dmccoach
PA, USA Status: offline
quote:
ORIGINAL: dick Hanson The Zinger 18x8 -that I have tried -- loads engine too much and it never gets on the pipe - Put the 18 x6 on it Unless the engine is allowed to turn over 8000 the pipe simply does not work. 15 cm is shortest good performance length of header that we have run - shorter will require faster running band. I have run aluminum and the steel header no difference in performance if both same length the al header as a wee bit larger internally but that made no difference. Thanks again Dick - I will try the Skorepa 18x6, tach it and report back here - However, I cut the Macs header to 12CM because that is how long the steel one is: http://mvvs.nl/ (see petrol engines and then the pipe link for the 26). Are you suggesting up to 15CM will provide better results? I know, you will tell me - start with a given length, tach, cut 1/8ths, tach again, cut again, etc. till you are happy with performance, but, the steal pipe (which I have) is manufactured at 12CM, so theoretically, I would have started this process from 12CM? Thank you, Dan
< Message edited by dmccoach -- 11/27/2006 1:07:03 AM >
