fast turbine start up    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> fast turbine start up
Page: [1]
Login
fast turbine start up - 11/3/2011 9:24 PM
Santino.G
Score: 100
Last Login: 5/20/2013
Status: offline
 After the introduction of this new turbine start up philosophy published on this forum  few time ago,    http://www.rcuniverse.com/forum/m_10714066/tm.htm
today I have been starting the test on a boomerang sprint. I made two complete flights and lot of starts for incoming informations about  reliability of this system.
I enclouse two videos:
1) turbine start     http://www.youtube.com/watch?v=4kaM8xtOv1Q&feature=youtube_gdata_player
2) take off         http://www.youtube.com/watch?v=ZfOlJVYK4Pc&feature=youtube_gdata_player
The turbine is a KJ66 upgraded to a Eagle
Electric starter is a permax 280bb
all the electronic, single electrovalve and pump are inside the turbine cover
combustion chamber and injectors are original
Santino
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Santino.G -- 11/3/2011 10:10 PM >
Hide Signatures
       Post #: 1
RE: fast turbine start up - 11/3/2011 9:45 PM
thunderceptor
Score: 105
Last Login: 5/19/2013
Status: offline
Leonardo da Vinci= Italian
Alessandro Volta= Italian
Guglielmo Marconi= Italian
Santino Genovese= Italian
_____________________________
Alberto
Hide Signatures
(in reply to Santino.G)
       Post #: 2
RE: fast turbine start up - 11/3/2011 10:00 PM
Santino.G
Score: 100
Status: offline
 Grazie Alberto  ma mi sembra un pochino esagerato!
Thanks but it seems to much
Hide Signatures
(in reply to thunderceptor)
       Post #: 3
RE: fast turbine start up - 11/3/2011 10:10 PM
chrigui
Score: 100
Last Login: 5/8/2013
Status: offline
big boss...
www.jetflydemoteam.com
Hide Signatures
       Post #: 4
RE: fast turbine start up - 11/3/2011 10:11 PM
Joe C
Score: 100
Status: offline
quote:
ORIGINAL: thunderceptor
Joe Castelao= Italian
BEST IN THE WEST JET RALLY
www.bestinthewestjetrally.com Oct. 16th-20th, 2013
Hide Signatures
       Post #: 5
RE: fast turbine start up - 11/3/2011 10:43 PM
Vincent
Score: 105
Last Login: 5/21/2013
Status: online
quote:
ORIGINAL: Joe C
Vin DiFabbio... 100% Italian
Hide Signatures
(in reply to Joe C)
       Post #: 6
RE: fast turbine start up - 11/3/2011 10:51 PM
Joe C
Score: 100
Status: offline
quote:
ORIGINAL: Joe C
Ok, Sicilian
Hide Signatures
(in reply to Joe C)
       Post #: 7
RE: fast turbine start up - 11/3/2011 11:50 PM
Vincent
Score: 105
Status: online
quote:
ORIGINAL: Joe C
quote:
ORIGINAL: Joe C
Ok, Sicilian
Ok...Abruzzo
Hide Signatures
(in reply to Joe C)
       Post #: 8
RE: fast turbine start up - 11/4/2011 12:27 AM
ianober
Score: 100
Status: offline
OOOOHHHH!!!!!!!
Hide Signatures
(in reply to Joe C)
       Post #: 9
RE: fast turbine start up - 11/4/2011 1:26 AM
uncljoe
Score: 160
Status: online
FORGETABOUTIT !!!!!
Look towards the Horizon......your death awaits you there
Hide Signatures
(in reply to ianober)
       Post #: 10
RE: fast turbine start up - 11/4/2011 11:27 AM
Santino.G
Score: 100
Status: offline
 Sorry, but I don't mind  aspects other than technical one
I'd like to explain a little bit better this new start up philosophy, for the people that are curios to understand how it works.
This system differs from the standard kerosene start because it doesn't have the burner fuel line.
The flame departs direct from the main needle!
Obviously a particular prewarmer system has been designed to obtain this result.
Follows the Ecu sequence:
1) The electric motor run the turbine at about 3.000
2) In the meantime departs the heat 1 phase
3) as soon as the current needed for the heat1 decreases departs the heat 2 and the electric motor starts to accelerate the turbine as much as possible (maximum motoring)
4) at this point,  the pump runs for 2 seconds with higher voltage than requested (to permits unlock the gear) than reduce to the preselected value
5) the electrovalve starts cicle.
6) As soon as the temperature rises of about 4° from the 2seconds previous reading the electrovalve increases the % ON and decreases the % OFF
10) at 12.000 rpm the prewarmer heating it is switched off
11) at 22.000 rpm the electric motor  disengages from turbine
12) the rest is equal to other turbines
As introduced at the beginning of this thread to permits this system to work, is essential that:
1) the electric motor should be of  very high quality
2) the battery shoul have a good discharge current of about 15A for few seconds
3) the wire from battery to turbine if longer than 30 cm should be 4mm square to avoid drop voltage
4) the Ecu should be able to manage 15A  without interfere with its functioning dew to pwm frequency
5) Because the pump and the solenoid valve are inside the frontale case the tube from the hopper tank to the turbine should be at least 6mm outside to avoid pump cavitation
I enclouse a couple of inside Boomerang Sprint pics.
Winter condition and seasons of flights will be necessary to confirm or no the system reliablility.
Sorry for the english and for long post
Santino
P.S. the R&S TECHNOLOGY is just a joke. It is the name of my nephew Riccardo (he helped me in the develop of firmware over the last 4 years) and mine Santino,  nothing of commercial
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 11
RE: fast turbine start up - 11/4/2011 11:43 AM
chrigui
Score: 100
Status: offline
nice work....!!
Hide Signatures
       Post #: 12
RE: fast turbine start up - 11/4/2011 12:48 PM
S_Ciambra
Score: 100
Last Login: 1/10/2013
Status: offline
Salvatore Ciambra - Palermo (Italy)
Hide Signatures
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.453RCU1
