RE: Meister Scale P 47 - step by step    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Meister Scale P 47 - step by step
Page: <<   < prev  8 9 10 11 12 13 [14] 15 16 17   next >   >>
Tower Hobbies Today's Special Offer! Brands Products
Login
RE: Meister Scale P 47 - step by step - 2/7/2012 10:54 PM
ram3500-RCU
Score: 135
Last Login: 5/22/2012
Status: offline
quote:
ORIGINAL: mirce
What to tell you guys, I am blessed with my wife...
Yes, you are.
My shop is in the basement of my home, and I, well.............do catch some flak. However, my wife is a registered nurse and has always worked the night shift. This works out well, for building, at least. We did manage to have 8 kids as well
_____________________________
Cheers,
Gary P. / use Steel Powder for ballast not lead. PM me for some.
Hide Signatures
(in reply to mirce)
       Post #: 326
RE: Meister Scale P 47 - step by step - 2/8/2012 12:18 AM
mirce
Score: 100
Status: offline
Ok, tell me what do you think about this?
http://www.rcuniverse.com/forum/fb.asp?m=10948306
Finish set for scale warbirds - panel lines, rivets, dummy screws, paint masks & other RC products - www.nsmodelers.rs
Hide Signatures
(in reply to ram3500-RCU)
       Post #: 327
RE: Meister Scale P 47 - step by step - 2/8/2012 2:03 AM
TJPro351
Score: 100
Last Login: 5/21/2012
Status: offline
quote:
ORIGINAL: ram3500-RCU
quote:
ORIGINAL: mirce
Yes, you are.
8 kids
Geez Gary....all the time you spend on your planes...you do manage your time well..... or you don't have enough planes or TV's
Hide Signatures
       Post #: 328
RE: Meister Scale P 47 - step by step - 2/8/2012 3:41 AM
ram3500-RCU
Score: 135
Status: offline
quote:
ORIGINAL: mirce
Very exciting time in a build IMO. You are doing a wonderful job, as you have done on every phase of this build.
The one piece wing with the belly pan permanently part of the wing makes for a very simple and strong wing, if transport and storage is no issue.
I saw scenes like your wintery back yard, around here last year, but not this year, thankfully. Shirtsleeves in January!!! We have hardly had any Winter.......(yet).
Cheers,
Hide Signatures
(in reply to mirce)
       Post #: 329
RE: Meister Scale P 47 - step by step - 2/8/2012 9:58 PM
mirce
Score: 100
Status: offline
I got US visa today... Can't wait to see you guys on Top Gun this year...
Regards
Mirce
Hide Signatures
       Post #: 330
RE: Meister Scale P 47 - step by step - 2/8/2012 10:22 PM
Icemanjr92
Score: 100
Status: offline
YAHOOOOOOOOO!!!!!
Dino Di Giorgio, President
Aero-accessories, Meister-Scale, WMWA
92, 94, 01, 07, 08, 10 Top Gun Champ.
Hide Signatures
(in reply to mirce)
       Post #: 331
RE: Meister Scale P 47 - step by step - 2/8/2012 11:02 PM
ram3500-RCU
Score: 135
Status: offline
quote:
ORIGINAL: mirce
Regards
Mirce
Looking forward to some quality face time. You are welcome to hang out in our tent. Our team 'Team Vought' including Dino and Kim, Steve Thomas, and Mr. Solo Props Wayne Fussell are all sharing a tent. We will have extra chairs.
Cheers,
Hide Signatures
(in reply to mirce)
       Post #: 332
RE: Meister Scale P 47 - step by step - 2/9/2012 4:43 AM
wayne d
Score: 105
Status: offline
Thats great news.
looking forward to meeting you.
Best Regards,
Wayne Fussell Pres. Solo Propellers & RC Products
Hide Signatures
       Post #: 333
RE: Meister Scale P 47 - step by step - 2/9/2012 9:43 AM
mirce
Score: 100
Status: offline
Thank you, can't wait to come to "modeling paradise"...
Mirce
Hide Signatures
(in reply to wayne d)
       Post #: 334
RE: Meister Scale P 47 - step by step - 2/10/2012 11:28 PM
mirce
Score: 100
Status: offline
Mirror, mirror on the wall...
Upper surface after second layer of epoxy resin. This side is finish, now same on other wing side...
This days I start working on my next project. This will be my new jet model, but I will made it from my plans, and hope at the end offer to the market like a kit...
More on this link: http://www.rcuniverse.com/forum/m_10948682/tm.htm
Regards
Mirce
Hide Signatures
(in reply to mirce)
       Post #: 335
RE: Meister Scale P 47 - step by step - 2/14/2012 9:52 PM
mirce
Score: 100
Status: offline
In last few days I was working on the wing bottom side. Same procedure...
Because it's here still bad weather, and car is in garage, I made model in dinning room. I was working on cowl flaps...
Next step is to instal two servos which will open and close this flaps...
Can't wait to snow melt and return in my garage...
Regards
Mirce
Hide Signatures
(in reply to mirce)
       Post #: 336
RE: Meister Scale P 47 - step by step - 2/18/2012 6:05 PM
mirce
Score: 100
Status: offline
Few days ago, after two weeks, I drove the car out from the garage. Snow start to melt, temperature is above 0 degree, so I return back to work on my P 47.
First I finished work on switch cover. After few ideas I made it on most simply way with two hinges and mechanism for closing with the spring. Aluminum plate was curved like fuselage, so everything is easy, simply, safe and fit well...
Because I want to make scale exhaust system, I was thinking how it will be best and most easy to made.
I was looking in Thunderbolt books...
...and got idea to try to made same system like was on real plane...
I must thinking about few things, there must be enough space for fixing split exhaust end, exhaust must have good cooling, and finally, with two ply plates I made connection between first and second fuselage ribs more rigid.
All in all, first I marked where I need to cut fuselage. I saw that upper top of holes will be in same level with ply in which come front wing joiner...
After sanding, I have holes ready for gluing ply plate...
Same procedure on top side (top side is here on picture, it's bottom side on fuselage)...
Than I draw and cut three holes. Middle hole will be for exhaust pipe, and left & right holes are for cooling.
Through this holes hot air will go out. Hot air are not just from exhaust, but from engine also...
In front part of side holes I made fins from aluminum plate. It's same dimension like Meister Scale give on plans. Front fin is bigger, and rear is smaller, like on real plane...
After second fin, hole will be cover with aluminum plate which will have hole in the middle. Through that hole will come out end of exhaust pipe. Those plate will be removable...
Regards
Mirce
< Message edited by mirce -- 2/18/2012 11:07 PM >
Hide Signatures
(in reply to mirce)
       Post #: 337
RE: Meister Scale P 47 - step by step - 2/18/2012 9:48 PM
misha034
Score: 100
Last Login: 5/19/2012
Status: offline
Very nice and clean instalation
Hide Signatures
(in reply to mirce)
       Post #: 338
RE: Meister Scale P 47 - step by step - 2/19/2012 6:01 AM
ram3500-RCU
Score: 135
Status: offline
Good approach to the venting and exhaust Mirce.
Cheers,
Hide Signatures
(in reply to misha034)
       Post #: 339
RE: Meister Scale P 47 - step by step - 2/19/2012 10:06 AM
mirce
Score: 100
Status: offline
Thanks Misha and Gary...
Last night I made little modifications, so this is it. I want to try to get as much as possible big area for installation exhaust system. Because that I made rear fin and aluminum plate in one piece, which can be removed with 4 screws...
In the middle of aluminum plate will be hole for exhaust pipe. Hole will be made when I get engine and find how big pipes need to be...
Regards
Mirce
Hide Signatures
       Post #: 340
RE: Meister Scale P 47 - step by step - 2/19/2012 6:00 PM
mirce
Score: 100
Status: offline
Here are few more pictures...
Regards
Mirce
Hide Signatures
(in reply to mirce)
       Post #: 341
RE: Meister Scale P 47 - step by step - 2/28/2012 11:03 AM
mirce
Score: 100
Status: offline
In last few days I was working on cockpit...
Plastic parts I bought from Meister Scale site. For both sides I made reinforcements...
Pilot chair...
Than I made holes on instrument panel. I used felt tool on my Proxon...
On back side of the cockpit I glued thin balsa plate to cover hole on the rib. On upper part, I made pilot protection plate.
All in all, it look like this...
Yesterday I get package with few stuff, and one of them was pilot. I bought Premium pilot from Dino. It's nice, very detailed...
...and fit nice in cockpit...
On canopy is protective foil, so it little blurry...
Now I have all the parts that can make a model...
In last few days I was sanding some smaller parts, and on some I put primer. Final result is good...
I installed all the parts in switch box. With main switch, there are Robart parts for filling the air and pressure measurement, and small switch for lights.
Hope that today will add primer on all parts, and in next few days I will sand wing...
Best regards
Mirce
Hide Signatures
(in reply to mirce)
       Post #: 342
RE: Meister Scale P 47 - step by step - 2/28/2012 3:25 PM
Icemanjr92
Score: 100
Status: offline
Great progress Mirce!!
Hide Signatures
(in reply to mirce)
       Post #: 343
RE: Meister Scale P 47 - step by step - 2/28/2012 4:06 PM
mirce
Score: 100
Status: offline
Thanks Dino...
I'm finally back in my work shop, and progress is obvious.
I don't want to dirt my work shop with wing sanding. Weather forecast for next few days is good, temperature will be higher, so I can do that in my yard...
Until that I will work on gear doors.
Regards
Mirce
Hide Signatures
(in reply to Icemanjr92)
       Post #: 344
RE: Meister Scale P 47 - step by step - 2/28/2012 4:47 PM
Shiftyeddie
Score: 100
Last Login: 4/22/2012
Status: offline
Looks great Mirce!
As always, I look forward to watching your progress on this
plane.
Keep up the postings!
Eddie
Hide Signatures
(in reply to mirce)
       Post #: 345
RE: Meister Scale P 47 - step by step - 2/28/2012 8:09 PM
John Taylor
Score: 100
Status: offline
Great Work Mirce, I'm looking forward to your next step the gear doors. John T.
Hide Signatures
(in reply to Shiftyeddie)
       Post #: 346
RE: Meister Scale P 47 - step by step - 2/29/2012 6:20 PM
mirce
Score: 100
Status: offline
Thanks Eddie and John...
As I told here is few photos of gear door covers.
In kit you get gear doors made from ply, but retract not fit complete in wing, so doors must little to distort...
First, I made inside cover. Original wooden cover I use like template, and made new cover from 0,5 mm thin aluminum plate. Aluminum plate is easy to twist, but it's rather weak, so I add wooden part inside.
Cover sits nicely on the wing...
Hinges was next...
After that I start working on gear door which will be on lower part of the retract.
To be continued...
Regards
Mirče
Hide Signatures
(in reply to John Taylor)
       Post #: 347
RE: Meister Scale P 47 - step by step - 3/1/2012 1:04 AM
mirce
Score: 100
Status: offline
OK, I finished one side...
I made cover over retract mechanism, and on it I put hinges for door which cover retract leg...
Door which cover wheel is clamped on retract with two bolts...
As you can see leg door is going over wheel door, and on the overlap is small curvature not to bend to each other...
System is very simple, when retract start coming out wheel door push leg door...
Rubber is not most nicest detail, but it's practical and for now is good to see how system work. Rubber always pulling leg door to retract. Because that I must add one 1,2 mm thin ply inside leg door...
I am very pleased with how everything works. Its light, simple, look good and it's easy for maintenance, everything is on screws and nuts...
Now, I must gear doors copy - paste on other wing side, and finally must add pneumatic valves on inner gear doors. I will use Dino's system...
Regards
Mirce
Hide Signatures
(in reply to mirce)
       Post #: 348
RE: Meister Scale P 47 - step by step - 3/1/2012 4:13 AM
G T
Score: 100
Last Login: 5/17/2012
Status: offline
hi mirce
this is a great build ,, very impressive, your workmanship is outstanding and thanks for posting the great images with it
i am sure that all watching this build "as other have previously stated" appresiate the effort you are putting into the reports.
keep it coming
Hide Signatures
(in reply to mirce)
       Post #: 349
RE: Meister Scale P 47 - step by step - 3/1/2012 1:14 PM
John Taylor
Score: 100
Status: offline
Hi Mirce, great job on your gear doors. John T.
Hide Signatures
(in reply to G T)
       Post #: 350
Jump to:
Google
SITE MAP!   : :   FORUM RULES
RC Universe is a service of Internet Brands, Inc. Copyright © 2001-2012.
0.608RCU1
