pe reivers
Joined: 1/23/2002 From: Arcen, , NETHERLANDS Status: offline
There is as far as I know of, no power graph for the 1.60 The power max. is specified at 9000 rpm, so propping between 7500 and 8000 should give best flight results. As a reasonable rule of thumb, best torque is at 70% in two strokes, so it would be between 6000 and 6500 rpm. This is in line with many reports using props from 16x6 up to 20x8. In prop selection, much depends on plane performance window and drag, so experimentation is the key word, if you want to get the best out of your engine. IMAC pilots would probably prefer a 16x12/14 whilst glider tow would be better off using a 18x8/10 or even a 20x6/8
_____________________________
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl There is sanctuary in analisys.
