RE: Meister Scale P 47 - step by step    Gallery
Logged in as Guest
Users viewing this topic: pittss3s
    Search This Thread
Printable Version
AZ Model Aircrafters 1/4 Scale Albatross D.V - RTF
Seller:  Dumb Thumb
Details:   $2,500.00   |  5/16/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Meister Scale P 47 - step by step
Page: <<   < prev  14 15 16 17 18 19 20 21 [22] 23   next >   >>
Login
RE: Meister Scale P 47 - step by step - 8/12/2012 8:13 PM
mirce
Score: 151
Last Login: 5/20/2013
Status: offline
Hello Pete, somewhere in my topic I wright about "my system" how I put engine on the fuselage.
If you want MVVS (Evolution) propeller shaft to get in the middle of the dummy engine hole, you need first to put dummy engine in the cowl. Then set cowl on the fuselage. For that you need to have aluminum cowl carriers. That is first step.
Second step is to put engine on the front side of the mount and set mount carriers on back side. You can't made holes on the fire wall without all those parts...
Holes on the wire wall are 6 mm, but holes worth nothing without the engine mount. You can't made it precisely on the fire wall without all those parts...
In mean time I add lead in front on the cowl (1 kg) and three 100 gr leads on the back side of the dummy engine.
This leads I made removable in the case to need to take down some lead after first few flights...
Tomorrow I will sent first Detail Set for P 47.
Detail Set contains all details for fuselage, wing and tail surfaces.
In Detail Set you get more dummy screws (dummy screws you can get in Mirce Finish Set also, with panel lines and rivets...)
How details look on Thunderbolt you can see in this topic from post 415, 442, 446, 447...
Regards
Mirce
P.S. Thank you Kevin (Melchizedec) for kind words. Engine angle is for eliminate propeller rotation torque...
_____________________________
Rivets, Screws, Panel lines, Detail & Finish Sets, Paint Masks and other equipment for scale warbirds - www.nsmodelers.rs
Hide Signatures
(in reply to scrutineer)
       Post #: 526
RE: Meister Scale P 47 - step by step - 8/13/2012 5:47 PM
ESSAR
Score: 100
Last Login: 4/14/2013
Status: offline
Hey Mirce, Great build, I am anxiously awaiting your maiden flight and I wish you the best of luck when the time comes.
I wanted to ask; Could your finishing decal set be scaled down for the the Top Flite giant 1/6th  thunderbolt?
Essar.
Hide Signatures
(in reply to mirce)
       Post #: 527
RE: Meister Scale P 47 - step by step - 8/13/2012 10:27 PM
mirce
Score: 151
Status: offline
Thank you Essar, I'm waiting maiden flight too.
Today my friend, who made my trailer, visit me and take measure for P 47 trailer stand. Hope in next few day it will be finished, so after that no reasons for more waiting.
Engine work fine, I get 5900 rpm with propeller Falcon 26x10. In Evolution manual wright that best performance engine will have when you get 6400 rpm on the ground. Hope that I will get those numbers after engine more and more work time...
For now, engine work nice, it start very easy, idle is good 1300 - 1400 rpm, transition from idle to full rpm are good, and on full speed engine work fine.
Propeller this size is recommended from Evolution, and it is smaller propeller size.
In next day or two I will try this engine with Pitts style muffler, just to check numbers...
And at the end, Essar, yes I can made smaller detail set for Top Flite P 47. I will change size of P 47 in my Corel Draw file, from 2,6 meter wing span (Meister) on 2,17 meter (Top Flite).
Few days ago I send one Mirce Finish set for 1/6 scale. Difference is in smaller rivets ( 1,6 mm diameter), so I can offer that to you too.
All the best
Mirce
Hide Signatures
(in reply to ESSAR)
       Post #: 528
RE: Meister Scale P 47 - step by step - 8/14/2012 1:38 AM
redbiscuits
Score: 130
Status: offline
Mirce,
I did receive the finish set for my TF Giant P-47. I was in Mexico for the past 2 weeks on vacation and I just picked it up from my friend who went to the post office and picked it up for me. I am VERY happy with the quality of everything that you provided.
Thank you so much.
Gary-Waco Brother#171 If the build gets tough, always refrain from throwing things! ARCA, Austin Tx. www.austinrc.org
Hide Signatures
(in reply to mirce)
       Post #: 529
RE: Meister Scale P 47 - step by step - 8/14/2012 8:52 AM
mirce
Score: 151
Status: offline
Thank you Gary...
Hide Signatures
(in reply to redbiscuits)
       Post #: 530
RE: Meister Scale P 47 - step by step - 8/14/2012 12:58 PM
ESSAR
Score: 100
Status: offline
Thank you Mirce I will contact you in the future when I start the project, I only hope I can build it half as nice as your's!
Thanks for sharing your very inspiring build thread, we'll have our fingers crossed for your maiden flight.
Essar.
Hide Signatures
(in reply to mirce)
       Post #: 531
RE: Meister Scale P 47 - step by step - 8/14/2012 8:33 PM
scrutineer
Score: 100
Last Login: 2/24/2013
Status: offline
hi morice... i would like to order off you .........big flap hinges/// finish set///rivet set///engine mounting set/// cowl mounting set///detail set... please can you e,mail me the total price including post to wales uk. thanks again pete
Hide Signatures
(in reply to mirce)
       Post #: 532
RE: Meister Scale P 47 - step by step - 8/14/2012 10:08 PM
mirce
Score: 151
Status: offline
Thanks Essar and Pete...
Pete yes I can prepare all to you, but I will send you e-mail with details...
Today I get metal carrier for trailer in which I will put fuselage. Construction I have of earlier, from my Top Flite P 47, so my friend who made it, haven't a lot to work to change it.
New carrier must be little longer and wider...
When I made trailer, few years ago, I made it bigger and wider, than I need at that time.
Tonight, when I put Meister P 47 inside, I saw that trailer is just 2" longer than fuselage. I think that I will take down spinner in transport...
Job about making fuselage carrier was last big job in this building, and hope it will be finish tomorrow.
Tomorrow I will made last engine test and at Saturday, if temperature and wind be OK, I will made maiden flight...
Regards
Mirce
Hide Signatures
       Post #: 533
RE: Meister Scale P 47 - step by step - 8/15/2012 2:21 PM
Scott Prossen
Score: 106
Last Login: 5/19/2013
Status: online
Good luck my friend with the maiden. I wish you a 1000 great flights and I know you will love to fly this plane. The more you fly and get to know the true envelope of the Meister 47 the more fun you will have. Anytime you see guys flying a big 47 very very slow it turns out to be a Meister. Great airfoil and so fun to fly! I have enjoyed mine for a number of years now and wish I had time to fly it every day!
Congrats on a great build and finished product.....it really has been fun to watch and great work on your part. Thanks for taking all the time and effort to put this all on line. I know it can be a lot of work and you sure have done a great job educating us.
We all wish you well on saturday and are excited to hear the good news!
Scott
Hide Signatures
(in reply to mirce)
       Post #: 534
RE: Meister Scale P 47 - step by step - 8/15/2012 3:08 PM
glazier808
Score: 291
Status: online
+1!!! Well said Scott!
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
(in reply to Scott Prossen)
       Post #: 535
RE: Meister Scale P 47 - step by step - 8/15/2012 5:59 PM
rcyogi
Score: 100
Status: offline
Mirce, Wil you have a similar detail package for a TF 1/5 P51?
I will fly until they pry the transmitter from my cold dead hands!
Hide Signatures
(in reply to glazier808)
       Post #: 536
RE: Meister Scale P 47 - step by step - 8/15/2012 7:48 PM
mirce
Score: 151
Status: offline
Rcyogy, unfortunately I haven't.
Detail set for P 47 is first set I made because I made that model. I can change scale from 1/5 to 1/6 or some other...
I wasn't made P 51.
Next Mirce Detail set will be for Zero and after that for Foke Wulf - that's my next projects...
Mirce
Hide Signatures
(in reply to rcyogi)
       Post #: 537
RE: Meister Scale P 47 - step by step - 8/16/2012 2:07 AM
mirce
Score: 151
Status: offline
Today I finished work on my trailer, so P 47 fuselage is ready for transport...
Most important thing in trailer are rails in which my fuselage carrier slide to front and back.
This allowed me to put fuselage a lot of easier in and out of the trailer.
Screws in the front don't allow carrier to go in front...
... and rear screws are removable...
I cut plastic part for fixing Hellcat spinner and that give me more space in the front for spinner of P 47...
Last night I made test how much rpm and traction I have with my exhaust system, compare with exhaust system from factory (Evolution).
With propeller Falcon 26 x 10 and my exhaust system, engine give 5760 rpm and 16,75 kg of traction.
We change exhaust...
... warm up engine and get 6000 rpm and 17,5 kg of traction. As we can see factory exhaust is better, and in first moment I think to change my system with that, but after thinking and made some calculation I saw that difference is just 4%.
With my exhaust Thunderbolt weight and tractive force is 76% vs 81% with factory exhaust.
Mayne reason why not to put factory exhaust is because I need to made one big hole in the middle of the left cowl side, and that will be pretty ugly...
With almost 17 kg of traction, this model will fly very nice. Can't forget, in the air engine will be little relieved, and after every flight it will be more and more stronger...
Unfortunately I haven't some smaller propeller like 25 x 10 or some Majzlik, with thinner blades, to try measure with that.
In Evolution manual wright that best torque is between 6200 - 6600 rpm.
Regards
Mirce
Hide Signatures
(in reply to mirce)
       Post #: 538
RE: Meister Scale P 47 - step by step - 8/16/2012 4:26 AM
dubs1946
Score: 100
Status: offline
Hi Mirce, i have been following your build from the beginning, very nice clean work.
Your Evo is putting out almost the same as my 3W85 i am getting 18kg thrust at about 6000 RPM with a 26X10 Chinese prop there is a bit more in my engine but those numbers do me fine.
Mine is in a T/F P47 kit build at about 35 Pounds and it really honks at those figures.
Good luck with the maiden, don't forget the video so we can all share in it.
Dave.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to mirce)
       Post #: 539
RE: Meister Scale P 47 - step by step - 8/19/2012 12:04 AM
mirce
Score: 151
Status: offline
Yesterday I made maiden flight with P 47... Oh man, this model is fantastic...
I made two flights, both was without any problem, take off is straight, P 47 run like on rails...
My biggest concern was engine power. As I wright I get 5750 rpm which is lower than 6200 - 6600 area of biggest torque. But, no problem in the air....
Best of all is landing, full flaps, throttle on idle, and landing was soooooooooo smooth... Unbelievably....
This model look like bigger, better version of Top Flite Thunderbolt.
Here is few picture from airfield, and video will be in day or two...
I am very very satisfied with flight performance.
All in all, this topic show how good Meistre design is. Building is easy, simple, model is huge, very attractive, it is big enough to add many details, and finally flying characteristic are great...
Best regards
Mirce
Hide Signatures
(in reply to dubs1946)
       Post #: 540
RE: Meister Scale P 47 - step by step - 8/19/2012 12:42 AM
hrrcflyer
Score: 121
Status: offline
Hello Mirce,
Please let me be the first to Congratulate you on your successful maiden flights. I agree with you that Meister makes a fantastic airplane, but to start with a box of wood and end up with a plane like yours , takes an incredible amount of talent and hard work on your part. I have thoroughly enjoyed following along with you from the beginning on your build and I wish you MANY year of enjoyable flights with your Jug. I think you should also be commended for your hard work in keeping uip with this build thread. It gives people like me, with far less building experience, the chance to watch a real craftsman at work.
David
Fly Safe and Have Fun ! ! !
Ultra Sport Brotherhood #22
Hide Signatures
(in reply to mirce)
       Post #: 541
RE: Meister Scale P 47 - step by step - 8/19/2012 1:41 AM
JPate147
Score: 116
Status: offline
Congratulations are definately in order - your obvious pride and happiness are well deserved. It's a fantastic model with your mods, and I too appreciate your efforts to share this with all of us.
Jerry
Hide Signatures
(in reply to hrrcflyer)
       Post #: 542
RE: Meister Scale P 47 - step by step - 8/19/2012 2:56 AM
Scott Prossen
Score: 106
Status: online
Congrats!! Mirce you deserve the great results.
Scott
Hide Signatures
(in reply to JPate147)
       Post #: 543
RE: Meister Scale P 47 - step by step - 8/19/2012 2:26 PM
frisconick
Score: 100
Last Login: 5/9/2013
Status: offline
Mirce,
So glad to hear your maiden went well. I too, want to thank you for sharing your tips, tricks, and ideas throughout this build. I still have a long way to go on mine !! Where did you end up setting the CG? I don't think I saw it here.
Nick
Corsair Brotherhood #44
Hide Signatures
(in reply to mirce)
       Post #: 544
RE: Meister Scale P 47 - step by step - 8/20/2012 2:10 AM
Shiftyeddie
Score: 100
Status: offline
Wow Mirce, you have done it!
Everything turned out great! I cant wait to see the
video.
I know this thread build is going to be a big help when I
began mine.
Hopefully you might consider another thread if you
start a different build. I enjoyed it very much
Eddie
Hide Signatures
(in reply to frisconick)
       Post #: 545
RE: Meister Scale P 47 - step by step - 8/20/2012 2:52 AM
JSZ
Score: 100
Status: online
Congrats, nise work, John
You gonna paint that?
Hide Signatures
(in reply to Shiftyeddie)
       Post #: 546
RE: Meister Scale P 47 - step by step - 8/20/2012 10:06 AM
mirce
Score: 151
Status: offline
Thank you for nice wishes...
Here is video of maiden flight...
http://www.youtube.com/watch?v=mI5DZxG_IjQ&feature=youtu.be
Regards
Mirce
Hide Signatures
(in reply to JSZ)
       Post #: 547
RE: Meister Scale P 47 - step by step - 8/20/2012 2:45 PM
ESSAR
Score: 100
Status: offline
Wow!! excellent work, congratulations and thank you for sharing this impressive build with us. Very nice!
Hide Signatures
(in reply to mirce)
       Post #: 548
RE: Meister Scale P 47 - step by step - 8/20/2012 3:02 PM
Scott Prossen
Score: 106
Status: online
First flight and words afterwards...............great great great!
Hide Signatures
(in reply to mirce)
       Post #: 549
RE: Meister Scale P 47 - step by step - 8/20/2012 4:44 PM
glazier808
Score: 291
Status: online
Loved the video....you were just a little happy, yes?
Casey
Hide Signatures
       Post #: 550
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.094RCU1
