RE: ***CUB BROTHERHOOD***    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: ***CUB BROTHERHOOD*** Page: <<   < prev  20 21 [22] 23 24 25 26 27 28 29   next >   >>
Login
RE: ***CUB BROTHERHOOD*** - 3/18/2012 12:24 PM
cannonball200
Score: 105
Last Login: 5/18/2013
Status: offline
I am getting close to having my Hanger 9 J-3 Cub ready to fly. I have had it for over 2 1/2 years and started putting it together, but crowded the Waco YMF5 in and finished it instead. I like a few things yet including the windows and wing work. It should be flyable in a week or so. It has a DLE 20 with stock muffler. I am ordering a set of Dubro cub treaded 1/4 scale air up tires/wheels for it. Dubro still have those but you have to call them to order because they are not advertised because of a legal issue with the Goodyear name on them a few years ago.
Eddie
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
cannonball200
Waco" Brother #191 @ Cub Brother #122
Hide Signatures
(in reply to Cub Man)
       Post #: 526
RE: ***CUB BROTHERHOOD*** - 3/18/2012 8:01 PM
mrwad
Score: 100
Last Login: 5/14/2013
Status: offline
Great job cannonball !!
One question....I have a 1/4 scale hanger 9 as well. I didn't want to have to open the door every time I turned the receiver on or off. Has anyone mounted the switch OUTSIDE the plane ? If so where is a good spot for this. The double wall construction makes it a bit of a problem......
Thanks, Don
< Message edited by mrwad -- 3/19/2012 12:51 AM >
Hide Signatures
(in reply to cannonball200)
       Post #: 527
RE: ***CUB BROTHERHOOD*** - 3/18/2012 9:31 PM
acerc
Score: 221
Last Login: 5/26/2013
Status: offline
This is not a hanger-9 but it's how I did mine.
Click for fullsize
Click for fullsize
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to mrwad)
       Post #: 528
RE: ***CUB BROTHERHOOD*** - 3/19/2012 12:02 AM
tenspeed59
Score: 100
Last Login: 2/25/2013
Status: offline
I guess I need to ask the OP or someone about a Cub Brotherhood number perhaps???....I have a 1/4 scale SIG Piper Cub with the two piece wing...no functional door tho due to this kits age....thats how they rolled back then I suppose.
Mark
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
"There are more planes in the ocean than submarines in the sky"
Club Saito Member # 777, Cub Brotherhood #124
Hide Signatures
       Post #: 529
RE: ***CUB BROTHERHOOD*** - 3/19/2012 12:25 AM
rafeeki
Score: 101
Last Login: 5/22/2013
Status: offline
Where did u get those pins with retainers holding down the cowl pl? Or who makes them?  What are they called?
Rafeek
Hide Signatures
(in reply to acerc)
       Post #: 530
RE: ***CUB BROTHERHOOD*** - 3/19/2012 12:55 AM
acerc
Score: 221
Status: offline
Those are 8-32 bolts with the head's cut off, hole's drilled for the pin's. And the pin's are small body clip's for R/C car's. And those are functional.
Robert
Hide Signatures
(in reply to rafeeki)
       Post #: 531
RE: ***CUB BROTHERHOOD*** - 3/19/2012 1:50 AM
cannonball200
Score: 105
Status: offline
Mrwad, I was originally going to put the switches on the bottom of the cub but decided to put them inside. I'm not crazy about having to open the door to turn everything on & off either. I will try it & if I don't like them inside I can always put them outside somewhere. I put the ignition switch on the right side beside the front seat in the floor. Robert put his in an easy to get to place.
Eddie
cannonball200
Hide Signatures
(in reply to mrwad)
       Post #: 532
RE: ***CUB BROTHERHOOD*** - 3/19/2012 3:08 AM
Live Wire
Score: 6329
Status: online
I put mine on the inside of the bottom door, when you open the door and it drops down there they are.
Larry K
Larry K AMA 36417
Sig Kadet Brotherhood # 4 WACO Brotherhood #34 Cub Brotherhood 14
Hide Signatures
       Post #: 533
RE: ***CUB BROTHERHOOD*** - 3/19/2012 12:01 PM
Cub Man
Score: 100
Last Login: 5/24/2013
Status: offline
#1 Cub Man - Charles Brooks
#2 Minn Flyer - Mike B.
#3 acerc - Robert R
#4 Arup -
#5 Frequent Flyer -
#6 bikerbc -
#7 GAP RCU -
#8 rafeeki -
#9 Scirocco 14 - Mark
#10 Lins - Lindsey G
#11 CK1 – Chris
#12 Jaybird –
#13 heritageman -
#14 Live Wire - Larry K
#15 Saito18 –
#16 davidgeorge212 –
#17 WacoNut –Anthony
#18 raydar –
#19 no1isnormal –
#20 JH313 –
#21 JNorton – John
#22 FJRrider –
#23 lovetoflyguy – PJ
#24 Edwin – Edwin
#25 Lavell – Lavell
#26 crash bandicoute
#27 do335a –
#28 fred985
#29 Pa-18cub150 –
#30 cessna579 –
#31 cubcrasher –
#32 mac1va –
#33 morganflyboy –
#34 Steve Landron –
#35 mintie –
#36 Gordie M –
#37 extra-nut –
#38 snowball –
#39 eastkurt - Kurt
#40 JerryM –
#41 rcavi8or –
#42 meanrc –
#43 Rc Overkill –
#44 oldiron410 –
#45 Hill202 –
#46 weathervane – Andrew
#47 SunDevilPilot –
#48 iflyj3 – Dan
#49 gluemaster –
#50 EddieC –
#51 CanDo – Les
#52 dabigboy – Matt
#53 suduchandi@gmail.com
#54 woodworm –
#55 skipb
#56 mrdhub – Dan
#57 Homer712
#58 scaleman57 –
#60 psheffield
#61 quiltsfly
#62 G.Barber
#63 bobbailey
#64 scflyboy
#65 Cub Flyer Fresno
#66 FILE IFR - Mike T
#67 talob – Mike
#68 Lowvoltage – Joe
#70 Glyder – Chuck
#71 smkrclfyer –
#72 jeffEE
#73 GW –
#74 lever02
#75 AB Bob – Bob
#76 rede2fly –
#77 Barn-E-Stormer
#78 Ray S. –Ray
#79 Daniel-EL
#80 ExcaliburIII – Richard Longfellow
#81 jrb1 -
#82 on_your_six –
#83 BGCombs
#84 RevGQ
#85 jkr_1100
#86 Dope Fiend
#87 paero-RCU
#88 .50cal
#89 mrshea - Phil
#90 Cougar-RCU
#91 glenladen
#92 cublover
#93 lowbubba
#94 steve
#95 Gray Beard
#96 roaddog2
#97 biam
#98 rcpilotaviator
#99 funtana1
#100 rcavi8or
#101 GPutt33
#102 actionjackson
#103 sj3cub
#104 dreamwever
#105 phatbob02
#106 igoren
#107 N1EDM
#108 mrwad – Don
#109 dirtrod – Ty
#110 HawkI
#111 redkav
#112 GerKonig _Gerry
#113 SCOTT42
#114 5blue
#115 crazystick
#116 3rd time Richard
#117 chevyman962000
#118 Mrj3cub
#119 Oldflyer2
#120 rogergh
#121 TEAMERICA
#122 cannonball200
#123 TripleDeucer
#124 tenspeed59 - Mark
The Cub Den, www.thecubden.org
Cub Brother #1 Ultimate Brother #3 Waco Brother #120
Hide Signatures
(in reply to Live Wire)
       Post #: 534
RE: ***CUB BROTHERHOOD*** - 3/19/2012 12:05 PM
Cub Man
Score: 100
Status: offline
For the cowl pins, Dubro makes some 4-40 rigging couplers You will need 3 packs of Dubro #618 4-40 Rigging Couplers (4/pkg) for the pins you can find them at most hardware stores Pop over to my site and look in the J3/L-4 related for mounting a cowl.
Hide Signatures
       Post #: 535
RE: ***CUB BROTHERHOOD*** - 3/20/2012 5:10 AM
rcjunky67
Score: 100
Last Login: 9/12/2012
Status: offline
Greetings ... my name is robert ,and I've got a GP .60 size cub kit  with a 91" wing and I've also got the float kit to go with it that I'm getting ready to start on in about a month. Not to be presumtiuous , but I sure woul like to join the brotherhood , if I could. It would seem that #125 would be the next in line. this will be my first full kit build , and I'm working on my shed trying to put together a nice flat building surface .I'd really like to build jigs for the wing and  fuse,something that could be used in future builds as well. Any ideas would really be appreciated. I'm aware that theres several on the market , but I'm a singal dad on a tight budject, and I sure would like to build these myself. Any help would be greatly appreciated. thank's
Robert,AMA#947232 waco brotherhood #222
Hide Signatures
       Post #: 536
RE: ***CUB BROTHERHOOD*** - 3/20/2012 11:59 AM
Cub Man
Score: 100
Status: offline
#3 acerc - Robert R
#4 Arup -
#5 Frequent Flyer -
#6 bikerbc -
#7 GAP RCU -
#8 rafeeki -
#11 CK1 – Chris
#12 Jaybird –
#13 heritageman -
#15 Saito18 –
#18 raydar –
#19 no1isnormal –
#20 JH313 –
#21 JNorton – John
#22 FJRrider –
#24 Edwin – Edwin
#25 Lavell – Lavell
#27 do335a –
#28 fred985
#29 Pa-18cub150 –
#30 cessna579 –
#31 cubcrasher –
#32 mac1va –
#33 morganflyboy –
#34 Steve Landron –
#35 mintie –
#36 Gordie M –
#37 extra-nut –
#38 snowball –
#39 eastkurt - Kurt
#40 JerryM –
#41 rcavi8or –
#42 meanrc –
#43 Rc Overkill –
#44 oldiron410 –
#45 Hill202 –
#47 SunDevilPilot –
#48 iflyj3 – Dan
#49 gluemaster –
#50 EddieC –
#51 CanDo – Les
#52 dabigboy – Matt
#54 woodworm –
#55 skipb
#56 mrdhub – Dan
#57 Homer712
#58 scaleman57 –
#60 psheffield
#61 quiltsfly
#62 G.Barber
#63 bobbailey
#64 scflyboy
#67 talob – Mike
#70 Glyder – Chuck
#71 smkrclfyer –
#72 jeffEE
#73 GW –
#74 lever02
#75 AB Bob – Bob
#76 rede2fly –
#77 Barn-E-Stormer
#78 Ray S. –Ray
#79 Daniel-EL
#81 jrb1 -
#82 on_your_six –
#83 BGCombs
#84 RevGQ
#85 jkr_1100
#86 Dope Fiend
#87 paero-RCU
#88 .50cal
#89 mrshea - Phil
#90 Cougar-RCU
#91 glenladen
#92 cublover
#93 lowbubba
#94 steve
#95 Gray Beard
#96 roaddog2
#97 biam
#98 rcpilotaviator
#99 funtana1
#100 rcavi8or
#101 GPutt33
#102 actionjackson
#103 sj3cub
#104 dreamwever
#105 phatbob02
#106 igoren
#107 N1EDM
#108 mrwad – Don
#109 dirtrod – Ty
#110 HawkI
#111 redkav
#113 SCOTT42
#114 5blue
#115 crazystick
#117 chevyman962000
#118 Mrj3cub
#119 Oldflyer2
#120 rogergh
#121 TEAMERICA
#122 cannonball200
#123 TripleDeucer
#124 tenspeed59 – Mark
#125 rcjunky67 - Robert
Hide Signatures
(in reply to rcjunky67)
       Post #: 537
RE: ***CUB BROTHERHOOD*** - 3/21/2012 2:47 AM
rcjunky67
Score: 100
Status: offline
well thank you ver'much... glad to be a part of this killer thread. now , as I mentioned before , I've got a great planes .60 size cub kit that I can build with a standard wing , 91" ,or as a clipped wing ,89" .  my question is this , does anyone have any experience with this kit. just wandering if theres anything I may need to pay special attention to? it looks to be a pretty straight forward build , but because here ,  I feel I'm in the midst of greatness , it sure is comforting to know that I can ask yall a question or two along the way ...    once I get my hanger/shed ready to start this project , I'll try to document as much as I can along the way. I'd like to try a different color scheme if thats ok . I think theres been more cub yellow model planes buit by this point than the real thing. and after being an auomotive tech for twenty years now , Its getting harder for me to see that kind of plane ,mono colored covering scheme . top looks like the bottom at a distance ya know. thanks again
Hide Signatures
       Post #: 538
RE: ***CUB BROTHERHOOD*** - 3/21/2012 12:18 PM
acerc
Score: 221
Status: offline
Robert, I have built many of thuse kit's over the years. They are a clean kit, good instruction's, and very scaleable. Just take your time. And plan ahead for any mods you may want to make. We here are alway's willing to help. I don't know much but your welcome to it.
Robert
Hide Signatures
       Post #: 539
RE: ***CUB BROTHERHOOD*** - 3/21/2012 12:54 PM
Cub Man
Score: 100
Status: offline
Feel free to ask away. after all we are a bunch of Cub lovers!!!!!! I have a Goldeburg Cub that is all yellow with a black sunburst on the wing and tail. This pattern is only on the top. No set rule that it has to be all Cub Yellow.
Hide Signatures
(in reply to acerc)
       Post #: 540
RE: ***CUB BROTHERHOOD*** - 4/22/2012 12:22 AM
WacoNut
Score: 175
Status: offline
Here are a few pics from flying my 1/3 AMR J-3 Cub this past Thursday.
The plane flew great but I goofed up the landing and landed short in the tall grass causing a ground loop and a broken prop. I just finished unstalling a new prop. I will be taking the Cub to the Bluegrass Fly-In on May 5th, anyone else going?
Later!!
Anthony
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
       Post #: 541
RE: ***CUB BROTHERHOOD*** - 4/22/2012 1:05 AM
chuck l
Score: 108
Status: offline
Waconut,
Nice plane, sorry about the prop. Hopefully there wasn't any damage to the plane itself. I'm waiting to here back from Michel on a couple of questions, then will place the order for the 1/3 scale Cub.
Chuck
WACO Brother #233
Hide Signatures
(in reply to WacoNut)
       Post #: 542
RE: ***CUB BROTHERHOOD*** - 4/22/2012 1:46 AM
WacoNut
Score: 175
Status: offline
Hi Chuck,
No damage at all to the plane. It just dropped a wing tip into the tall grass and tourqued around to the right and nosed over onto the prop. The blade split down the middle. The engine was at idle at that point.
That is the 1st prop I have broken in years, guess I was due.
If you run into any questions during the build don't hesitate to ask. It is a pretty straight forward build.
Later!!
Anthony
Hide Signatures
(in reply to chuck l)
       Post #: 543
RE: ***CUB BROTHERHOOD*** - 4/22/2012 3:34 PM
cannonball200
Score: 105
Status: offline
I flew my new Hanger 9 1/4 J-3 Cub yesterday with the DLE 20 on it. It has plenty of power and will fly scale below 1/2 throttle. It weighs 16 1/2# with no fuel. It has the stock 17 oz tank. It has the Dubro air up scale goodyear tires. It flys awesome.
Eddie
Click for fullsize
Click for fullsize
cannonball200
Hide Signatures
       Post #: 544
RE: ***CUB BROTHERHOOD*** - 4/22/2012 3:45 PM
bikerbc
Score: 116
Last Login: 5/25/2013
Status: online
RCJunky I have a fuse jig that is fairly easy to build that I could take a few pics of if you like..It really helps me to build my fuselage's straight..I think the original design came out of the old RCM mag yrs ago . I sort of copyied what I rembered so its not my idea but it sure works ...
Click for fullsize
Click for fullsize
Click for fullsize
Ken , Biker BC Cub Brother #6 UltraSport BrotherHood # 100 Tiger Club # 7
Hide Signatures
       Post #: 545
RE: ***CUB BROTHERHOOD*** - 4/23/2012 3:10 PM
Cub Flyer Fresno
Score: 115
Status: online
quote:
ORIGINAL: cannonball200
Eddie
Hey there Eddie, what kind of milage are you getting with the DLE-20?  From what I've been hearing it's about two minutes per ounce.  I'm curious because I'm installing a 10 oz. tank.  Glad to hear that 20 is plenty of power.  Now I can't wait to get mine done!
Take care,
David
Cub Brotherhood #65
Hide Signatures
       Post #: 546
RE: ***CUB BROTHERHOOD*** - 4/23/2012 3:48 PM
cannonball200
Score: 105
Status: offline
I can not really answer your question honestly. I think I flew it around for about 5 minutes and could see the tank level was only down about 1/4 ". Of course the plane slants down at the rear but the 17 oz tank had a lot to go. It can be flown gracefully at 1/3 throttle very scale.
Eddie
cannonball200
Hide Signatures
(in reply to Cub Flyer Fresno)
       Post #: 547
RE: ***CUB BROTHERHOOD*** - 4/23/2012 5:44 PM
Cub Man
Score: 100
Status: offline
Good to see reports of Cub's int he air!!!! I have been working on a biplane getting it ready to fly again. For all of you around the KY area i have the Cub and Classics coming up first of May. Sig, Balsa USA, Tower Hobbies and Bob smith Industries have stepped up and made donations for this event.
Hide Signatures
       Post #: 548
RE: ***CUB BROTHERHOOD*** - 4/23/2012 10:14 PM
WacoNut
Score: 175
Status: offline
I am looking forward to the event.
I am going to try and get out for another flying session this weekend with the new prop and put some more stick time in. I don't want to make a fool of myself at the Fly-In
Later!!
Anthony
Hide Signatures
       Post #: 549
RE: ***CUB BROTHERHOOD*** - 5/3/2012 3:45 PM
VincentJ
Score: 145
Status: offline
Hey Charles now that I'm on the home stretch on my Cub I should request entry into the brotherhood...#126 ?
VJ
Hide Signatures
       Post #: 550
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.484RCU1
