1QwkSport2.5r
Score: 155 Joined: 10/15/2006 Last Login: 5/23/2013 From: Cottage Grove,
MN, USA Status: offline
quote:
ORIGINAL: mechanike hey 1Q or other good peeps,,,,,,,,,,,,,,,,,,,,,,,,,,is it me or does nitro''s run like poop below 60 degrees,,,,,,,,,,,,,,,,,,,,,,, Nitros will run like poo in the winter if the tuning isnt right. I run my nitros in the winter when its 20-30°F outside every winter and they run fine. Fuel goes a little quicker because of the richer fuel mixture but otherwise its fine. And as far as the trans. gears I was referring to - they are just that. Gears in the transmission. If I was talking about spur gears/clutchbells, I would have said that instead. I ran one of my airplane engines on my test stand last winter and at 21°F, My little Thunder Tiger .46 hit its highest peak RPM on a 9x7 that its ever ran. That engine seems to like the cold weather better almost....
_____________________________
*Real* glow fuel is made with Methanol, Nitromethane, and Castor oil.
Hide Signatures
