mvvs 1.60 gasser
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
1.60 GFS
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> mvvs 1.60 gasser
    Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
    Login
    mvvs 1.60 gasser - 9/1/2003 2:25 AM
    pe reivers
    Score: 111
    Last Login: 11/7/2009
    Status: offline
    MVVS is very proud of their inner engine gas transfer flow, enabling the smooth power output. A fringe benefit is low fuel consumption wich is the twin brother of a well tuned design. Not only the gas engine, the glow version is a winner as well.
    To check this issue statement:
    compare OS BGX with the new 1.60 FX , and you know why it took OS so long to get a well behaved glow engine of large capacity. These engines have a huge difference in specific fuel consumption (amount of fuel per BHP/h), and with the FX they finally hit the target.
    The superb ST 2300 is another fine example of much improved design when compared with the previous Big Tigres series. This concerns the engine, and not the crappy carb, which had all the marks of ignorance of mixture control.
    _____________________________
    Pe, Dealer for MVVS, MTW, Xoar and Mejzlik
    There is sanctuary in analysis.
    Hide Signatures
    (in reply to Patriot)
           Post #: 26
    mvvs 1.60 gasser - 9/1/2003 3:39 AM
    PlaneKrazee
    Score: 185
    Last Login: 11/4/2009
    Status: offline
    If you could put needle bearings in the 160FX it would be fun to see how it would run on gas with the Valch ignition.
    KB1DTB
    AMA11123
    Hide Signatures
           Post #: 27
    mvvs 1.60 gasser - 9/1/2003 4:50 AM
    kenair
    Score: 100
    Last Login: 11/1/2009
    Status: offline
    The weather has been just beautiful this long weekend so far, my two mvvs 1.6's have been behaving great.
    The older 1.6 with the round ignition has been turning a Zinger Pro 17x8 at 7700, it is in a 1/4 scale 72"ws Lanier Laser 200 at 11.6 pounds less fuel. This combo almost has unlimited vertical and if I had the red head in this plane I feel the verical would be 99% close to unlimited.
    Mean while my red head soldiers on in the Sig Cap 232, breaking in nicely. Today I switched to synthetic oil (Amsoil 50:1) after running on Pennzoil 40:1. Today's prop rpms is, Menz S 17x8, 8200 rpm.
    I'm using a Bisson muffler on the red head and the stock muffler ( modified with two down pipes) on the Laser)
    I've burned about 4 gallons of fuel so far through each engine and they have performed very well.
    A buddy just ordered a mvvs 1.6 to put in a new Sig Cap 232, his airframe will be a couple of pounds lighter than mine, I'm anxiuos to see how if flies.
    cheers - ken k.
    web page at www.upaero.com
    Blog at http://cavuday.blogspot.com/
    Hide Signatures
           Post #: 28
    quation for Pé Reivers - 9/1/2003 4:50 AM
    Scoubidou
    Score: 100
    Last Login: 11/6/2009
    Status: offline
    Hello Pé
    1)Is there a graph available somewhere showing the torque peak of that MVVS1.6 fonction to RPM or torque (Y axe) to RPM (X axe) without tune pipe?
    2)Or what are the best prop and RPM to develop maximum thrust with the Bisson Pitt muffler?
    Scoubidou
    Hide Signatures
           Post #: 29
    mvvs 1.60 gasser - 9/1/2003 2:27 PM
    pe reivers
    Score: 111
    Status: offline
    There is as far as I know of, no power graph for the 1.60
    The power max. is specified at 9000 rpm, so propping between 7500 and 8000 should give best flight results.
    As a reasonable rule of thumb, best torque is at 70% in two strokes, so it would be between 6000 and 6500 rpm. This is in line with many reports using props from 16x6 up to 20x8.
    In prop selection, much depends on plane performance window and drag, so experimentation is the key word, if you want to get the best out of your engine.
    IMAC pilots would probably prefer a 16x12/14 whilst glider tow would be better off using a 18x8/10 or even a 20x6/8
    Hide Signatures
           Post #: 30
    mvvs 1.60 gasser - 9/4/2003 5:56 AM
    JAYNC
    Score: 100
    Last Login: 3/6/2006
    Status: offline
    I bought an mvvs 1.60 redhead about 2 months ago and, I put it on a breakin stand. I put an 18x6 pro zinger on it and started it. During the 3-4 minutes that we ran it the highest rpm we got was 7750 rpm with the inverted bisson pitts muffler. I think once it is broke in and I go to 50:1 amsoil it will really be powerfull I am hoping 8500 rpm on a pro zinger. I put the engine on a DA Funtana and hope to fly it soon.
    Hide Signatures
           Post #: 31
    mvvs 1.60 gasser - 9/4/2003 6:10 AM
    Scoubidou
    Score: 100
    Status: offline
    Wow, very good reading. I am gonna buy one next week for my CA Extra300!!!
    How many mamp do you use for ignition?
    Hide Signatures
           Post #: 32
    mvvs 1.60 gasser - 9/4/2003 6:40 AM
    PlaneKrazee
    Score: 185
    Status: offline
    How does the 18X6 Pro Zinger compare to the APC 18X6W?
    I will be interested to see how much more you get after a couple of gallons. It should be run in by then.
    KB1DTB
    AMA11123
    Hide Signatures
           Post #: 33
    mvvs 1.60 gasser - 9/4/2003 9:21 AM
    JAYNC
    Score: 100
    Status: offline
    I put a 1500mah 4.8 pack up front for the ignition and an electronic kill switch for back-up.
    Hide Signatures
           Post #: 34
    mvvs 1.60 gasser - 9/4/2003 5:41 PM
    kenair
    Score: 100
    Status: offline
    I tried a 18x6 standard zinger on my red head las Saturday, tached at 7800.
    It flew the cap 232 but airspeed was too slow, I need more pitch than a 6, sure slowed down for landing though.
    --ken
    Hide Signatures
           Post #: 35
    mvvs 1.60 gasser - 9/4/2003 9:21 PM
    pe reivers
    Score: 111
    Status: offline
    props that performed well are 16x12, 18x8 and 18x10
    6" pitch is good for small glow engines, not gassers.
    We tried the engine in a hover application. Here too, the 8" pitch proved better.
    Hide Signatures
           Post #: 36
    mvvs 1.60 gasser - 9/5/2003 6:20 AM
    JAYNC
    Score: 100
    Status: offline
    It depends on what you like to do when you fly, I like the 6" pitch because I hate to fly really fast and I like to do 3d. I guess everyone has their own preferences. I have a bunch of different props that I will try the first few times out. It also will be on a DA Funtana which doesnt need to fly fast and is almost impossible to stall since it weighs less than 11 pounds ready to fly.
    Hide Signatures
           Post #: 37
    mvvs 1.60 gasser - 9/5/2003 7:12 AM
    PlaneKrazee
    Score: 185
    Status: offline
    For aerobatics it depends on the rpm. A 18X6 between 8500 and 9500 rpm is good, a 18X8 between 7200-8200 good. 10" pitch good 6000-7000, 12" pitch below 6000 rpm, etc.
    OS 160FX APC 18X6W 9200 RPM. Good speed, good vertical. Excellent unlimited in a 13 lb. plane, would pull out of hover well. Good in a 14 lb. plane, barely pull out of hover.
    OS160FX APC 18X8W 8200 RPM. More Speed, not so much vertical.
    All with Jtec dual Snuffler and Hobbico exhaust extensions, very quiet and clean.
    < Message edited by Skypilot_one -- Sep 5 2003 10:56AM >
    KB1DTB
    AMA11123
    Hide Signatures
           Post #: 38
    Problems starting - 9/5/2003 8:44 AM
    pequeajim
    Score: 100
    Last Login: 9/28/2009
    Status: offline
    I have an older MVVS 1.6 with the round black ignition. It has been sitting in a box over the winter and I just got around to putting it in a plane.
    I can not get the engine to fire even with a starter.
    I know that I am getting power to the ignition module and gas to the carb.
    What is the best way to test to see if the ignition module is firing?
    Is there a standard way of testing it?
    Jim!
    AMA 653825
    Buck RC Club
    Hide Signatures
           Post #: 39
    mvvs 1.60 gasser - 9/5/2003 9:02 PM
    pe reivers
    Score: 111
    Status: offline
    A starter does not provide better performance in these engines, because when the spark and all else is OK, a lazy flip will do best.
    To check: (battery charged and "on"??
    1- the plug should be clean. When in doubt, fit a new one.
    2_ To check the spark, make absolutely sure that the mass connection is maintained. The module is easily damaged when allowed to spark without plug, or without proper mass connection.
    The ignition module resets, when the power is turned off, and on again.
    Hide Signatures
           Post #: 40
    mvvs 1.60 gasser - 9/5/2003 10:54 PM
    lxcoupe
    Score: 100
    Last Login: 10/27/2009
    Status: offline
    I have a Dp Ultimate that I just bought a redhead for. I'm waiting on the bisson pitts muffler before i install it. Morris says they will be in this week, but they also told me that 3 weeks ago when i ordered it...lol Anyway I'm running a saito 150 in my ultimate now and it will spin a 16x8 apc on the ground at 8400-8500 rpm. I was hoping that once i get my mvvs in her that i'll see approx the same rpm with a menz S 18x8. If so the plane should have quite a bit more thrust.
    BTW, if anyone has a bisson pitts for this engine that they want to sell. I will buy it.
    AL
    Hide Signatures
           Post #: 41
    mvvs 1.60 gasser - 9/6/2003 6:20 AM
    pequeajim
    Score: 100
    Status: offline
    So can I ground the plug to the engine and flip the prop and I should see a spark, correct? This will not hurt the ignition?
    Jim!
    AMA 653825
    Buck RC Club
    Hide Signatures
           Post #: 42
    mvvs 1.60 gasser - 9/6/2003 1:31 PM
    pe reivers
    Score: 111
    Status: offline
    Jim,
    It should not hurt the ignition if you make absolutely certain ground contact with engine and plug boot is maintained all the time. You have not removed the HT lead from the can did you? If you did: Ouch! and you may have to send it in for repair. (I sealed the HT connections on engines I prepared to make sure the customer understood it is not a user option to dismantle the HT cable).
    For spark checking, you do not need to flip the prop. Just move the magnet to and fro past the Hall pickup sensor.
    For the completed work on the ignition download my manual at
    http://mvvs-nl.com/MVVS/ignition_manualPRME.pdf
    This manual is for the PZ-1a ignition only (round can).
    The Vlach ignitions have very much improved protection cirquits and are very forgiving.
    Hide Signatures
           Post #: 43
    mvvs 1.60 gasser - 9/6/2003 1:39 PM
    pe reivers
    Score: 111
    Status: offline
    Al,
    you will not get those rpm with the menz 18x8 prop. It would exceed the engine specifications, obtained with tuned pipes.
    See my prop power/thrust calculator at http://home.wanadoo.nl/pereivers/prop-power.xls
    I would appreciate your results.
    Hide Signatures
           Post #: 44
    RE: mvvs 1.60 gasser - 9/9/2003 3:38 AM
    JimRoss
    Score: 100
    Last Login: 6/29/2008
    Status: offline
    I just got an almost new MVVS 1.6 and I'm putting it in an Edge 540 80" ws.
    Having a little trouble mounting the ignition module though. Can I get away with putting it inside the firewall and run the wires out to it? Need to be mounted in foam? It mounted nicely and looks real good. soon as I can get the battery hooked up and charged I'm gonna run it to see what kind of speed I can get out of it.
    I also got the exhaust flange for a tuned pipe system but I need to know what tuned pipe to get for it.
    No matter where you go, there you are.
    Of All the people I know, you're one of them.
    Hide Signatures
    (in reply to pe reivers)
           Post #: 45
    RE: mvvs 1.60 gasser - 9/9/2003 11:08 PM
    pe reivers
    Score: 111
    Status: offline
    So far, the original MVVS tuned pipe has performed best
    Hide Signatures
    (in reply to JimRoss)
           Post #: 46
    RE: mvvs 1.60 gasser - 9/12/2003 2:51 AM
    JimRoss
    Score: 100
    Status: offline
    Ok, here comes the next silly question. Is Morris Hobbies the only place to get the tuned pipes?
    Hide Signatures
           Post #: 47
    RE: mvvs 1.60 gasser - 9/12/2003 2:59 AM
    PlaneKrazee
    Score: 185
    Status: offline
    Still no engines at Morris. Two weeks, two weeks, two weeks. Sounds like Total Recall (the Movie).
    KB1DTB
    AMA11123
    Hide Signatures
           Post #: 48
    RE: mvvs 1.60 gasser - 9/12/2003 3:11 AM
    lxcoupe
    Score: 100
    Status: offline
    That sounds familiar
    Al
    Hide Signatures
    (in reply to PlaneKrazee)
           Post #: 49
    RE: mvvs 1.60 gasser - 9/12/2003 4:16 AM
    JimRoss
    Score: 100
    Status: offline
    Just looked at Morris Hobbies web site. Ouch! A tuned pipe for the 1.60 is $79.00 + shipping. Have a Pitts style wrap around muffler for mine but haven't gotten to run it yet. Kind of anxious to see what it's gonna do. Soon, real soon, I'll have some info on it.
    Hide Signatures
    (in reply to JAYNC)
           Post #: 50
    1.60 GFS
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    Kaango.com Classifieds
    1.469RCU1
