RysiuM
Joined: 4/22/2003 From: Elk Grove, CA, USA Status: offline
quote:
ORIGINAL: makib For first time starting after long period close choke, make abouth 10-20 flips Like I wrote, it would take more than 20 flips (it will be more than 1000 flips) to get the fuel to the carb. I admit, that the fuel tank is about 10 inches behind the engine, but still the fuel moves in the line very slow. Comparing to my other engines, where every flip the fuel moves about 1/4 inch in the line for every flip, in MVVS I can't see any movement in the fuel line. Once the carb is wet, it draws the fuel without problem. Maybe my carb is bad (it was always like that) or maybe I should open the pump cover and check the membrane for contamination. I think I have the same version (red head, two magnets, Vlach ignition). Once it starts the engine is awesome.
_____________________________
Mather Aerospace Modelers, Inc. AMA Gold Leader Club, Charter #1243, Sacramento, CA
