pe reivers
Joined: 1/23/2002 From: Arcen, , NETHERLANDS Status: offline
If the plug is too dark, your mixtures are set too rich. This is hardly influenced by the oil content. First set your needles right. MVVS sets them quite rich to allow sure starts. The low needle influences the full range, while the high needle is for the top half only. That means, that the low needle must be adjusted first. Lean it out for max rpm, then open up 1/4 turn. Then turn to the high needle, and find max rpm. Richen about 1/8 tyrn. Now go back to the low needle, and check throttle response. Lean out, till response gets less, then richen up again to good response. Finally readjust the high needle for max rpm with richest setting, maybe 50 rpm off peak. Repeat the procedure as required to get it just right. Now your plug insulator should show a deer brown color, or medium grey, depending on gas or oil brand. White indicates lean mixtures, black is too rich. This is not changed by oil content, unless you enter the 1:10 range; Then the oil will darken the plug somewhat. This works for me. Important!! Set your standard idle throttle setting so that engine will keep running, and is switched off using the ignition. Starting: open the throttle to 1/3, then close the choke, and flip until the engine fires. (about 5 flips) The engine will stop again. Close throttle to a few clicks open, open the choke slightly and start the engine. That should be in about 3 flips. As the engine warms up, open the choke and check throttle response. Alternative: Choke the engine, ignition off, at 1/3 throttle, untill it is hissing wet. Open the choke slightly, throttle few clicks open, turn on ignition, and flip. Starting is on first or second flip. Open the choke as the engine warms up.
_____________________________
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl There is sanctuary in analisys.
