RE: ***CUB BROTHERHOOD***    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> RE: ***CUB BROTHERHOOD*** Page: <<   < prev  25 26 [27] 28 29 30 31 32 33 34   next >   >>
Login
RE: ***CUB BROTHERHOOD*** - 11/5/2012 6:29 PM
do335a
Score: 105
Last Login: 5/18/2013
Status: offline
quote:
ORIGINAL: rafeeki
I have a Sig Clipped wing 1/4 scale Cub kit that I will be starting soon. Any tips on making it a full 1/4 scale Cub? Is it just a matter of extending the spars and adding a few ribs to achieve the full 110'' or so wingspan?
Rafeek
The Sig 1/4 size Cubs are what we call stand off scale. There are tons of things which separate them from true scale, both clipped wing and full span versions.
In any case, I've had the clipped wing version for many, many years and also flown full size span versions. IMO, they should all be clipped. You can get lots more performance from it clipped wings when you want while still having a floater if you wish.
Hide Signatures
(in reply to rafeeki)
       Post #: 651
RE: ***CUB BROTHERHOOD*** - 11/5/2012 11:41 PM
WacoNut
Score: 175
Last Login: 5/24/2013
Status: offline
quote:
ORIGINAL: rafeeki
Rafeek
The wing needs to be extended at the root. The clipped wing version builds as a one piece wing and the full span builds as a 2 piece wing. A full length 1 piece wing would be a bear. I was contantly hitting my clipped wing on everything in the shop and while transposrting. I would build the clipped wing and let it go at that. They fly great.
Anthony
_____________________________
WACO Brother #30 Cub Brother #17
It''s not the hours you put in It''s what you put into the hours.
Hide Signatures
       Post #: 652
RE: ***CUB BROTHERHOOD*** - 11/5/2012 11:49 PM
rafeeki
Score: 101
Last Login: 5/22/2013
Status: offline
Thanks, you make a lot of sense
Other than the wingspan are there other differences thou?
Hide Signatures
(in reply to WacoNut)
       Post #: 653
RE: ***CUB BROTHERHOOD*** - 11/5/2012 11:55 PM
WacoNut
Score: 175
Status: offline
I think just being built as one and two piece. Of course the cabin top is different for the 2 types. It would be much easier to make a full span a clipped wing versus a clipped wing a full span.
Hide Signatures
       Post #: 654
RE: ***CUB BROTHERHOOD*** - 11/6/2012 12:28 AM
Cub Flyer Fresno
Score: 115
Status: offline
Here's one.  Let's say you build a full span Cub, fly it for a year or so, then decide to clip the wings.  Not having that much experience (but learning quickly) how much would be involved?
And, by the way, if I were to do this again, I think even with a clipped wing, I'd want to make the center section part of the fuse with a wing tube for attachment.  It just seems more practical and probably a lot easier to transport.
Cub Brotherhood #65
Hide Signatures
       Post #: 655
RE: ***CUB BROTHERHOOD*** - 11/6/2012 12:39 AM
WacoNut
Score: 175
Status: offline
On the full scale Clipped Wing Cub they basically shortened the wings 1-1/2 bays at the root of the wing panels. You could do the same with the model by stripping the covering and moving the root rib in by the proper distance. This of course would require surgery to all the sheeting as well. I would just order a wing kit for the full wing and build 2 clipped wing panels and you could have 2 sets of wings ready to fly and you can choose which set for the day of flying. You would also have to build a new set of struts for the clipped wing.
Later!!
Anthony
Hide Signatures
(in reply to Cub Flyer Fresno)
       Post #: 656
RE: ***CUB BROTHERHOOD*** - 11/6/2012 12:43 AM
Cub Flyer Fresno
Score: 115
Status: offline
I had actually considered buying the wing kit.  And having a spare wing probably wouldn't hurt either.  I think I could probably build and finish a wing in under two years.
Thanks!
David
< Message edited by Cub Flyer Fresno -- 11/6/2012 3:46 PM >
Cub Brotherhood #65
Hide Signatures
       Post #: 657
RE: ***CUB BROTHERHOOD*** - 11/6/2012 9:50 AM
oldfartpilot
Score: 100
Status: offline
I now have 3 Cubs, a 72" blue/white sunburst w/ Saito 72, a 72" L4 Grasshopper w/Saito 72 and a 90" still in the box that I've not decided on the power plant yet, ( Magnum 1.60 twin FS, 91 FS or a gas engine. Can I become a member of the Cub Brotherhood?
Hide Signatures
       Post #: 658
RE: ***CUB BROTHERHOOD*** - 11/15/2012 2:06 AM
Rv7garage
Score: 128
Last Login: 4/26/2013
Status: offline
Today was one of those extra-crispy Midwest autumn days. 42* at 4pm, dead calm, late afternoon light changing from yellow-orange to salmon. Saito 90-TS twin purring away in the nose of my Sig 1/5-scale... loops & hammerheads, touch-n-goes, slips & crabs, lazy spins. A perfect day!
#26 Club Saito ***CUB BROTHERHOOD*** #86
My full-scale build: www.rv7garage.blogspot.com
Hide Signatures
(in reply to oldfartpilot)
       Post #: 659
RE: ***CUB BROTHERHOOD*** - 11/15/2012 2:33 AM
rafeeki
Score: 101
Status: offline
Oldfarpilot,
Which kit is the 90"? I am looking for a Cub for my Gemini 120 twin.
Rafeek
Hide Signatures
       Post #: 660
RE: ***CUB BROTHERHOOD*** - 11/15/2012 4:49 PM
Rv7garage
Score: 128
Status: offline
My Sig 1/5-scale is 88", non-clipped. The 120 Twin would be a perfect motor for this airframe!
Hide Signatures
       Post #: 661
RE: ***CUB BROTHERHOOD*** - 11/15/2012 5:45 PM
rafeeki
Score: 101
Status: offline
Thanks.
I already have the 1/6th running on an OS 40
Hide Signatures
(in reply to Rv7garage)
       Post #: 662
RE: ***CUB BROTHERHOOD*** - 11/24/2012 3:20 PM
bikerbc
Score: 116
Last Login: 5/23/2013
Status: online
I am using a Gemini 160 in my 1/4 scale BUSA Cub and planning on getting an ASP 160 for my new Hanger 9 1/4 scale P18 ... The Gemini 160 is lots of power for a 1/4 cub if its not over weight
Ken , Biker BC Cub Brother #6 UltraSport BrotherHood # 100 Tiger Club # 7
Hide Signatures
       Post #: 663
RE: ***CUB BROTHERHOOD*** - 11/25/2012 2:39 AM
ARUP
Score: 134
Status: offline
Just finished rib stitches and tapes. Wing tanks (ply), cap handles and filler neck ring (lithoplate) epoxied in place. The PA-12 gets red paint after placing masks.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to bikerbc)
       Post #: 664
RE: ***CUB BROTHERHOOD*** - 11/26/2012 2:13 AM
acerc
Score: 221
Status: offline
Damn ARUP! I thought I did some scale work but your making mine look like childsplay. Real nice!
Robert
Cub Brotherhood #3\ Ryan STA Brotherhood #4
Hide Signatures
(in reply to ARUP)
       Post #: 665
RE: ***CUB BROTHERHOOD*** - 12/7/2012 7:06 PM
Cougar-RCU
Score: 100
Last Login: 4/6/2013
Status: offline
OK guys , I want to find a 1/4 scale cub ARF... and the only one I am seeing for about $379 is
the world model ones.. I do have a 20 size from them seems to be OK . I just wanted to check
with you folks first about this. and to see if there was any other options. I am liking the red star-burst one's.
I have also noticed that tower doesn't sell the kits anymore.
Jeff
** CUB BROTHERHOOD ** #90
Hide Signatures
(in reply to acerc)
       Post #: 666
RE: ***CUB BROTHERHOOD*** - 12/7/2012 8:30 PM
acerc
Score: 221
Status: offline
Jeff, Hanger-9 has a nice 1/4 scale cub.
Of course you could always opt for this one.   http://vogelsang-aeroscale.com/severinj3.html
Robert
Hide Signatures
(in reply to Cougar-RCU)
       Post #: 667
RE: ***CUB BROTHERHOOD*** - 12/7/2012 8:35 PM
Cub Flyer Fresno
Score: 115
Status: offline
HA!  Good one Ace!
I second Roberts suggestion of the Hanger 9.  It's nice looking...  for an ARF.
Cub Brotherhood #65
Hide Signatures
(in reply to acerc)
       Post #: 668
RE: ***CUB BROTHERHOOD*** - 12/7/2012 9:10 PM
rafeeki
Score: 101
Status: offline
Take a look at the 1/4 super cub arf Hobby King is selling. Looks like the one on the cover of the latest issue of Model Airplane News. Its a steal
Hide Signatures
       Post #: 669
RE: ***CUB BROTHERHOOD*** - 12/7/2012 9:59 PM
cannonball200
Score: 105
Status: offline
Hanger 9 1/4 scale ARF J-3 Piper Cub is a good one. I have had all 3 versions they have made and the latest one is nice. It has scale seats, panel, opening door/window, scale landing gear, etc. I made the throttles, control sticks, etc. It is powered with a DLE 20 and weights 16#S. Flies awesome!!!!
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
cannonball200
Waco" Brother #191 @ Cub Brother #122
Hide Signatures
       Post #: 670
RE: ***CUB BROTHERHOOD*** - 12/7/2012 10:56 PM
Cougar-RCU
Score: 100
Status: offline
Very nice photos, the hanger 9 indeed looks awesome but its out of my $$ range...
Then I found this and wow.. I guess it IS CHEAP LOL
http://www.hobbyking.com/hobbyking/store/__17992__Hobbyking_Piper_J_3_Cub_1_20_Glow_2310mm_ARF_.html
But looks OK
Now the red starburst from world is $379
This above one is only $159 how can they do that?
Hide Signatures
(in reply to cannonball200)
       Post #: 671
RE: ***CUB BROTHERHOOD*** - 12/7/2012 11:02 PM
Cougar-RCU
Score: 100
Status: offline
rafeeki $159.00 is that correct? sheesh maybe I should get two of them LOL
Hide Signatures
       Post #: 672
Cub Flyer Fresno
Score: 115
Status: offline
Ever hear of sweat shops?  Slave labor?  Uh... what else do you call it...?
Don't get me wrong, I buy the stuff myself out of necessity.
As for the Hanger 9 BARF... excuse me!  I mean ARF,  that makes me sick.  All the work I'm going to!  But I can say "I made this!"
Take care,
David
Cub Brotherhood #65
Hide Signatures
       Post #: 673
RE: ***CUB BROTHERHOOD*** - 12/7/2012 11:06 PM
Cougar-RCU
Score: 100
Status: offline
David I do still build though :-) Sorry
Just wanted to play around with a larger size
I did build the rest of my cubs. kinda getting tired and old LOL
Hide Signatures
       Post #: 674
RE: ***CUB BROTHERHOOD*** - 12/7/2012 11:10 PM
Cub Flyer Fresno
Score: 115
Status: offline
Eh, just trying to join the rest of the building crowd.  I've had five ARF's total and two builds.  The Cub is my first and last so far (I'm slow with this one) and it's my first BIG build.  I'm LOVING it!
I'll be interested to here what the HK looks like and how it compares to the H9!  Keep us informed!
Cub Brotherhood #65
Hide Signatures
       Post #: 675
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.422RCU1
