RE: mvvs 1.60 gasser carb #'s
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
1.60 GFS
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: mvvs 1.60 gasser carb #'s
    Page: <<   < prev  48 49 [50] 51 52 53 54 55 56 57   next >   >>
    Login
    RE: mvvs 1.60 gasser carb #'s - 9/9/2006 7:37:02 AM
    hollerp89
    Status: offline
    i AM LOOKING FOR A MVVS .09 NEEDLE VALVE THROTTLE KIT. OR CLOSE TO THAT SIZE ,
    THANK YOU BOB
    _____________________________
    nothing sings like a cox engine all day long
    (in reply to CoolShuttle)
           Post #: 1226
    RE: mvvs 1.60 gasser carb #'s - 9/9/2006 10:37:35 PM
    FentonFlyer
    Status: offline
    Pe or Dick,
    Is the APC 17x8N a good prop for the 26 on a tuned pipe?
    < Message edited by FentonFlyer -- 9/9/2006 10:38:01 PM >
    Getting Undeserved Credit Since '07
    (in reply to hollerp89)
           Post #: 1227
    RE: mvvs 1.60 gasser carb #'s - 9/9/2006 10:52:23 PM
    dick Hanson
    Status: offline
    depends on application
    so far - and I have used my setup on the Showtime and Funtanas, the 18x6 props which spin easily seem best - but that might be a good prop an a fast sporty setup - say a scale racer where you want it to really move-or if you like old style pattern where it really cooks - should be great .
    < Message edited by dick Hanson -- 9/9/2006 10:53:25 PM >
    I am watching you
    Libby
    (in reply to FentonFlyer)
           Post #: 1228
    RE: mvvs 1.60 gasser carb #'s - 9/9/2006 11:52:58 PM
    pe reivers
    Status: offline
    The APC prop 18x8N spins in excess of 8000 rpm, so I wold use at least a 10"pitch if you are after speed. (16x12 or 17x11)
    For thrust, and power reserve (needed for quick spool-up in 3D) the 18x6 is best.
    For normal sports, use 18x8 or 18x10
    APC does not provide the best thrust in these sizes. In my tests, it performed worst of all
    (compared to Menz- and clones, Mejzlik, Zinger)
    Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl
    There is sanctuary in analisys.
    (in reply to dick Hanson)
           Post #: 1229
    RE: mvvs 1.60 gasser carb #'s - 9/10/2006 1:00:30 AM
    FentonFlyer
    Status: offline
    I'm using the 26 on a CMP Giles 202. I have an 18x6 menz, an 18x6 Pro Zinger, an 18x6 Top Flight or the APC 17x8. I guess for starters, I'm looking for more pattern speed than 3D. Also, the plane is a little overweight, so I thought the 8" pitch would help with keeping speed up a bit on final.
    Any more thoughts?
    (in reply to pe reivers)
           Post #: 1230
    RE: mvvs 1.60 gasser carb #'s - 9/10/2006 1:07:07 AM
    dick Hanson
    Status: offline
    the pitch being lower is actually better for landing- keep revs up and then control final speed with throttle -NOT elevator
    I am watching you
    Libby
           Post #: 1231
    RE: mvvs 1.60 gasser carb #'s - 9/10/2006 7:15:06 AM
    RysiuM
    Status: offline
    quote:
    ORIGINAL: preivers
    APC is very heavy spooling up much slower than CF or wooden props - not good for 3D. I run 18x6 Mejzlik on Powerline Hobbies Edge 540, and this is the happiest prop for this plane.
    Mather Aerospace Modelers, Inc.
    AMA Gold Leader Club, Charter #1243, Sacramento, CA
           Post #: 1232
    RE: mvvs 1.60 gasser carb #'s - 9/11/2006 2:57:37 PM
    killuminati
    Status: offline
    This being my first gas engine, I see all the plastic pustrods. Is my metal pushrod going to be a problem? I plan on starting it for the first time tonight. Should I just see what happens or go ahead and find a plastic pushrod. My next question would be where to get one.
    (in reply to RysiuM)
           Post #: 1233
    RE: mvvs 1.60 gasser carb #'s - 9/11/2006 10:07:13 PM
    pe reivers
    Status: offline
    Look for Sullivan Golden rod
    (in reply to killuminati)
           Post #: 1234
    RE: mvvs 1.60 gasser carb #'s - 9/11/2006 10:12:16 PM
    killuminati
    Status: offline
    So no go on the standard metal rod?
           Post #: 1235
    RE: mvvs 1.60 gasser carb #'s - 9/11/2006 11:12:50 PM
    pe reivers
    Status: offline
    A metal rod may cause interference on the radio. Do not use them for throttle or choke.
           Post #: 1236
    RE: mvvs 1.60 gasser carb #'s - 9/12/2006 12:25:18 AM
    RysiuM
    Status: offline
    quote:
    ORIGINAL: killuminati
    I use a combination. Inside both ends of 10-15 inch golden rod I screwed in a short piece (2 - 1.5 inch) of metal threaded rod. The golden rod is running inside the plastic sleve but both loose ends (without the sleve) do not bend because of the metal inserts. This way I have thread on both ends for clevis to put on, and the part of golden rod between sleve and the servo horn (or throttle arm) and th sleve doesn't bend for crisp throttle control. And what is important, the plastic rod doesn't melt from the engine heat.
    You can see the throttle setup on my MVVS 1.6 in Powerline Hobbies Edge below
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    < Message edited by RysiuM -- 9/12/2006 12:27:14 AM >
           Post #: 1237
    RE: mvvs 1.60 gasser carb #'s - 9/12/2006 12:36:25 AM
    jamiem75
    Status: offline
    fiberglass or carbon fiber pushrods also work very well. The dave brown fiberglass rods that tower sells are what I used.
           Post #: 1238
    RE: mvvs 1.60 gasser carb #'s - 9/13/2006 2:49:14 PM
    killuminati
    Status: offline
    Gold-n-rod worked great thanks.
    (in reply to jamiem75)
           Post #: 1239
    RE: mvvs 1.60 gasser carb #'s - 9/13/2006 3:08:54 PM
