Smoky
SK, CANADA Status: offline
That problem is caused by the slop in the cable assembly itself. There is no cure for it, using the set up you have. If you move the rudder slowly one way then the other you will see how much the rudder moves before the Float rudder begins to move. this is what is causing your problem. However you should be able to fly with ok the way it is. To Cure it. Use either a direct push-rod set up, or Dual cables (lots of resistance tho). set both to pull. one on each side of the rudder, and down to the appropriate side of the control horn of the float. (you need a Dual horn here, that sticks out both ways.) If you check the Galleries here, you should be able to see a few different set-ups that are being used. I started with the set-up you have, didn't like it, same probs, and I am now using a push rod type. Smoky.
