reply to aussiesteve)
       Post #: 8
RE: lawn darted brand new 50cc - 10/25/2011 12:36 AM
andizzle
Score: 101
Status: offline
lol ethanol kicks butt lol
sadly i just got this plane this week rtf off a friend after drolling over it for months, and he put a good number of flights on it so i knew his setup was good to go. when this happened yesterday it was only my third day out with it. on a very positive note i sold a 50cc edge 540 i got but never started on to a friend and he had put it together and flew it a handle full of times over the summer. after we all had time to calm down after this mishap he offered to sell me back my old 50cc airframe for dirt cheap. its reasons like this that i love this hobby and my friends at the field, even when the night is darkest every comes to gether to help you out
Hide Signatures
       Post #: 9
RE: lawn darted brand new 50cc - 10/25/2011 1:09 AM
RC MANIAC119
Score: 100
Status: offline
I just love the '"FINAL RESTING PLACE" for your baby.
RC MANIAC-PRO BRO 1900-AMA# 95841
Hide Signatures
       Post #: 10
RE: lawn darted brand new 50cc - 10/25/2011 1:26 AM
andizzle
Score: 101
Status: offline
lol thanks, i took the wind sock down and stuck it up there, seemed only fitting to show off my trophy lol
Hide Signatures
(in reply to RC MANIAC119)
       Post #: 11
RE: lawn darted brand new 50cc - 10/25/2011 4:39 AM
JeffinTD
Score: 110
Status: offline
Major bummer, but it is good you have flying buddies to take a bit of the sting out of it.
Hide Signatures
       Post #: 12
RE: lawn darted brand new 50cc - 10/25/2011 1:52 PM
Guitarman52
Score: 136
Last Login: 6/16/2013
Status: offline
Man I know the feeling.... Same thing happened to me. Two planes.. same result except that my radio was a Futaba.... I switched to Hitec. Lets wish each other luck. Unfortunely, I think it can happen on all of the radios. You just can't put any trust in them after that, even if it wasn't the radio.
Hide Signatures
(in reply to JeffinTD)
       Post #: 13
RE: lawn darted brand new 50cc - 10/25/2011 8:46 PM
aa78
Score: 100
Last Login: 2/11/2013
Status: offline
A9, receiver and module firmware versions?
Hide Signatures
(in reply to Guitarman52)
       Post #: 14
RE: lawn darted brand new 50cc - 10/27/2011 4:01 AM
andizzle
Score: 101
Status: offline
hung my war trophy up in the living room, think it really spruced up the room
Hide Signatures
(in reply to aa78)
       Post #: 15
RE: lawn darted brand new 50cc - 10/27/2011 7:50 AM
JeffinTD
Score: 110
Status: offline
That does look pretty cool. Maybe compound miter the end so it sits flat on the wall, and put some lights on it?
Hide Signatures
       Post #: 16
RE: lawn darted brand new 50cc - 10/27/2011 2:15 PM
andizzle
Score: 101
Status: offline
i never thought of lights lol
im thinking of taking some of the smaller pieces and makeing christmas orderments for my tree lol
Hide Signatures
       Post #: 17
RE: lawn darted brand new 50cc - 10/27/2011 3:17 PM
JeffinTD
Score: 110
Status: offline
I always thought if I ended up with the front of a fuse it would be cool to make an electric wall fan or something.
I wonder if you could rig something up on this to wiggle the control surfaces to music or something?
Hide Signatures
       Post #: 18
RE: lawn darted brand new 50cc - 10/27/2011 5:44 PM
andizzle
Score: 101
Status: offline
u just gave me a idea, i still have the cowling that is messed up, i should put in on the other side of the wall lol
Hide Signatures
       Post #: 19
RE: lawn darted brand new 50cc - 10/27/2011 11:52 PM
Guitarman52
Score: 136
Status: offline
I grew up in Philo. Where do you guys fly up there?
Hide Signatures
       Post #: 20
RE: lawn darted brand new 50cc - 10/28/2011 2:46 AM
andizzle
Score: 101
Status: offline
quote:
ORIGINAL: Guitarman52
cool deal man i live out behind white cottage...our field is down off tunnel hill rd. in new lex. pretty much out in the middle of a strip mine so we have plenty of room to play
Hide Signatures
       Post #: 21
RE: lawn darted brand new 50cc - 10/28/2011 9:17 PM
Guitarman52
Score: 136
Status: offline
I'll have to check it out when I get up there. Seems like a lot of fields are located in strip mines and land fills.
Hide Signatures
       Post #: 22
RE: lawn darted brand new 50cc - 11/24/2011 6:17 AM
rrragmanliam
Score: 111
Last Login: 6/13/2013
Status: offline
quote:
ORIGINAL: andizzle
no there was no optical kill switch of any kind, i pretty much got it ready to fly from a friend...
i cant remember the brand name batteries off the top of my head...
RTF from a friend? Did you do the radio instalation or did he? Did your "real pilot extensive preflight" include a range check with the engine running at various throttle settings and with the airplane at various attitudes to the radios antenna? 10 flights "no problems" then on flight 11 theres a problem? Sounds like a battery/charge/ connection problem to me, not a MFG defect.
quote:
ORIGINAL: andizzle
You have no solid evidence to back up this statement. Hightec radios are fine, so are Futaba and JR. To often when a crash occurs, a pilots first instinct is to throw the radio mfg under the bus. Go ahead and swich to Futaba, it's what I fly. You will crash again with their equipment on board, then it will be "Futaba's fault". Right?
rrragman
< Message edited by rrragmanliam -- 11/24/2011 5:40 PM >
"Half a bee, philosophically, must ipso facto half not be. But half the bee has got to be, vis-à-vis its entity - d''you se
Hide Signatures
       Post #: 23
RE: lawn darted brand new 50cc - 11/26/2011 6:48 PM
k3 valley flyer
Score: 115
Status: offline
Not nearly enough information here to blame the radio. Flew 10 times no problem then "locked me out", was this the 11th flight of the day? "Plane looped a few times and the lawn darted into the ground a half mile away", was the plane a half mile out when the "lock-out occured? You have 2 years experience and are flying a complicated gas 3D plane with a 3 battery set-up. The lock-out term has been used alot in last few years due to the problem Spektrum radios had with low voltage battery levels especially in planes with digital servos and high current draw and resulting reciever drop-out. Most radio issues are swithch or battery related and not necessarily lock-out but loss of signal between the tx and rx. I know when a pilot gets "behind" a high performance plane at a considerable distance and every attempt to regain control fails it sure "feels" like loss of radio or 'lock-out", but rarely is. Hitec receivers can be set up with one or two batteries, if two are used generally one powers the receiver only and the other the servos, how the rudder was on a battery seperate from the other servos is not explained. Before blaming any brand of equipment more experience with the product being used would be good. As previous poster I believe all the major brands are currently offering very good products, but the more complex they get the more knowledge of teh end user required.
Hide Signatures
(in reply to rrragmanliam)
       Post #: 24
RE: lawn darted brand new 50cc - 11/26/2011 9:22 PM
bkdavy
Score: 146
Status: offline
There's no mention of the battery chemistry. Were the batteries Li-Po, LiFe, NiMH, or NiCd? I think in some cases (I've witnessed one), the nickel batteries may not be capable of delivering sufficient current for 5 high torque digital servos often found on high performance planes. The subsequent voltage drop causes a temporary radio lockout.
I've been flying an Aurora 9 with Optima 7 on a 50 cc Yak-54 with 5 7955TG servos for two years on A123 batteries (unregulated) with nary a problem (except when the plane flew through the trees - damned Aurora).
Brad
Hide Signatures
(in reply to k3 valley flyer)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.688RCU1
