RE: mvvs 1.60 gasser
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
1.60 GFS
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: mvvs 1.60 gasser
    Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
    Login
    RE: mvvs 1.60 gasser - 9/12/2003 10:58:30 AM
    PlaneKrazee
    Status: offline
    Morris Hobbies should update their site to say they do not have them in stock and that they may have them by Thanksgiving.
    _____________________________
    KB1DTB
    AMA11123
    (in reply to JimRoss)
           Post #: 51
    RE: mvvs 1.60 gasser - 9/12/2003 1:23:37 PM
    Scoubidou
    Status: offline
    You can buy the tune pipe muffler and MVVS engines at:
    1)http://www.topmodel.fr/product_list.php?rows=5&desc=0&f_top=1&f_cat=93&f_text=&sid=1e8ca836c962598551882e689265c1c5&pos=21
    2) http://www.justengines.unseen.org/mv160p.htm
    3) http://www.mvvs-nl.com/, from Pé Reivers, great support, good price good service.
    Scoubidou
    (in reply to JAYNC)
           Post #: 52
    RE: mvvs 1.60 gasser - 9/12/2003 4:56:22 PM
    pe reivers
    Status: offline
    Blush:
    I too don't have the new engines in stock (MVVS says: soon), though I still do have a few of the early 2003 production. Mechanically, they are equivalent.
    (in reply to JAYNC)
           Post #: 53
    RE: mvvs 1.60 gasser - 9/12/2003 5:35:03 PM
    JimRoss
    Status: offline
    Do you have any of the tuned pipes for the 1.60? I already have the curved pipe that fits o the engine, I just need the tuned pipe and the coupler. If so, how much including shipping to Texas, zip code 77535?
    No matter where you go, there you are.
    Of All the people I know, you're one of them.
    (in reply to pe reivers)
           Post #: 54
    RE: mvvs 1.60 gasser - 9/18/2003 2:39:37 AM
    kenair
    Status: offline
    I flew a couple more props on my red head and the Sig Cap 232.
    Top FLite power point 18x8 tached at 7200 rpm, flew the plane well, nice pull on the up lines, engine seemed to be lugging a bit, may cut this prop down to a 17.5x8
    Also tried the Top Flite pp 18x6-10, tached at 6600 rpm, plane flew a bit sluggish and engine was lugging, to much prop IMHO.
    cheers - ken k.
           Post #: 55
    RE: mvvs 1.60 gasser - 9/18/2003 5:23:08 AM
    GeraldO
    Status: offline
    Several posts were skipped over when the website changed over. Here's one of mine which I just copied from the old website:
    I recently took my MVVS 1.60 off the tuned muffler and installed a KS cannister type smoke muffler. I am currently running an APC 18x8W (wide blade)prop and getting RPM measurements of 7650. I have an 18x8N that I haven't tried yet.
    (in reply to JAYNC)
           Post #: 56
    RE: mvvs 1.60 gasser - 9/18/2003 11:19:58 AM
    PlaneKrazee
    Status: offline
    How do you get to the old site? I always get redirected to the new site.
    KB1DTB
    AMA11123
    (in reply to GeraldO)
           Post #: 57
    RE: mvvs 1.60 gasser - 9/18/2003 4:29:06 PM
    Maudib
    Status: offline
    FYI... there is a brand new alternative 35cc gas engine out there now...
    It's $395 with mount and muffler... similar weight to the MVVS...
    More info at this thread: http://www.rcuniverse.com/forum/NEW_35CC_Gasser_for_120%2D140_size_planes%21%21%21%21/m_1145153/tm.htm
    (in reply to PlaneKrazee)
           Post #: 58
    RE: mvvs 1.60 gasser - 9/19/2003 5:21:34 AM
    GeraldO
    Status: offline
    J. David
    Columbus, OH
    http://www.renderwurx.com/rc
    This discussion is about the MVVS 1.60 (26cc) engine. The 35cc engine you are referring to is MUCH heavier and larger than the 1.60 we are talking about.
    (in reply to JAYNC)
           Post #: 59
    RE: mvvs 1.60 gasser - 9/19/2003 6:50:02 AM
    Herby 1
    Status: offline
    A 26cc Zenoah with ighition conversion weighs 2 1/2 lbs with ignition, without muffler...
    Fair comparison ?
    Mejzlik 18-6 8800 rpm with an Abell Muffler....$380.00 from BH Hanson in Las Vegas....
    < Message edited by RCIGN1 -- 9/19/2003 7:51:29 AM >
           Post #: 60
    RE: mvvs 1.60 gasser - 9/19/2003 11:40:41 AM
    Maudib
    Status: offline
    My humblest apologies...
    I was just sharing some info I just found out about something new I saw... It is comparable to the MVVS 2.1 and is (after you add a muffler to the 1.6) about 16 oz. heavier... that is alot...
    FWIW, the same manufacturer has a 25cc coming soon... but I won't bother you with the details as it's not relevant to your discussion.
    Take care.
           Post #: 61
    RE: mvvs 1.60 gasser - 9/19/2003 12:44:04 PM
    PlaneKrazee
    Status: offline
    An OS 160FX spins a Mejzlik 18X6 at over 10,000 rpm. with a bisson ST 4500 muffler.
    What will the Z 26 running on gas spin an APC 18X6?
    KB1DTB
    AMA11123
    (in reply to Herby 1)
           Post #: 62
    RE: mvvs 1.60 gasser - 9/19/2003 12:51:18 PM
    Scoubidou
    Status: offline
    Modified Zenoah with ignition??,
    Hi Rcsign, is there a link where we could read the spec. on that new modified Zenoah G26 please?
    18x6 at 8600RPM sounds attractive for gas engine at 2.5 pounds
    Scou
    (in reply to Maudib)
           Post #: 63
    RE: mvvs 1.60 gasser - 9/19/2003 12:52:42 PM
    kenair
    Status: offline
    The G23's / G26's are great engines like the 1.6 and each engine has it pro's and cons, and I have flown each, the mvvs has certain features that I like, such as the slimer width with the front mounted carb, lightweight out of the box with no modifications.
           Post #: 64
    RE: mvvs 1.60 gasser - 9/19/2003 3:15:44 PM
    pe reivers
    Status: offline
    I tried to mail you, but the messages bounced.
    Mail to preivers@mvvs-nl.com, and I will send you a quote for pipe without header.
           Post #: 65
    RE: mvvs 1.60 gasser - 9/19/2003 3:27:37 PM
    Patriot
    Status: offline
