need a needle valve for an OS .48 surpass    Gallery
Logged in as Guest
    Search This Thread
Printable Version
90 Dgree Muffler Adapters
Seller:  RC Specialties
Details:   $19.95   |  4/12/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> need a needle valve for an OS .48 surpass
Page: [1]
Login
need a needle valve for an OS .48 surpass - 10/27/2011 1:38 AM
Vertical3-D
Score: 100
Last Login: 3/17/2013
Status: offline
wrecked a plane and broke the high speed needle off in the carb anyone know if tower sells them and which to buy, they dont list one specifically for that engine and if not where can I buy one, I'd prefer to buy from tower though...thanks in advance for any help
_____________________________
...GP 81" J-3 CUB arf, powered by Saito FA-130T, Futaba 2.4GHz...
...Club Saito #711...
Hide Signatures
       Post #: 1
RE: need a needle valve for an OS .48 surpass - 10/27/2011 2:16 AM
w8ye
Score: 318
Last Login: 5/20/2013
Status: offline
The OS 52 Four Stroke carb or the carb from a Magnum 52 will bolt right on the 48 like it was made for it.
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Recipient, Mangledhand award August 2008
Club Saito Member #7
Original AMA #31261
Hide Signatures
(in reply to Vertical3-D)
       Post #: 2
RE: need a needle valve for an OS .48 surpass - 10/27/2011 2:39 AM
Vertical3-D
Score: 100
Status: offline
is there a benefit in swapping the carbs, the engine did seem a little finicky with the stock carb compared to my saito .91 I had and my dads ASP .61, both of those engines always ran perfect with only minor tuning changes for weather, I'd like to set the OS up for another plane I have since I not only wrecked the suhkoi which had the OS on it, but a week earlier my big cub with my saito twin when in, then a week later my dads plane pulled the front wing dowl out in flight, luckily two of the planes are fixable, the suhkoi is done though, also looking for a new home for my saito 1.30 twin as its just two heavy for that cub
Hide Signatures
(in reply to w8ye)
       Post #: 3
RE: need a needle valve for an OS .48 surpass - 10/27/2011 3:33 AM
w8ye
Score: 318
Status: offline
My OS 48 had a OS 52 carb when I traded for it. It ran fine. I never had a 48 with an original carb.  I've seen them with the Magnum 52FS carb too.
Original AMA #31261
Hide Signatures
       Post #: 4
RE: need a needle valve for an OS .48 surpass - 10/27/2011 11:59 PM
Vertical3-D
Score: 100
Status: offline
I think I'll go with the magnum crab, its about half the price and its the same carb as my dads ASP .61 it looks like which I'm familiar with and has always ran great
Hide Signatures
(in reply to w8ye)
       Post #: 5
RE: need a needle valve for an OS .48 surpass - 10/28/2011 12:38 AM
w8ye
Score: 318
Status: offline
I think you will find that it is pretty much like the original carb.
I've had several Magnum Four strokes and the carbs seem to work fine.
Tell Hobby People that you have a Magnum 52.  They will refuse to sell you a carb to go onto a OS 48 and insist that theirs will not fit a OS 48.
Original AMA #31261
Hide Signatures
       Post #: 6
RE: need a needle valve for an OS .48 surpass - 10/28/2011 3:25 AM
gkamysz
Score: 120
Last Login: 2/6/2012
Status: offline
Tower's site is a disaster if you don't have OS part numbers. This is the needle for the FS-48.
The needle from the FS-30, and 40 also fits the FS-48 carb. This needle has a finer taper so it will give you a few clicks more range of adjustment on the needle.
I have a NIP carb for the FS-48 if you prefer to go that route.
Greg
Greg
Hide Signatures
(in reply to w8ye)
       Post #: 7
RE: need a needle valve for an OS .48 surpass - 10/29/2011 6:02 PM
piper_chuck
Score: 126
Last Login: 3/1/2012
Status: offline
quote:
ORIGINAL: gkamysz
I usually go to the OS site first to get part numbers and then to Tower.
Part list for the FS-48:
http://osengines.com/parts/xr35800.html
Usually the needle isn't listed with the engine. Instead, you need to get the carb number and look there. Here's a page showing carbs:
http://osengines.com/parts/discontinued.html
And the listing of parts for the FS-48 carb:
http://osengines.com/parts/xr45881000.html
AMA 87959
Hide Signatures
(in reply to gkamysz)
       Post #: 8
RE: need a needle valve for an OS .48 surpass - 10/29/2011 10:03 PM
w8ye
Score: 318
Status: offline
The only part they have is the needle valve itself
Original AMA #31261
Hide Signatures
(in reply to piper_chuck)
       Post #: 9
RE: need a needle valve for an OS .48 surpass - 10/30/2011 3:17 PM
Vertical3-D
Score: 100
Status: offline
if the needle is only 7 bucks I may as well just fix that, I have a list to order from tower in the coming weeks so I'll just go that route, the plane the engine is going on now is an old trainer that I'm converting to tail dragger for a good beater/bush flying plane, my cub is also getting real flaps in its rebuild as I use that for r/c bush flying as well
Hide Signatures
(in reply to w8ye)
       Post #: 10
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> need a needle valve for an OS .48 surpass
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.141RCU1
